Is the square of Heaviside function equal to Heaviside?
In summary: R(x)=0 for x< 0 and R(x)=x for x> 0. In summary, the conversation discusses the definition and properties of the Heaviside function and its relationship to its square. It is mentioned that the value of the function at 0 can be defined differently without affecting its properties. The final conclusion is that the square of the Heaviside function is not equal to the function itself, but rather to the ramp function.
snooper007
33
[tex]H(t-t')\times H(t-t')=H(t-t')? [/tex]
Please help me on the above equation.
Mathematics news on Phys.org
What are ther definitions? It gives away the answer.
Any function which has its range 0 and 1 and nothing else will be equal to its square. This is because x2=x has exactly 2 solutions, 0 and 1.
Thank mathman and Matt Grime for your help.
I was perplexed at this problem for several days.
Please don't multi-post!
As I said in this same thread in the homework help section,
http://planetmath.org/encyclopedia/H...eFunction.html
defines the Heaviside function by
H(x)= 0 if x< 0, 1/2 if x= 0, and 1 if x> 0.
With that definition, [itex]H^2(x) \ne H(x)[/itex] because
[tex](H(0))^2= \frac{1}{4}\ne \frac{1}{2}= H(0)[/tex].
This is merely a quibble. The value of the Heaviside function at 0 is irrelevant in any application.
But not irrelevant to the question of whether H2(x)= H(x)!
Quibble continued. We can define H(0) to be 0 or 1 (or anything else in between), since it doesn't affect its properties. If you want H(x)=H(x)2 for all values of x, let H(0)=0 or 1.
And you are asserting that whether or not H(x)= H2(x) is not one of its properties?
Halls stated the "usual" definition of [tex]H[/tex]
where [tex]H(0) = 1/2[/tex]
Is there another definition you want to use?
Final quibble. I prefer a definition that H(x) is the integral of a delta function at 0. In that case, H is undefined at 0. If you want left continuity, H(0)=0, right continuity gives H(0)=1.
No. [tex]H(t-t')\times H(t-t')=R(t-t') [/tex]
Here R is the ramp function
1. What is the Heaviside function?
The Heaviside function, also known as the unit step function, is a mathematical function that is defined as 0 for negative input values and 1 for positive input values.
2. What is the square of the Heaviside function?
The square of the Heaviside function is defined as the product of the Heaviside function with itself. It is often denoted as H(x)^2.
3. Is the square of the Heaviside function equal to the Heaviside function?
Yes, the square of the Heaviside function is equal to the Heaviside function for all values of x. This can be seen by substituting the definition of the Heaviside function into the square expression.
4. What is the purpose of squaring the Heaviside function?
The square of the Heaviside function is often used in mathematical equations and models to represent the behavior of a system that has a discontinuity or sudden change. It is also useful in simplifying complex equations.
5. Are there any other important properties of the square of the Heaviside function?
Yes, the square of the Heaviside function has several important properties, including being an even function, having a derivative of 0 everywhere except at x = 0, and being equal to the absolute value function. These properties make it a useful tool in mathematical analysis and applications.
10K
  • Quantum Physics
