Electron traveling parallel to a Uniform Electric Field
In summary: Thank you for pointing that out, and for the alternative method. In summary, an electron with an initial speed of 2.0E7 m/s will travel a distance of -6.97785E-2 m before stopping when traveling parallel to a uniform electric field of magnitude 1.18E4 N/C. The time it takes for the electron to return to its starting point can be calculated using the formula Δx = -mv2/(2eE), where e is the elementary charge and m is the mass of the electron.
format1998
An electron with speed 2.0E7 m/s is traveling parallel to a uniform electric field of magnitude 1.18E4 N/C. How far will the electron travel before it stops? How much time will elapse before it returns to its starting point
q = 1.60E-19 C
mass of electron = 9.11E-31 kg
velocity (initial) = 2.10E7 m/s
velocity(final) = 0 (zero)
Electric Field
E=F/q --> F=qE
Acceleration / Force equation
a=F/m
Constant Acceleration
v(final)^2=v(initial)^2 +2a*(delta x) --> delta x = (v(final)^2 - v(initial)^2) / 2a
F=qE = (1.60E-19 C)(1.8E4 N/C) = 2.88E-15N
a=F/m = (2.88E-15N) / (9.11E-31 kg) = 3.16E15 m/s^2
delta x = (0 - 2.10E7 m/s) / 2*(3.16E15 m/s^2)
delta x = -6.97785E-2 m <--- ACCORDING TO MASTERING PHYSICS THIS ANSWER IS WRONG!
with the 2nd part of the question... I was going to use the equation
delta x = 1/2[v(initial) + v(final)]*t
but since my delta x is wrong, i haven't quite started this part...
Any and all help will be appreciated! Thank you in advance!
Welcome to PF,
It looks like you might have slipped up on your arithmetic. The given electric field is 1.18e4 N/C, but you have used 1.8e4 N/C.
By the way, the first part of this question is much easier to solve using conservation of energy. For a uniform electric field, the potential difference between two points is just the electric field strength multiplied by the distance between the two points (V = E*Δx). And the potential energy change for the electron is just the electron charge multiplied by the potential difference. Finally, since the electric force is a conservative force, all of the initial kinetic energy of the electron is converted into electric potential energy (as the electric force does negative work on it to slow it). So you just equate the kinetic and potential energies and solve for Δx.
You'll end up with:
-e*V = (1/2)mv2
where e = 1.60e-19 C is the elementary charge, the smallest unit of charge found in nature (e is the charge of a proton, and -e is the charge of an electron).
-2eEΔx = mv2
Δx = -mv2/(2eE)
Notice that this is just the same formula as the one you obtained using kinematics, since a = F/m = eE/m. However, with this method you arrive at it more quickly. Also, written in this way, it allows you to just plug in all of the given quantities without having to take the intermediate step of computing a.
Hmmm... Hahahaha! One digit causing so much trouble. Thank you so much. Your help is much appreciated...
1. How does an electron behave when traveling parallel to a uniform electric field?
When an electron travels parallel to a uniform electric field, it experiences a force in the same direction as the field. This force causes the electron to accelerate, increasing its velocity and kinetic energy.
2. What factors determine the acceleration of an electron in a uniform electric field?
The acceleration of an electron in a uniform electric field is determined by the strength of the electric field, the charge of the electron, and the mass of the electron. The larger the electric field, the greater the acceleration of the electron.
3. Can an electron travel at a constant velocity in a uniform electric field?
No, an electron cannot travel at a constant velocity in a uniform electric field. Since the electron experiences a constant force from the electric field, it will continue to accelerate and increase its velocity until it reaches a terminal velocity.
4. How does the direction of the electric field affect the motion of an electron?
The direction of the electric field determines the direction of the force on an electron. If the electric field is parallel to the motion of the electron, it will accelerate in the same direction. If the electric field is opposite to the motion of the electron, it will decelerate.
5. What is the relationship between the distance traveled by an electron and the strength of the electric field?
The distance traveled by an electron in a uniform electric field is directly proportional to the strength of the electric field. This means that a stronger electric field will cause the electron to travel a greater distance in the same amount of time compared to a weaker electric field.
