Why does the moon appear larger at the horizon?
In summary: I'd have to say it's because of perspective.The increased size of the moon comes purely from illusion of perspective.
acesuv
63
I've heard two hypothesis:
1. The air causes the image of the moon to literally appear larger
2. The increased size of the moon comes purely from illusion of perspective
Which one is it?
Try it by comparing it to an object for reference. (a ruler perhaps)
So #1 is definitely wrong? :uhh:
That's why it's called the moon illusion. It is an incredibly compelling illusion, even for those who know that it's all in our heads.
Pick a camera, make one picture at the horizon and one when the moon is high in the sky (with the same camera settings of course), and compare.
The moon is nearly full now.
A good comparison object is a coin. I think you will find that a 2p coin held at arms length covers the moon wherever it is in the sky.(it also covers the sun but I would not recommend looking directly towards the sun)
acesuv, just FYI, had you typed the subject line of this thread into Google you would have gotten the same information as give here. Try to remember that Google is your friend.
Your brain's perceptual framework changes depending on the situation, but you do not recognise the vague area where the two methods of assessment blend and cross over. It is an illusion.
When seen near the horizon your estimate of the moon's size is assessed by comparing the angular diameter of the moon with the angular separation between the moon and the horizon.
size(low) = moon / gap.
When far from the horizon your estimate of the moon's size is based on the area of the moon compared with the area of the sky.
size(high) = moon^2 / sky^2.
Since: size(low)^2 = size(high), the dimensions of size are different and so cannot be honestly compared.
Which one is it?
No. 3. The increased size of the moon is real. Right now the moon appears largest because it is at its closest distance from to the earth. It is 14% larger and 30% brighter than at the apogee.
AM
Well, that is not related to its apparent position in the sky.
The best explanation I have seen is that you are mentally judging the moon's size by comparing its apparent size to its apparent distance - and your visual estimate of its distance is different when veiwed low to the horizon vs high in the sky.
We "stick" the moon onto the sky canopy, which appears relatively low above us, but extends way off in the distance to the horizon.
The way we actually "see" to sky is like a low flat barrier - as if the highest point of the sky was only a few miles above us and curves very slightly down to the horizon many miles far away. The problem is that we know and see a flat horizon as being about 7 miles away, and anything with elevation (like the rising/setting moon) is going to look like it is about 10 miles or so away.
The result is that the sky canopy itself looks extremely close above us and quite far away at the horizon. You notice this very strongly on an overcast day where you can see the choud patterns showing this. When the moon is up high in the sky, it looks like it is about three miles away, and we make the visual judgement that it must be pretty big to subtend that angle at that distance... when we see it low on the horizon, it looks like it is about 10 or so miles away, and we make the visual judgment that it must be larger to look that size at that distance.
Human visual judgment is really 'poor' and subject to circumstances. Take a ladder. Lay it on the ground and look at it. Then lean it up against a wall and look at it. Then climb to the top and look down along it. You will perceive three very different lengths.
One big breakthrough, in Science, was when they decided to measure things, rather than just to look at them.
I had just been out for a walk and remarked to my wife how much larger the full moon on the horizon appeared tonight than on previous occasions. So I just assumed the question as asking why the full moon appears larger at the horizon now as opposed to on other full moon occasions.
If the question is why does it look bigger on the horizon than higher in the sky I am not sure I agree with the premise. It looked pretty big higher up in the sky last night.
The moon should appear a bit bigger as the moon rises since the distance from the moon a point on the surface of the Earth is a minimum when the point on the Earth is on the line between the centre of the Earth and the centre of the moon.
AM
That is precisely the premise, Andrew. It's called the moon illusion. It's a very compelling illusion to a significant majority of viewers. I myself am susceptible even though I am fully aware that it's all in my head. A full moon on the horizon looks huge compared to the tiny circle the moon makes when it is high in the sky. There have been a number of competing hypotheses put forth to explain why this illusion is so compelling.
I hear a good way to dispell the illusion is to bend down and put one's head between legs, so as to look at the Moon upside down.
Surgeon General's warning: Performing this experiment might damage your spine and/or social standing.
There is actually a real and quantifiable effect of size altering due to refraction, but "the moon illusion" myth gets it backwards: objects closer to the horizon are smaller, not larger than objects high up.
This is a byproduct of objects appearing higher than they really are, which is an effect requiring correction for accurate celestial navigation:
http://en.m.wikipedia.org/wiki/Atmospheric_refraction
Since the effect increases rapidly as you approach the horizon, objects appear noticeably flatter unless another atmospheric effect intervenes.
Thanks, I'll definitely consider using google for simple questions like this.
A long time ago I observed the moon high in the sky and at the horizon comparing its image to a coin. I held the coin at arm's length and observed the relative size and coverage. To my surprise and in accordance with what I read about this subject, the size of the moon was unchanged. Blocking it with the same coin held at arm's length affirmed that the size of the moon's image is the same high in the sky and at the horizon.
Nothing at all to debate here. The image appearing larger at the horizon has already been correctly explained. We perceive the sky as a canopy with a low height, but the horizon seems far away. At the horizon the size is the same as high in the sky. But because we think the horizon is further away than the sky canopy, our mind falsely concludes that the horizon image is larger.
The coin affirms positively that the images are both the same size. Trust measurements more than your senses.
Claude
Claude
Your measurements were not precise enough. The moon should be about 1.5 percent larger when directly overhead than when it is seen on the horizon.
Yes, but that's irrelevant to the topic at hand, since a 1.5% change in size is not going to be visibly detectable, and thus could not account for the observed effect (also, the change is in the wrong direction, since the illusion is of a substantially larger moon at the horizon).
Also, the length of your arm could effectively change as you raise it and lower it. That experiment is certainly near enough for jazz and you shouldn't really be dissin' it.
I was just pointing out that the moon is not the same size high in the sky as it is at the horizon. And I don't know what "near enough for jazz" means but it doesn't sound like science.
AM
Look it up on Wiki. It's in the same section as irony and humour.
Moreover, the distance from (each of) your eye(s) to the tip of your finger is not the same for every orientation of your stretched arm.
The whole experiment is pretty approximate but it's sufficient to show that the phenomenon in the OP is really just an illusion. Just how far do you go in any experiment? Time, money and inclination are limited resources.
It would be interesting to find out whether the fact that the Moon looks bigger when it's closer to the Earth is mainly because of the angle subtended or mainly the brightness difference. It certainly looks different on successive nights, when the surrounding light environment is different but the distance hasn't changed. There's another can of worms to discuss.
1. Why does the moon appear bigger at the horizon?
Many people have noticed that the moon appears larger when it is closer to the horizon, compared to when it is high in the sky. This phenomenon is known as the moon illusion, and it is an optical illusion that is caused by our brain's perception.
2. Is the moon actually bigger when it is at the horizon?
No, the size of the moon does not physically change when it is at the horizon. It remains the same size throughout its orbit around the Earth.
3. What causes the moon illusion?
The moon illusion is caused by a combination of factors, including the moon's position in the sky, our brain's perception, and the objects around us that provide a sense of scale.
4. Does the moon illusion happen with other objects in the sky?
Yes, the moon illusion can also occur with other celestial objects, such as the sun and stars. However, it is most noticeable with the moon due to its large size and brightness.
5. Can the moon illusion be explained by science?
Yes, the moon illusion has been studied by scientists for centuries, and there are several theories that attempt to explain it. Some suggest that it is a result of the brain's perception and depth cues, while others propose that it is influenced by atmospheric conditions and the curvature of the Earth.
  • Astronomy and Astrophysics
  • General Discussion
