Vacuum and non-vacuum regions, dust and fluids
In summary: Thus, realistically, the percentage of vacuum in the inside of an average star is constantly changing depending on the scale being considered.In summary, the conversation discusses the distinction between vacuum and non-vacuum regions in GR, and the role of the Ricci and Weyl tensors in handling these regions. It also touches on the idea of working with reasonable approximations and using averaged quantities, as well as the definitions of "dust" and "fluid" in this context. The percentage of vacuum in the inside of an average star is constantly changing depending on the scale being considered.
Passionflower
1,543
In GR there is made a clear distinction between a vacuum region and a non-vacuum region as one is handled by the Ricci tensor and the other by the Weyl tensor.
But is reality so black and white? And when do we realistically talk about dust and when about fluid?
So the inside of an average star, what is the percentage of vacuum?
In a vacuum region the Ricci tensor is zero and the Weyl tensor is nonzero. In nonvacuum, both Ricci and Weyl tensors are nonzero.
We work in reasonable approximations, and often pretend that matter is continuous, not made up of atoms in random motion. We then make use of averaged quantities, including an averaged Ricci tensor.
"Dust" refers to matter in which the pressure is negligible compared to the energy density.
What percentage of the air in your room is vacuum? The answer depends on how fine a scale you're interested in. You can count the space between atoms as vacuum. Or you can even say that the interior of each atom is mostly vacuum.
1. What is vacuum and how does it differ from non-vacuum regions?
Vacuum refers to a space that is completely devoid of matter, including air and other gases. Non-vacuum regions, on the other hand, contain some amount of matter. The main difference between vacuum and non-vacuum regions is the presence or absence of matter.
2. How is dust different from fluids in terms of their behavior in a vacuum?
Dust and fluids have very different behavior in a vacuum. Dust particles are usually solid and have a tendency to settle to the bottom due to gravity. Fluids, on the other hand, can flow freely in a vacuum due to their fluid nature and lack of resistance from air molecules.
3. What are some common examples of vacuum regions in our everyday lives?
Vacuum can be found in various forms in our everyday lives. Some common examples include space, the inside of a vacuum cleaner, and the inside of a sealed container from which all air has been removed.
4. How does dust affect the performance of vacuum technology?
Dust can have a significant impact on the performance of vacuum technology. It can clog filters and reduce the suction power of a vacuum, making it less effective. Dust can also cause wear and tear on the moving parts of a vacuum, leading to decreased efficiency and potential breakdowns.
5. Can fluids exist in vacuum regions?
Yes, fluids can exist in vacuum regions. In fact, fluids in a vacuum can behave differently than they do in non-vacuum regions due to the absence of air molecules. For example, water can boil at a lower temperature in a vacuum due to the reduced atmospheric pressure.
  • Classical Physics
