Speed of light becomes Infinity and Zero
In summary, the conversation discusses the idea of time dilation and Lorentz contraction in relation to the speed of light. It is noted that photons, which travel at the speed of light, do not experience time and have no valid reference frame. The equation t = t0/√(1-v2/c2) is mentioned but questioned for its accuracy and explanation of variables. The concept of the speed of light being considered as an infinitely great velocity is also discussed.
RiddlerA
58
Speed of light becomes Infinity and Zero!
Hi Guys, I am just new to SR & GR. I learned about Lorentz contraction and time dilation, but they don't make sense when i consider the following situation...
Your(Moving non inertial frame) Time runs slow relative to a stationary observer when your speed increases and it will become infinity(as t = t0/√(1-v2/c2)) if speed v equals 'c' right?
Since photons travel at speed c, their time relative to our world or the whole universe must be infinity.. Since it takes infinite time to move relative to us, we can safely assume that the photon doesn't move at all(relative to our frame).. i.e. speed of light = 0 :confused:
Now consider Lorentz contraction... L = L0√(1-v2/c2))
This means that as the object's speed increases, its length decreases(in the direction of motion)... So if the object's speed equals 'c' ,then its lenth would be 0 (in the direction of motion)... But we know there is no absolute frame(since einstein forbade the ether :wink:)
So we can say that photon travels at c relative to universe, but if we consider universe moves at c relative to photon, then the length of universe would be 0 and hence photon can traverse the whole universe in no time.. which means Speed of light = Infinity :confused:
I know I am wrong but i don't know where i went wrong.. The above anomalies are the conclusions I am arriving at whenever i think of relativity... Please someone clear that for me...
how can time run slow and become infinity?time ceases at light speed. btw your equation is wrong
https://www.physicsforums.com/showthread.php?t=511170
Yup.
This is why photons (and anything else moving at c) do not have a valid reference frame.
One definition of a valid reference frame is that it is a frame in which you are at rest. Since, by definition, photons always move at c in any reference frame, then you have a reference frame in which photons are both stationary and moving at c.
So no, photons do not experience time. Photons do not experience anything at all (since experience requires the passage of time). It is no valid to try to think of a photon's frame of reference.
Sorry small correction, i was going to say Time runs slow for moving frame and becomes 0 when speed equals 'c'. Now the time becomes infinity for the stationary observer(relative to moving frame).. which means the observer cannot perceive the event at all... And again I am getting that SPeed of light = Infinity :confused:
And please tell me the correct equation for time dilation...
thanks in advance...
RiddlerA said:
t = t0/√(1-v2/c2)
Where did you get that equation from? Did it explain what t0 is or what t is?
RiddlerA said:
[..] Your(Moving non inertial frame) Time runs slow relative to a stationary observer when your speed increases and it will become infinity(as t = t0/√(1-v2/c2)) if speed v equals 'c' right?
[...correction added:] Time runs slow for moving frame and becomes 0 when speed equals 'c'. Now the time becomes infinity for the stationary observer(relative to moving frame).. which means the observer cannot perceive the event at all... And again I am getting that Speed of light = Infinity :confused:
He did no such thing. :wink:
Well that is quite correct, in a certain way: if an astronaut could travel near the speed of light, he/she would be able to the cross the universe in almost no time according to himself/herself. :tongue2:
Einstein formulated it as follows in 1905:
the velocity of light in our theory plays the part, physically, of an infinitely great velocity.
- see section 4 ("Physical Meaning of the Equations ..") of:
http://www.fourmilab.ch/etexts/einstein/specrel/www/
t = time duration for the desired frame of reference
to = time duration for the relative frame of reference
for example: if a rocket is moving with some speed, then 't' is the time duration for the rocket which we want to calculate and 'to' is the time duration for the stationary frame of reference from which we are observing the rocket...
What i meant was that einstein eliminated the thought of ether by introducing relativity...
Wow that gives me an idea.. photon can be converted to particle/anti-particle pair and vice versa right?.. So if we find a way to photonize(matter annihilation) ourselves then we can travel at light speed.. In the destination we again do the reverse process(pair production) to bring our former self :rofl:
And hence the mystery of Nightcrawler's teleportation is solved. Case Closed...:cool:
And btw thanks for the link.. that cleared lots of doubt... thank you very much..
