| Thread Closed |
Assumed violation of physics - Heat vs. Work |
Share Thread | Thread Tools |
| Jan28-13, 02:31 PM | #69 |
Good evening Dale,
One matter absent from your analysis is the small matter of heat transfer efficiency into and out of the reservoirs. Your perfect machine analysis is silent in this respect. |
| Jan28-13, 02:43 PM | #70 |
Mentor
Hi Studiot, I believe that you are talking about the rate of transfer to the reservoir, not efficiency. Correct? The transfer is passive, so it doesn't use or generate work, so I don't see where efficiency would come in.
| Jan28-13, 03:23 PM | #71 |
No I'm not talking about rate of transfer.
Let us say you want to use the heat pump to heat a room, obtaining the heat from the outside atmosphere ( a pretty typical practical application). 1)In order to extract heat from the air to your working fluid you have to pass the air over some sort of heat exhanger. Probably you require to expend energy in a fan. 2)Having picked up the heat, you have to pump your working fluid around in heat pump and perform the compression and expansion cycles. 3)You now know what I'm going to say. Having pumped your hot fluid into the room you need a second heat exchanger/fan to remove and distribute the heat. I was intending to come round to explaining that the manufacturers only quote the the COP of the heat exchanger using (2) as the work budget. This makes advertising headlines but poor engineering. |
| Jan28-13, 03:49 PM | #72 |
Mentor
Well, all that does is reduce the real efficiency further from the ideal efficiency. Since even an ideal heat engine and heat pump could not gain energy this way, what you mention is just one more way for a real system to perform even worse. Worse than 0 is pretty bad. |
| Jan28-13, 04:10 PM | #73 |
Are you guys discussing heat pumps from the 80's?
I can buy a heat pump with COP of 6.6 @ +7 degrees C when I want to keep an indoor temperature at 20 degrees C. While it is freezing cold outside, -15 degrees C, the COP is 4.3. The heat pump is said to deliver decent heat, when it is -30 degrees C outside, but the factory guarantee down to -25. It is a Mitsubishi Electric heat pump I have been reading about. Vidar |
| Jan28-13, 05:10 PM | #74 |
Mentor
We are giving the idea the complete "benefit of the doubt" and talking about using theoretically perfect heat pumps. And even then it takes all of the work from the ideal heat engine to run the ideal heat pump. |
| Jan28-13, 06:05 PM | #75 |
As I said before, your using Carnot efficiency on a scale of absolute zero. Its nonsensical. We are talking about an engine running on ambient heat. "Free" heat all around us in the air. A virtually unlimited supply that is renewed on a daily basis by the sun and will never run out until the sun itself burns out. Lets take a "real world" example. Not really "REAL" just using real numbers in a hypothetical situation. Lets say I build an experimental engine that runs on hot air and it works. I set up hot air solar panels to help concentrate the heat for the engine. I even set up a heat pump along with the solar panels to add more heat on cloudy days. The engine takes off. It draws in hot air and blows out cold air and generates electricity. I even set up duct work to use the cold air from the engine to air condition my house. Day after day goes by and it keeps running day and night. I notice that the heat pump is redundant as it never goes on. It wasn't needed. I'm sitting pretty. All the free energy I can use. One day the wind blows my solar collector over. I didn't even notice because the engine kept running just the same without it. Still producing electricity. But now the air conditioning is way too cold. Earlier I measured the heat in the solar panels at an average of 200 degrees Fahrenheit. The engine was always utilizing 100% of all the heat the solar panels could produce and sometimes then some. Exhausting cold air into the house at a comfortable 60 degree Fahrenheit, even on balmy summer days. Now with the solar panels destroyed I take new measurements. The engine is now drawing in 60 degree Fahrenheit ambient air directly. I'm shocked to see that the exhaust is now negative 30 degrees Fahrenheit. Thirty degrees below zero! No wonder the house was getting so damn cold. What is the theoretical "Carnot Efficiency" of this little miracle engine ? Unfortunately, I know, the thing didn't cool the air all the way down to absolute zero and the whole apparatus didn't disappear reducing itself to a single Bose-Einstein Condensate particle in the process so it can't be 100% efficient at removing every last drop of heat so that the exhaust air was colder than the dark side of the moon or deep interstellar space. I'm a little fuzzy on the math and the conversion between Fahrenheit and Kelvin and all that technical stuff. Based on the data. The "Th" and "Tc". all that complicated math stuff that's all Greek to me anyway. What's the Carnot efficiency of this engine before and after the destruction of my solar collector ? |
| Jan28-13, 06:37 PM | #76 |
Mentor
| Jan28-13, 06:43 PM | #77 |
| Jan28-13, 06:53 PM | #78 |
An air to water system produces water at a stated temp and COP. What you do with it is then your business. Further comments. To transfer heat from the ouside air to the heat pump fluid requires the cold reservoir in the heat exchanger to be be colder than the outside air. To produce warm air at 20°C require the hot reservoir in the indoor heat exchanger to be warmer than 20°C Thus neither of these figures can be used for COP calculations. When making comparisons it should be noted in most cases the work input is performed by electricity. This is more expensive per joule than some other forms of heating. So the heat output that derived from the work input will be at higher cost. |
| Jan28-13, 07:36 PM | #79 |
Carnot efficiency does not describe practical utilization of the supplied heat, it describes how much of all the heat. ALL of it. That means if you are talking about a hot air engine running on heat in the air, the engine has to cool the air to absolute zero to be 100% "efficient". The engine could be working great making all the energy anyone could ever need but the Carnot efficiency numbers would make it look like a dog. A waste of time. |
| Jan28-13, 07:56 PM | #80 |
It is not too unlike this little combined heat engine and cooling system, just scaled up a bit. Different kind of heat engine. Different kind of cooling method.
There is no temperature difference until the engine is started, afterwards it maintains its own temperature difference. This little bird is a heat engine running on ambient heat and evaporative cooling. Evaporative cooling is also driven by ambient heat. So energy from ambient heat in the air is being utilized to produce both energy output and supply cooling. Until the engine starts, everything is the same temperature. http://www.youtube.com/watch?v=Rq3K6Ma0wIU This is a little different, yet similar. http://www.youtube.com/watch?v=ARD3ctp80ac Still running on ambient heat and simple evaporative cooling from a damp piece of paper. |
| Jan28-13, 08:17 PM | #81 |
Mentor
A device that uses a heat pump to create a temperature difference to drive a heat engine, achieving a positive energy output is a violation of the 2nd law of thermodynamics: a type 2 perpetual motion machine. We don't do perpetual motion machines here. Thread locked.
| Thread Closed |
| Thread Tools | |
Similar Threads for: Assumed violation of physics - Heat vs. Work
| Thread | Forum | Replies | ||
| finding work, heat, and entropy in a heat engine | Introductory Physics Homework | 2 | ||
| Finding work done, heat in, and heat out over a reversible thermodynamic cycle | Introductory Physics Homework | 3 | ||
| thermal physics: work and heat | Biology, Chemistry & Other Homework | 1 | ||
| thermal physics: work and heat | Advanced Physics Homework | 2 | ||
| physics- work and heat | Introductory Physics Homework | 0 | ||
