Do complex number have anything like consecutive numbers?
In summary, the complex numbers cannot be ordered in the same way as the natural, rational, and real numbers. While there are different ways to define an ordering for complex numbers, none of them fully respect the algebraic structure and properties of complex numbers. Additionally, the Well Ordering Principle does not apply to the complex numbers, as they cannot be well-ordered. Therefore, there is no concept of consecutive numbers in the complex number system.
achyut joshi
does complex number have anything like consicutive numbers? . Like 2,3,4 are consicutive integers...
No. Both the rational and real numbers have the property that between any two rational (or real) numbers there exist at least one rational (or real) number and that property extends to the comple number- there cannot be a "next" complex number.
Sure they do. Every set can be well-ordered.
Give the complex numbers a well-ordering. For each complex number z, consider the minimal element of the set of complex numbers larger than z. This will be the least number larger than z, in other words, a consecutive element.
Now this of course applies to R and Q as well, but note that this cannot correspond to their usual order. The complex numbers however don't have any natural ordering (which satisfies e.g. a < b --> a+c < b+c), so I don't see how the order properties of the real numbers extends to the complex numbers.
There is one similarity between natural numbers and complex numbers which is that two concecutive integers multiplied together then multiplied by 4 is one less than a perfect square. In other words if n is an integer then 4n(n+1)+1 is a perfect square. Likewise if z is a Gausian integer then 4z(z+1) + 1 is a perfect complex square. This leads me to define two consecutive Gausian Integers to be z and z plus 1.
I think Halls was referring to the property of being dense(http://en.wikipedia.org/wiki/Dense_set).
no, which is a bit frustrating. we can't "totally order" the complex numbers in a way that corresponds to our notion of "bigger".
there is, however, a "partial" order, where we can say the "size" of a complex number is how far away it is from 0 = 0+0i.
this partitions the complex plane into a set of concentric circles, all the points on any circle are "all just as big".
for Gaussian integers, that is complex numbers of the form m+ni, where m,n are integers, we can order them (in a similar way) by their norm:
N(m+ni) = m2+n2 = |m+ni|2.
numbers with the same gaussian norm, also lie "on the same circle". but we have no way of telling whether 3+4i should "come before" 4+3i, or not, because both have the same norm.
suppose for numbers with the same norm, we arbitrarily list numbers counter clockwise from zero degrees. Then we can definitively say that one complex number comes before or after another in our catalog.
But you can never make an "ordered field" out of them: http://en.wikipedia.org/wiki/Ordered_field
http://planetmath.org/encyclopedia/OrderedField.html
A different explanation of ordered field.
the trouble with this, is that even though we keep going "bigger" (counter-clockwise), we eventually "come full circle" (as we approach 360 degrees). this is the same kind of trouble with have with ordering finite fields: since p-1 = -1, is this number < 0 or > 0 (apparently it's BOTH).
if we just consider what happens on the unit circle, we can have z > z0, w > z0, but zw < z0.
so this "<" doesn't behave well with respect to complex multiplication.
there are lots of possible orders. we could define a+bi < c+di as:
a < c, or if a = c, b < d.
but this "<" doesn't behave well with respect to complex addition.
the trouble is (more specifically), the field C doesn't have a "positive cone". with addition, we might be tempted to select the first quadrant, but multiplication can rotate, which nixes that idea.
Consider the integers. We have -1< 0, -2< 0 and (-1)*(-2)>0. So the integers aren't an "orderred field" either but they do have an order to them. So back to OP's question: Can we order the complex numbers? yes. Does that order mean anything? I don't know.
achyut joshi said:
does complex number have anything like consicutive numbers? . Like 2,3,4 are consecutive integers...
The complex numbers can not be an ordered field in the sense that there is no total ordering, x < y, of them that respects the algebraic structure.
technically this means (see article) that if a < b then a + c < b + c for all numbers c
and if 0 < a and 0 <b then 0 < ab
Notice that since this is a total ordering that any number is either less than or greater than any other.