I asked you where you got the equation from and you didn't say.
Are those explanations of t and to from the same place where you got the equation from or are you adding your interpretation?
Please note that your example does not follow your previous explanations of the two times and in fact is wrong because it will give you more time for the rocket instead of less time. That's why I'm trying to find out if it is your interpretation of the equation that is wrong or if was stated incorrectly in wherever it was you got the equation.
I got that equation from wikipedia.. See the Time dilation article in wikipedia...
Im totally confused... i guess i will have to learn it from the beginning once again..
And thank you very much for your time...
Here's the link to the article I found:
http://en.wikipedia.org/wiki/Time_dilation
I don't see your equation in there. If that is the same article you referred to, could you point out the section, paragraph, etc where it is? If not, could you provide the link to the article you found.
alexg said:
The equation is in section 2, Simple inference of time dilation due to relative velocity
http://en.wikipedia.org/wiki/Time_d...nce_of_time_dilation_due_to_relative_velocity
Are you talking about this equation:
It's not the same as t = t0/√(1-v2/c2) nor do I find these explanations in the text:
RiddlerA, please provide the link to where you got the equation and its explanation.
My first physics class in high school used Wilson/Buffa, and i remember them using those symbols in their time dilation equation as well. The way they had it, t0 represented a change in proper time for a "moving" observer (most of the problems involved a scenario where one person left Earth on a spaceship and returned after some time) and t represented a change in time for the stationary observer.
I also recall hating that textbook :tongue:.
[/PLAIN]
http://www.thebigview.com/spacetime/timedilation.html
How do you say that the equation from wikipedia and what i mentioned earlier are not the same? it looks the same to me...
RiddlerA said:
[/PLAIN]
by convention Δt is the measure of change in time and t is of time at an instant. when a moving clock S' reads t' and stationary S reads t then
t'=t[itex]\sqrt{1-V^{2}/C^{2}}[/itex](of course FoR is S)
If an event takes Δt in S it would appear to take longer when happens in S'(seen from S) hence if Δt' is the time taken in S'
Δt'=[itex]\frac{Δt}{\sqrt{1-V^{2}/C^{2}}}[/itex]
[/PLAIN]
Here's the equation from your link:
t' = t/√(1-v2/c2)
Well, all the equations have the form of a time on the left side of the equal sign and another form of a time on the right side of the equal sign divided by the square root of something that is less than one which means the time on the left side of the equal sign will be greater than the time on the right side of the equal sign. So the issue is: what do these two times represent?
In your first post, you had t on the left side of the equal sign but in your link, t is on the right side of the equal sign. You don't see this as a difference? This is why I asked you what the references you were looking at were explaining the different forms of t represent.
So now we have a big mess to clean up.
Let's start with the article in your link. This has to be one of the worst explanations of time dilation that I have ever seen. It is flat out wrong. Note the paragraph heading Time expands, space contracts. In order to show that time gets larger, they use this form of the equation were t' on the left side of the equation is larger than the t on the right side of the equation and they even show a plot with t' getting larger with velocity. And to explain it they reference the twin paradox where one twin travels for one year at 99%c. His age increase is represented by t and his Earth brother's age increase is calculated by t' as 7 years. What happened to the reciprocal nature of time dilation? Both brothers see the other one as aging less than them self but they don't mention that. What they do mention is:
This is due to the fact that time is stretched by factor 7 at approx. 99% of the speed of light, which means that in the space traveller’s reference frame, one year is equivalent to seven years on earth.
The truth is that in the space traveler's reference frame, one year is equivalent to 1/7th year on Earth and in the Earth reference frame, one year is 1/7th year for the traveler, or 7 years is 1 year for the traveler. Do you see the difference? They got it backwards. And yet they seem to realize that it's not quite right because just above the graph they say:
Time in the moving system will be observed by a stationary observer to be running slower by the factor t'
OK, now let's look at the wikipedia article. Their equation is:
Δt' = Δt/√(1-v2/c2)
This is identical to the one in the link you provided except that there are a couple of deltas in front of the t's and their explanation is:
which expresses the fact that for the moving observer the period of the clock is longer than in the frame of the clock itself.
