Prove Heisenberg Uncertainty Principle for Ground State Harmonic Oscillator
In summary, the conversation discussed the ground state wave equation and the Heisenberg Uncertainty Principle. The conversation centered around finding the expectation values for <x>, <p>, <x^2>, and <p^2> using the given wavefunction. The main difficulty was in finding <p^2>, as there was a mistake in the calculation due to a misunderstanding of the order of operations. After correcting the mistake, the correct value for <p^2> was obtained and used to show the Heisenberg Uncertainty Principle.
Sciencenerd3
Ground State Wave Equation:
ψ0=(a/∏)(1/4)e(-ax2/2)
Prove the Heisenberg Uncertainty principle ≥h(bar)/2 by way of expectation values.
First I found <x>=0 because it was an odd function
then I found <Px>=0 because it was an odd function
Then <x2>=∫(a/∏)(1/2)x2e(-ax2)/2dx=1/2a by way of even function integral table
The problem I am having difficulty on is finding <Px2>
It involves taking the double derivative and then integrating using a table (for me). I need to go through all of the derivatives and integrals I believe in order to get things to cancel so that only h/2 will be left over but I keep getting 0 for <Px2>
I have literally been trying to work this out for ≈4-5 hrs so any help anyone can offer would be extremely appreciated.
Here's a shortcut: H = p^2/2m + 1/2 m w^2 x^2, so <H> = (1/2m)<p^2> + (mw^2/2)<x^2>. You know <H> and <x^2>, so you can solve for <p^2>.
This seems as though it would work but I have to solve it in a specific way. My answer would be close if too many things were not cancelling but I cannot seem to work it out fully. After I integrate after taking the double derivative and keeping in mind to used the product rule, I am getting zero.
As far as I understand you simply are supposed to calculate [itex]\langle x \rangle[/itex], [itex]\langle p \rangle[/itex], [itex]\langle x^2 \rangle[/itex], [itex]\langle p^2 \rangle[/itex]. Since you've given the wavefunction in position space, you simply have to use the operators
[tex]\hat{x}=x, \quad \hat{p}=-\mathrm{i} \hbar \partial_x[/tex]
and use the general equation for expectation values
[tex]\langle A \rangle=\int_{\mathbb{R}} \mathrm{d} x \; \psi^*(x) \hat{A} \psi(x).[/tex]
Of course you must also check that the wave function is normalized properly, i.e., that
[tex]
\int_{\mathbb{R}} \mathrm{d} x \; |\psi(x)|^2=1.
[/tex]
Yes, the wavefunction is normalized because it is the ground state harmonic oscillator wavefunction. However, when I try to use the expectation value equation:
⟨A⟩=∫ℝdxψ∗(x)Aˆψ(x).
I get <P2>=h2(bar)/i2[-2a+2a]=0. However, I know that this value is not 0.
I am supposed to use the expectation equation and values to get Δx and Δp and show ΔxΔp≥h(bar)/2.
Uncertainty: Δx=√(<x2>-<x>2) but <x>=0. This is a similar result for Δp because <p>=0 as well.
Then after this you should be able to multiply both uncertainty values to get the Heisenberg uncertainty. But not matter what I do I can not get the expectation value of <p2> not to equal zero. And I also get <x2>=1/2a.
Is there anyone who can run through the expectation of momentum squared. It involves taking the double derivative and then integrating over allspace for the given wavefunction:
[itex] \psi_0=(\frac{\alpha}{\pi})^\frac{1}{4}e^{-\frac{\alpha x^2}{2}}[/itex]
So using the expectation equation:
[itex]<p^2>=∫\psi_0^*\hat{p}\hat{p}\psi_0dx[/itex]
[itex] <p^2>=∫\psi_0^*\frac{\hbar^2}{i^2}\frac{∂^2}{∂x^2}\psi_0dx[/itex]
[itex] <p^2>=∫\frac{\hbar^2}{i^2}\frac{∂^2}{∂x^2}(\frac{ \alpha}{\pi})^\frac{1}{2}e^{-\alpha x^2}[/itex]
[itex]\frac{∂^2}{∂x^2}(\frac{ \alpha}{\pi})^\frac{1}{2}e^{-\alpha x^2}=\frac{∂}{∂x}((\frac{ \alpha}{\pi})^\frac{1}{2}\cdot-2\alpha xe^{-\alpha x^2})=(\frac{ \alpha}{\pi})^\frac{1}{2}\cdot-2\alpha e^{-\alpha x^2}+(\frac{ \alpha}{\pi})^\frac{1}{2}\cdot4\alpha^2x^2 e^{-\alpha x^2}[/itex]
[itex] \int_{-∞}^∞e^{-\alpha x^2}=(\frac{\pi}{\alpha})^{\frac{1}{2}}[/itex]
[itex] 2\cdot\int_0^∞x^2e^{-\alpha x^2}=(\frac{\pi}{\alpha})^{\frac{1}{2}}\cdot\frac{2}{4\alpha}[/itex]
So putting these values in for the integrals, I get:
[itex]<p^2>=\int_{-∞}^∞[(\frac{ \alpha}{\pi})^\frac{1}{2}\cdot-2\alpha e^{-\alpha x^2}+(\frac{ \alpha}{\pi})^\frac{1}{2}\cdot4\alpha^2x^2 e^{-\alpha x^2}]=\frac{\hbar^2}{i^2}[-2\alpha+2\alpha]=0[/itex]
I cannot figure out if I'm doing the derivatives wrong or the integrals or neither. Maybe my values from the integral tables were figured incorrectly. Whatever it is, it has evaded my solving for a long time now.