Following the Wikipedia article, i^2 must be positive - the square of any number is positive i.e. greater than zero in the ordering -so the complex numbers can not be ordered.
The Well Ordering Principle says that any set can be well ordered. A well ordering is stringer then a total ordering since every subset of a well ordered set must have a smallest element. The reals are not well ordered in the usual ordering so a well ordering of the complex numbers can not extend the ordering of the reals.
yes but you are using numbers less than 0.
a "positive cone" refers to a subset of a field, considered its "positive elements". it must be closed under addition and multiplication. the positive cone of the real numbers derives from the fact the the natural numbers (including 0) form a sub-semi-ring of the semi-ring of integers (which is in fact, a full-fledged ring).
with the complex numbers, we do have an analog of the integers, the Gaussian integers Z, so one might hope that we could order THOSE, and then "fill in the gaps". but we don't have a suitable sub-semi-ring that qualifies as being dignified with the name "positive Gaussian integers".
geometrically, you can think of a total ordering as establishing a line where every number gets a unique place in line. for a given kind of "summing" and "multiplying" to be compatible with this order, we want addition and multiplication to be "order preserving on positive elements":
that is, if we write f(x) = c+x, and g(x) = cx:
0 < a < b --> f(a) < f(b)
0 < a < b --> g(a) < g(c)
well, both "stacking" (addition) and "stretching" along a given direction on a line do this. but on a plane, adding isn't "linear stacking" anymore, it's "head to tail" (triangle summing). and multiplying isn't just "stretching" (or dilation, as physicists are won't to call it), it's "stretching and rotating" (this turns out to be true even for the 4-dimensional quaternions, which is as many dimensions as we can get before things get really wacky).
that one extra degree of freedom of motion, really puts a monkey wrench in things. it makes you think in terms of circles (or should i say disks?), instead of segments.
in particular, the concepts "least upper bound" and "greatest lower bound" lose their utility as ideas when dealing with complex numbers, and induction loses a lot of power, as well. that's one of the reasons topology has become so important to mathematics...the complex numbers have some very desirable properties (including being able to solve problems that don't seem to even involve complex numbers), but we've had to devise a better framework of "closer" and "farther" than "smaller" and "bigger".
No, I guess not because there is no inequality or comparision in case of different complex numbers. We can compare their magnitudes, but never the complex numbers themselves...
Complex numbers are useful abstract quantities that can be used in calculations and result in physically meaningful solutions..The sum and difference of two complex numbers are defined by adding or subtracting
1. Do complex numbers have a concept of "consecutive" numbers?
Yes, complex numbers have a concept of consecutive numbers, but it is different from the concept of consecutive numbers in real numbers. In complex numbers, consecutive numbers are defined as numbers that are separated by a distance of 1 on the complex plane. This means that the real and imaginary parts of the numbers differ by 1.
2. How are consecutive complex numbers represented on the complex plane?
Consecutive complex numbers are represented on the complex plane as points that are one unit apart on the x-axis. This means that the real parts of the numbers are consecutive, while the imaginary parts remain the same.
3. Can a complex number have more than one consecutive number?
Yes, a complex number can have more than one consecutive number. In fact, every complex number has an infinite number of consecutive numbers, as there is an infinite number of points that are one unit apart on the complex plane.
4. Are there any patterns in the consecutive complex numbers?
Yes, there are patterns in the consecutive complex numbers. For example, the consecutive numbers of 3+4i are 4+4i, 5+4i, 6+4i, etc. This pattern can be seen on the complex plane as points forming a straight line parallel to the real axis.
5. How are consecutive complex numbers used in mathematics?
Consecutive complex numbers are used in various areas of mathematics, including complex analysis, number theory, and algebra. They can be used to solve equations and problems involving complex numbers, and also play a role in the study of complex functions and polynomials.
  • Linear and Abstract Algebra
  • Classical Physics
  • Precalculus Mathematics Homework Help