This again is designed to show the dilation or expansion of time.
But now let's look at how Einstein explains time dilation. We'll look at Einstein's 1905 paper that harrylin linked to in post #6:
Look down near the end of section 4 where you see this equation:
τ = t√(1-v2/c2)
He explains this as t being the time on a clock at rest in a frame and τ (tau) being the time on a clock moving in that frame. It's so simple, but don't overlook the fact that the square root factor is multiplied, not divided, meaning the time dilation results in the moving clock running slower than the stationary clock. That's all there is to it. What ever speed any clock is moving at in a frame determines how much time dilation there is for that clock. If you switch to a frame where the moving clock is now at rest, the time dilation switches to the other clock.
So why is there so much confusion? It's because some people want to have the equation for time dilation be the reciprocal of the one of length contraction because time dilates and length contracts. But what they fail to realize is that it's the interval of time that gets longer resulting in the clock running slower which means it is displaying less time, not more and so we need to use the same form of the equation for both time dilation and length contraction. Look at your first post to see that you have the two equations different. Look at the Lorentz Transform and you will see that the form of the equation for time is identical to the form of the equation for distance with just the t and x interchanged.
That's right.
But this is not right. You should have left it the same way with no division. So if something takes Δt in S, it will take less time in S' (moving with respect to S).
Also, in Special Relativity, the term "event" has a specific meaning. It refers to an instant in time at a specific location. It shouldn't be used to refer to a duration or an interval of time. An event is the four coordinates making up a "point" in spacetime.
why not?what i meant is this (an example) consider A moving at 0.86c and B is stationary. Now B has to wait for 2 years in order to have A 1 year old but he himself ages 1 year in 1 year (of course B is FoR)
sorry about that!dint know
Because from A's rest frame, B is the one who ages slower.
yes... but i mentioned B is my FoR
t' = t/√(1-v2/c2)
Δt' = Δt/√(1-v2/c2)
τ = t√(1-v2/c2)
Thank you so much for your support..
So long story short, Time runs slower for a moving clock relative to a stationary clock?
Mass increases with velocity?
And length contracts as the speed increases relative to a stationary FoR?
Are the above statements correct?
Once again thank you very much for spending time to clear my doubt...:smile:
Now tell me whether or not it makes sense given the fact that a person at rest in S' ages slower when viewed from S.
Is this the twin paradox is all about? It is a hole in the special theory of relativity right?
I mean in reality Only one of them is going to age slower than the other, but if we interchange FoR then it shows that either of them have to age slower relative to each other, which doesn't make any sense...
i never denied a person at rest ages slowly when seen by a person in motion. i just took one of the 2 cases. may be i should have mentioned Δt' is the time taken for the event in S' according to the S clock.
Your equation should have looked like this: [itex]\Delta t' = \Delta t \sqrt{1-v^2/c^2}[/itex].
RiddlerA said:
I mean in reality Only one of them is going to age slower than the other,.
There is no "in reality"; that would imply a privileged point from which it can be viewed. There are only frames of reference.
The key is that, to decide which one is younger, one of them must turn around and go back to meet the other. And in doing so, this causes an asymmetry in the passage of their timelines. By the time they meet up again, they will both agree on who is younger.
RiddlerA, the way you defined the times...
... it means your formula is incorrect, like the other guys said. Your t is the proper time (which someone in the rocket measures), while your to is the coordinate time (which someone on Earth measures, the observer, "us").
I think it is important to get it right, because this way you can figure out what happens from the equation. The correct formula is this, as elfmotat wrote:
[itex]\Delta t_{o} = \Delta t \sqrt{1-v^2/c^2}[/itex], it's the same as [itex]\Delta t = \frac{\Delta t_{o}}{\sqrt{1-v^2/c^2}}[/itex], which you take from Wikipedia.
[itex]\Delta t = \Delta t_{o} \sqrt{1-v^2/c^2}[/itex], it's the same as [itex]\Delta t_{o} = \frac{\Delta t}{\sqrt{1-v^2/c^2}}[/itex], which you take from Wikipedia.
