First order linear partial differential equation
In summary, the conversation discusses the method of characteristics for solving a first order partial differential equation. The equation has two general solutions, z = f(x-y)e^y and z = f(x-y)e^x + g(x-y)e^y, and both solutions are considered to be correct. The conversation also mentions an arbitrary function and a possible set of solutions for the equation.
coverband
171
Do these equations have two general solutions!?
e.g. z_x + z_y -z = 0
Using the method of characteristics
a=1
b=1
c=-1
d=0
Therefore dx/1=dy/1=dz/z
Taking first two terms: x = y + A
*Taking last two terms: z = Be^y
So general solution is z = f(x-y)e^y
BUT if we took first and last terms: z=Be^x
z=f(x-y)e^x...
Neither of those is the "general" solution. z= f(x-y)ex+ g(x-y)ey is the general solution.
You are quite the genius! Thanks
I disagree - first order PDE's don't have two arbitrary functions in their solutions!
a=1
b=1
c=-1
d=0
z=f(x-y)e^x...
Actually, they're both right.
First solution [tex]z = e^xf(x-y)[/tex] second solution [tex]z = e^y g(x-y)[/tex]. Since [tex]f[/tex] is arbitrary the set [tex]f(x-y) = e^{-(x-y)} g(x-y)[/tex] and the first becomes the second.
What, you mean I'm NOT a genius?
I've never met you so I really don't know :rofl:
1. What is a first order linear partial differential equation?
A first order linear partial differential equation is a mathematical equation that involves a function of several variables and its partial derivatives with respect to those variables. It is called "first order" because it involves only the first derivative of the function, and "linear" because the dependent variable and its derivatives appear only to the first power.
2. How do you solve a first order linear partial differential equation?
To solve a first order linear partial differential equation, you must first separate the variables and then integrate both sides of the equation. This will result in a general solution, which can then be further simplified by applying initial or boundary conditions.
3. What are some real-world applications of first order linear partial differential equations?
First order linear partial differential equations are commonly used in physics, engineering, and other fields to model various physical processes. Some examples include the heat equation, which describes the flow of heat through a material, and the wave equation, which describes the propagation of waves.
4. Can a first order linear partial differential equation have multiple solutions?
Yes, a first order linear partial differential equation can have infinitely many solutions. This is because the general solution of the equation contains an arbitrary constant, which can take on any value. However, when initial or boundary conditions are applied, a unique solution can be found.
5. What is the difference between a first order linear partial differential equation and a first order ordinary differential equation?
The main difference between these two types of equations is that a partial differential equation involves functions of multiple variables, while an ordinary differential equation involves functions of a single variable. In other words, partial differential equations describe phenomena that vary in space, while ordinary differential equations describe phenomena that vary in time.
  • Differential Equations
