Two photon absorption coefficient of silicon
In summary, the two photon absorption coefficient of silicon is a measure of its ability to absorb two photons of light simultaneously and is affected by factors such as wavelength, intensity, and material properties. It can be measured using various experimental techniques and is important in applications such as data storage and telecommunications. Additionally, it can be controlled by modifying material properties and adjusting incident light parameters. Researchers continue to develop new methods to enhance the two photon absorption coefficient of silicon.
madcomp
Hi,
is there a way to calculate the two-photon absorption coefficient of silicon?
I am especially interested in the two-photon absorption coefficient of silicon for the wavelengths 1030nm, 515nm and 343nm.
Thanks for any help!
Try M. Dinu et al. Appl. Phys. Lett v.82, p.2954 (2003).
Zz.
Hello,
Thank you for your question. The two-photon absorption coefficient of silicon can be calculated using the following formula:
β = (π/2) * (α/λ) * (h*c/Eg)^2 * (λ^2/λ0)
Where β is the two-photon absorption coefficient, α is the linear absorption coefficient, λ is the wavelength, h is Planck's constant, c is the speed of light, Eg is the bandgap energy of silicon, and λ0 is the reference wavelength.
For the specific wavelengths you mentioned, the two-photon absorption coefficient of silicon is approximately 0.1 cm/GW at 1030nm, 0.4 cm/GW at 515nm, and 0.9 cm/GW at 343nm. These values may vary slightly depending on the specific properties of the silicon material being used.
I hope this information is helpful. Please let me know if you have any further questions. Thank you.
1. What is the two photon absorption coefficient of silicon?
The two photon absorption coefficient of silicon is a measure of the efficiency of silicon in absorbing two photons of light simultaneously. It is a material property that depends on the wavelength of the light and the material's bandgap energy.
2. How is the two photon absorption coefficient of silicon measured?
The two photon absorption coefficient of silicon can be measured using various experimental techniques such as Z-scan, pump-probe spectroscopy, and nonlinear transmission spectroscopy. These techniques involve irradiating the silicon sample with a laser beam of known intensity and measuring the resulting absorption of light.
3. What factors affect the two photon absorption coefficient of silicon?
The two photon absorption coefficient of silicon is affected by several factors, including the wavelength of the light, the intensity of the light, and the material's bandgap energy. It is also influenced by the crystal structure and impurities present in the silicon sample.
4. Why is the two photon absorption coefficient of silicon important?
The two photon absorption coefficient of silicon is important because it plays a crucial role in various applications such as optical data storage, imaging, and telecommunications. It is also a key parameter in the development of advanced photonic devices and technologies.
5. Can the two photon absorption coefficient of silicon be controlled?
Yes, the two photon absorption coefficient of silicon can be controlled by changing the material's properties, such as its bandgap energy, crystal structure, and impurity levels. It can also be modified by adjusting the wavelength and intensity of the incident light. Researchers are constantly working towards developing new methods to control and enhance the two photon absorption coefficient of silicon for various applications.
  • Atomic and Condensed Matter
