thavamaran
- 42
Hi guys, this is my first work in optical and first simulation in matlab. I am sorry if there is mistake and I am really new to this.
Here is what I did, I am simulation an entire Radio Over Fiber system with Matlab, linear system.
Let me insert my code first,
%*****************************Defining constant parameter****************
%Rb = 1e+6; %bit rate
%Tb = 1/Rb; %bit duration / period
Num_bits = 1e4; %number of bits
nsamp = 20; %samples per symbols
%Tsamp = Tb/nsamp; %sampling rate, fsamp = 20MHz.
a = 0.2; %channel attenuation, dB/km
L = 20; % Length of fiber
Gain = 10; %Gain in dB
%*****************************Filter definations************************
snr_dB=0:20; %SNR in dB from 0 to 20
SNR=10.^(snr_dB./10); %SNR in linear scale
Tx_filter = ones(1,nsamp); %transmitter filter, in terms of
% h(t),match filter
Rx_filter = fliplr(Tx_filter/nsamp); % receiver filter (matched filter),
% flip from left to right to make
% it h(T-t), match filter
Tx_OOK = randint(1,Num_bits); % randomly generating 1 and 0 in a
% row of matrix for 1000
% column,basically ON-OFF keying
% with random bits
%*****************************Channel input*****************************
Tx_OOKin = 0+Tx_OOK; % Tx+with power, 0dBm,ideal.
%*****************************Channel properties************************
Txch = Tx_OOKin -(a*L); %Signal in channel, deducting with
%channel attenuation=4dB
Txout = 10.^(Txch./10); %Changing back the signal to linear
%scale
Tx_signal = rectpulse(Txout,nsamp); % generate rectpulse for nsamp time
% per symbol
%*****************************Receiver**********************************
for i=1:length(snr_dB)
Rx_signal = awgn(Tx_signal,snr_dB(i)+3-10*log10(nsamp),'measured');
%*****************************Match filtering***************************
MF_out = conv(Rx_signal,Rx_filter); %equivalent to y(t)=x(t)*h(t)
MF_out_downsamp = MF_out(nsamp:nsamp:end); %sampling and hold
%try without truncation
%*****************************Thresholding*******************************
Rxth = zeros(1,Num_bits); %Reset receiver before thresholding
Rxth(find(MF_out_downsamp>0.45))=1; %value above 0.45 equivalent to one
%at the receiver, thresholding.
%*****************************BER CALC**********************************
ber(i) = biterr(Tx_OOK,Rxth); %Matlab function for ber
%******************Theoritical BER CALC**********************************
ber_pr(i) = Qfunct(sqrt(SNR(i))); %theoritical for ber
end
figure;
semilogy(snr_dB,ber,'b'); %Simulation
hold on;
semilogy(snr_dB,ber_pr,'r');
xlabel('SNR(dB)');
ylabel('BER');[/CODE]
Above is my entire code, the part i bold, i dun really get the idea, i took it from my friend cause at the receiver part, i don't really have an idea of how to receive the signal for at least with 10 different SNR rate and plot BER. My friend used the Match filter, but i don't really have the exact idea how match filter works.
The Tx_filter and Rx_filter part i got it where we flip the entire input from transmitter and at the receiver. which is h(t) from transmitter becomes h(-t).
I have uploaded the output and the blue line on the plot is the output that i got
Code:
% h(t),match filter
% with random bits
%scale
% per symbol
end
figure;
hold on;
xlabel('SNR(dB)');
