New Reply
Regarding Weight Calculation !
Share Thread Thread Tools
Feb10-13, 12:51 AM   #1
I Found that my body weight with shoes is found less than the sum of ( body weight without shoes + weight of shoes ).
example : Weight of body is A and Weight of shoes is B
Human weight wearing shoes is C
I Found that C > ( A + B ).
Is it possible ?
PhysOrg.com
PhysOrg
physics news on PhysOrg.com
>> As chaos celebrates its 50th birthday, biophysicist develops a new method to visualize it
>> Novel features of helium-3 superfluidity discovered with new SQUID detector chip
>> Physics of 'green waves' could make city traffic flow more smoothly
Feb10-13, 01:09 AM   #2
Recognitions:
Gold Membership Gold Member
I don't believe so. It's probably a result of your scale having different weighing errors at different amounts of weight. IE if you put 5 pounds on it, it may be accurate to within 1-2 pounds, and if you put 150 pounds it may be accurate to within 2-3 pounds. If you put 155 pounds it may still be accurate to within 2-3 pounds. So if you add the first two measurements you could be off by several pounds compared to the third measurement just due to the errors inherent to the scale and the fact that you took multiple measurements.
Try doing several different measurements. Try putting your shoes on the scale and then pressing down and letting the scale come back up afterwards and see if that changes the measurement. Sometimes if it approaches the weight from the other way it will be different. Does that make sense?
Feb10-13, 01:46 AM   #3
Thanks for your answer which gives a possibility for these kind of situations as well.
I have seen the reverse as well in a new weighing machine where C < ( A + B ) does the sponge material available in it makes the difference ?
Feb10-13, 02:06 AM   #4
Recognitions:
Quote by Nivas.S View Post
I think it's unlikely.
New Reply
Thread Tools
Similar Threads for: Regarding Weight Calculation !
Thread Forum Replies
Proving that apparent weight is 5 times actual weight (no numbers) Introductory Physics Homework 12
Dumbbell Counter Weight Calculation Introductory Physics Homework 1
Rail transportation, train weight to passenger weight, reduce how much? Mechanical Engineering 5
weight percent concentration calculation with partition coefficients Biology, Chemistry & Other Homework 0
Weight Calculation General Engineering 11
