Help please -- Li saturation absorption spectroscopy
In summary, the graduate student is working on building a new machine with Li6 as one of the components. In order to cool the Li6, they need to perform saturation absorption spectroscopy on a separate stand-alone cell to determine the necessary laser frequencies. The cell is heated to 350-400 centigrade using fiberglass heater tape, and has a background pressure of 10 mTorr to prevent adsorption of Li on the windows. Despite the melting point of Li being 180 centigrade, the Li remains solid even at temperatures of 400-500 centigrade, which is mentioned in the literature as a method to "break oxidation". The student is seeking ideas on why the Li is not melting at these high temperatures
gol3tron
Dear PF,
I'm a graduate student working in an ultracold atomic phys lab. We're trying to build a new machine with Li6 as one of the components, but in order to cool it we need to do saturation absorption spectroscopy on a separate stand-alone cell in order to tell our lasers what frequencies they need to be.
To get a high enough vapor density of atoms we have to heat the lithium to about 350 - 400 centigrade, so we put the lithium inside of a stainless steel tube (solid Li chunk just sits on the inside of the tube) with windows on each end (for optical access) and heat the tube with fiberglass heater tape. The thermocouple that gives us out temperature reading is just sitting underneath the tape (on the outside of the cell), which gives us a measurement of the temperature between the tape and the cell.
Note that Li has a melting point of about 180 centigrade. Additionally, the cell has a background pressure of about 10 mTorr (Argon) to prevent adsorption of the Li on the cell windows.
Here's my question:
A few months ago I turned the heater tape up to about 400 centigrade, but the Li remained solid! In fact, the shape of the chunk doesn't appear to change at all! Why doesn't it melt? Shouldnt the temperature of the inside of the cell (at least the surface) be the same as the outside of the cell?
The literature mentions that some groups initially bake their lithium up to 500 degrees to "break oxidation", but even at those temperatures the Li didnt appear to melt either!
Any ideas would be appreciated.
Thanks!
Adam
Ihave the same question
1. What is Li saturation absorption spectroscopy?
Li saturation absorption spectroscopy is a technique used in scientific research to study the absorption properties of lithium atoms. It involves shining a laser through a sample containing lithium atoms and measuring the amount of light that is absorbed at different laser intensities.
2. How does Li saturation absorption spectroscopy work?
In Li saturation absorption spectroscopy, a laser beam is directed through a sample containing lithium atoms. The laser intensity is gradually increased until the absorption of the light reaches a maximum. This maximum absorption is known as the saturation point and can be used to determine important properties of the lithium atoms, such as their density and energy levels.
3. What are the applications of Li saturation absorption spectroscopy?
Li saturation absorption spectroscopy has a wide range of applications in various fields of science, including atomic and molecular physics, chemical analysis, and laser cooling and trapping. It is also used in the study of fundamental physical constants and in the development of new technologies such as atomic clocks and quantum computing.
4. How is Li saturation absorption spectroscopy different from other spectroscopy techniques?
Li saturation absorption spectroscopy differs from other spectroscopy techniques in that it specifically targets and studies the absorption properties of lithium atoms. It also has a higher sensitivity and precision compared to other techniques, making it a valuable tool for research in atomic and molecular physics.
5. What are the advantages of using Li saturation absorption spectroscopy?
One of the main advantages of Li saturation absorption spectroscopy is its high sensitivity, which allows for the detection of small changes in the absorption properties of lithium atoms. It is also a non-destructive technique, meaning the sample can be reused for further experiments. Additionally, it is relatively simple and cost-effective compared to other spectroscopy techniques.