Could it be that I am acting on both wave functions multiplied together with the momentum operator instead of just the second wave function in the expectation equation?
Here's the wrong step
The first equation is OK, but then you move ψ* from the left of the differential operator to the right, such that ∂x² is no longer acting on ψ but on |ψ|².
But
[tex] \int_{-\infty}^{+\infty}dx\, \psi^\ast \frac{\partial^2}{\partial x^2} \psi \neq \int_{-\infty}^{+\infty}dx\, \frac{\partial^2}{\partial x^2} |\psi|^2 [/tex]
This integral is zero (trvially) b/c
[tex] \int_{-\infty}^{+\infty}dx\, \frac{\partial^2}{\partial x^2} |\psi|^2 = \left. \frac{\partial}{\partial x} |\psi|^2\right|_{-\infty}^{+\infty} = 0[/tex]
which vanishes due to the asymptotics of ψ.
What you can do is
[tex] \int_{-\infty}^{+\infty}dx\, \psi^\ast \frac{\partial^2}{\partial x^2} \psi = - \int_{-\infty}^{+\infty}dx\, \left( \frac{\partial}{\partial x} \psi^\ast\right) \left( \frac{\partial}{\partial x} \psi\right) = \int_{-\infty}^{+\infty}dx\, \left( \frac{\partial}{\partial x} \psi\right)^2 [/tex]
where I first used integration by parts (which is always OK for wave functions vanishing at infinity) and then ψ* = ψ (which holds only in special cases).
That's your problem... ##\partial^2 / \partial x^2## applies only to ##\psi_0##, not to ##\psi_0^*##:
$$\langle p^2 \rangle = \int {(\psi_0^*) \left( -\hbar^2 \frac{\partial^2 \psi_0}{\partial x^2} \right) dx}$$
(I see tom.stoer beat me to it while I was debugging my LaTeX.)
Thanks so much. i cannot believe I wasted so much time on something so simple and trivial like forgetting order of operations. I'm new to the forum, is there any specific way I am supposed to give thanks or credit?
We'll consider it given. At least I will... maybe Tom will have a special request like a bottle of beer or something. :smile:
in such cases a bottle of whisky would be appropriate
1. What is the Heisenberg Uncertainty Principle?
The Heisenberg Uncertainty Principle is a fundamental principle in quantum mechanics that states that it is impossible to know both the position and momentum of a particle with absolute certainty. This means that the more precisely we know the position of a particle, the less we know about its momentum and vice versa.
2. How is the Heisenberg Uncertainty Principle related to the Ground State Harmonic Oscillator?
The Ground State Harmonic Oscillator is a simple quantum mechanical system that consists of a particle oscillating back and forth in a potential well. This system is often used to illustrate the Heisenberg Uncertainty Principle because it has a well-defined ground state energy and position, making it easy to calculate the uncertainties in position and momentum.
3. What is the mathematical expression for the Heisenberg Uncertainty Principle?
The Heisenberg Uncertainty Principle can be expressed mathematically as ΔxΔp ≥ ħ/2, where Δx is the uncertainty in position, Δp is the uncertainty in momentum, and ħ is the reduced Planck's constant.
4. How do we prove the Heisenberg Uncertainty Principle for the Ground State Harmonic Oscillator?
To prove the Heisenberg Uncertainty Principle for the Ground State Harmonic Oscillator, we use the Schrödinger equation to calculate the uncertainties in position and momentum for the ground state. We then substitute these values into the mathematical expression for the uncertainty principle and show that it holds true.
5. Why is the Heisenberg Uncertainty Principle important?
The Heisenberg Uncertainty Principle is important because it sets a fundamental limit on the precision with which we can measure certain properties of a particle. It also highlights the inherently probabilistic nature of quantum mechanics and challenges our classical understanding of the world. It has also led to many important developments in fields such as quantum computing and quantum cryptography.
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