You may take a look at either and figure out what's going on, let's take a look at the former (just notice that the time notations are swapped compared to your equation, based on how you defined them):
So t is the time of the moving clock, to is the time of the static clock (ours). Now v is the speed of the moving clock, and we know it is lesser than c, both in respect to the observer. When v increases, then [itex]v^2/c^2[/itex] increases as well, which means [itex]1-v^2/c^2[/itex] decreases towards zero (also [itex]\sqrt{1-v^2/c^2}[/itex] decreases). You can see now how, as the speed of the t clock (in the rocket) is increased, its period has to be lesser, in its frame of reference, to synchronize its ticks to the observer's clock (on Earth, "us"). Imagine what happens if v is so great that [itex]\sqrt{1-v^2/c^2} = 0.8[/itex]: when the clock on the observer from Earth (to) rings "one hour" [1], the guy in the rocket says "hey, wtf, based on my clock (t), only 48 minutes has passed!" - which is 60*0.8.
The two equations are equivalent, the former is for use by the observer in the rocket to figure out what time the clock on Earth shows when an hour has passed (to = 0.8 * t = 48 minutes - contracted time), the latter is for use by the static observer to figure out what time the clock in the rocket shows (t = to / 0.8 = 75 minutes - dilated time).
Does this make intuitive sense? (I hope I haven't messed something up, that would confuse things even more :P)
[1] - this is the second tick, the first was when they started the stopwatches, synchronously.
no you don't get me. Consider this a stationary observer S and a moving observer S' having identical light clocks. Now let S measure the time Δt between 2 consecutive ticks of the clock in S. Now how does he see the same clock to tick in S' (time difference between 2 ticks in S' as seen from S)it is Δt'=[itex]\frac{Δt}{\sqrt{1-V^{2}/C^{2}}}[/itex]its also true for S'(as FoR and seeing S) i m just taking one of the case
A lot of you are just arguing semantics with which equation is right or wrong. They are right or wrong depending on how you define the variables. This is why you should specifically specify which variable is which so there is no confusion over how you use the formula.
  • #31
You have them reversed. t0 is proper time and t is coordinate time.
If you use my above definitions, then this is correct.
to should be the moving clock's time.
Correct so far.
This is incorrect. The way you had your equations the stationary clock would experience less time. Also, the two observers DO NOT synchronize their clocks - this is impossible.
The guy in the rocket would not experience time dilation in his rest frame. From his perspective, the guy on Earth's clock is running slower.
Neither of the clocks actually show these calculated times. The person in the rocket thinks the person on Earth's time is being dilated. The person in the rocket thinks the exact opposite.
You still don't have it right. It should be [itex]\Delta t' = \Delta t \sqrt{1-v^2/c^2}.[/itex]
  • #32
:rofl: not even close! It is essentially a famous homework problem for the one of the first few lectures in an introductory SR class. It is a useful problem because it challenges students to think about a few concepts that are difficult and a little unintuitive. It is not a hole in the theory.
However, it really isn't the topic of this thread, and there are numerous other threads on the twin paradox. So I wouldn't try to derail the current topic.
  • #33
Damn! You are right that my equations were wrong based on my notations, however I prefer to stick to mine (even if they don't respect established conventions or yours) in order to accommodate RiddlerA's definition:
I corrected the equations in my post.
RiddlerA;3698911t[SUB said:
o[/SUB] should be the moving clock's time.
Now it is ok, based on the notations I established. I insist on keeping his definition in order for RiddlerA to easier understand what's going on.
Let's say that is what the guy in the static reference frame sees it happening and imagines how the guy in the rocket would react, not necessarily that it actually happens, ignoring "contracted time" as well. Is that fine for you?
  • #34
an apparent misunderstanding between us. can you explain your stand?
  • #35
Alright:
No problems so far.
When viewed from S the clock at rest in S' should undergo time dilation, correct? So the clock in S' should age less than the one in S. Let's see whether or not this fact is reflected in your equation:
Snip3r said:
it is Δt'=[itex] \frac{Δt}{\sqrt{1-V^{2}/C^{2}}}[/itex]
This equation says that the clock in S' should age more than the clock in S. Based on what we just established this is clearly wrong. The correct equation would be [itex]\Delta t' = \Delta t \sqrt{1-v^2/c^2}[/itex].
