New Reply
Difference between corelation function and corelation lenght
Share Thread Thread Tools
Aug14-12, 05:54 AM   #1
For example if we look Ising model correlation function is
[tex]\langle S_iS_{i+j}\rangle[/tex]
So we can see that if we took into acount just nearest neighbours interraction we also will see that some [tex]i+j[/tex]-th spin feels i-th spin. So there is some correlation between them.
Am I right? This is correlation function. And what is correlation lenght?
Is it lenght between
[itex]\uparrow\uparrow\uparrow\uparrow\downarrow\downarrow[/itex]
the biggest number of align spins?
PhysOrg.com
PhysOrg
physics news on PhysOrg.com
>> Promising doped zirconia
>> Nanocrystals grow from liquid interface
>> New insights into how materials transfer heat could lead to improved electronics
Aug14-12, 10:38 AM   #2
If I watch some spin system, for example Ising model or something, what is for me there correlation lenght? Can you explain this to me?
Aug15-12, 09:13 AM   #3
Recognitions:
I'm not sure if the usage in condensed matter is the same, but usually the correlation function is more general. When the correlation function is exponential, exp(-x/L), then L is the correlation length. If the correlation function is a power law, x^n, then the correlation length is not defined (or "infinite", eg. http://www-thphys.physics.ox.ac.uk/p...18_Harvard.pdf says "power-law phase with infinite correlation length").
Aug16-12, 02:40 AM   #4
Yes, I think it's the same. Just in condensed matter I have maybe
[tex]\Gamma=exp(-\frac{an}{L})[/tex]
where [tex]a[/tex] is distance between nearest neighbours. I don't understand very well that if I see phase transition in some point then correlation lenght there is pretty large. So [tex]\Gamma[/tex] goes to zero. Right?
And where I can have polynomial dependence? In ordered phase. Can someone explain me that?
Aug16-12, 11:38 AM   #5
Recognitions:
Quote by LagrangeEuler View Post
The divergence of the correlation length only occurs at some phase transitions, eg. at the critical point , which is where the boundary between liquid and gas disappears. Kardar has some notes on this. He writes the correlation function as a power law multiplying an exponential (Eq II.46). The correlation function is approximately a power law only for distances less than the correlation length (Eq II.49). As the critical point is approached, the correlation length diverges, and so the correlation function is close to a power law over very large distances (see his comments before Eq II.52).
http://ocw.mit.edu/courses/physics/8...notes/lec2.pdf
http://ocw.mit.edu/courses/physics/8...notes/lec3.pdf
http://ocw.mit.edu/courses/physics/8...notes/lec4.pdf
New Reply
Thread Tools
Similar Threads for: Difference between corelation function and corelation lenght
Thread Forum Replies
Corelation function Atomic, Solid State, Comp. Physics 3
In Dimensional analysis why is Lenght/Lenght=1 (a dimensionless number)? General Physics 58
Difference between Scalar Function and Vector Function? Calculus 4
Corelation betwen the geometric properties of the potential energy and the density of Quantum Physics 0
