| New Reply |
Infinite potential well |
Share Thread | Thread Tools |
| Feb1-13, 05:22 PM | #1 |
In one dimensional problem of infinite square potential well wave function is ##\phi_n(x)=\sqrt{\frac{2}{L}}\sin \frac{n\pi x}{L}## and energy is ##E_n=\frac{n^2\pi^2\hbar^2}{2mL^2}##. Questions: What condition implies that motion is one dimensional. Did wave function describes motion of particle? When we say particle did we mean electron? What kind of particle mass are good enough to be treated in this model? And also why we don't draw ##\phi_n(x)##.
| Feb2-13, 09:42 AM | #2 |
one distance variable x, implies one dimension.
be sure to see the dynamic illustration near the beginning of the article here....http://en.wikipedia.org/wiki/Infinite_square_well |
| Feb2-13, 10:30 AM | #3 |
| Feb2-13, 08:48 PM | #4 |
I didn't get the answer that I'm looking. My questions:
Did wave function describes motion of particle? What kind of particle mass are good enough to be treated in this model? And And also why we don't draw ##\phi_{-n}(x)##? |
| Feb3-13, 12:14 AM | #5 |
| Feb3-13, 10:27 AM | #6 |
Did you read the links I posted.....they will help a lot. " Interpretations of quantum mechanics address questions such as what the relation is between the wavefunction, the underlying reality, and the results of experimental measurements." There are different interpretations about exactly what the wavefunctions means...there are different ways to think about it. |
| Feb3-13, 03:45 PM | #7 |
Usually in one dimensional problem you can constrain a particle between two infinitely large parallel plates, that makes the particle only subject to the boundary conditions in one dimension.
Also, I don't think that particles are described by equations of motion in QM. In QM we describe particles in Hilbert space, in classical mechanics we use phase space which describe the equations of motion of a particle. Basically any particles follows QM, but when n is large, by Correspondence Principle, classical mechanics must be a good approximation of QM |
| Feb5-13, 02:59 PM | #8 |
One more question. By solving Sroedinger eq we get
##\varphi_n(x)=\sqrt{\frac{2}{a}}\sin \frac{n\pi x}{a}## ##E_n=\frac{n^2\pi^2\hbar^2}{2ma^2}## But for example solution of Sroedinger eq is also ##C_1sin\frac {\pi x}{a}+C_2\sin\frac{2\pi x}{a}## in which state is particle? What is the energy level? How could I know in which state is particle? |
| Feb5-13, 03:10 PM | #9 |
Mentor
Before the measurement happens, the answer to the question, "which of the two energy states is the particle really in?" depends on which interpretation of QM you subscribe to. |
| Feb5-13, 03:27 PM | #10 |
Well from
[tex]\int^{a}_0 (C_1\sin \frac {\pi x}{a}+C_2 \sin \frac{2\pi x}{a})^2=1[/tex] I get ##C_1^2+C_2^2=\frac{2}{a}## what next? |
| Feb5-13, 08:42 PM | #11 |
Mentor
It's better to start out by normalizing each individual function:
$$\psi(x) = C_1 \psi_1(x) + C_2 \psi_2(x)\\ \psi(x) = C_1 \sqrt{\frac{2}{a}} \sin {\left(\frac{\pi x}{a}\right)} + C_2 \sqrt{\frac{2}{a}} \sin {\left(\frac{2 \pi x}{a}\right)}$$ Then when you normalize ##\psi## as a whole by doing an integral like yours, you end up with $$C_1^2 + C_2^2 = 1$$ We interpret ##C_1^2## as the probability that the particle will be measured to have energy E1, and ##C_2^2## as the probability that the particle will be measured to have energy E2. The two probabilities add to 1 because they are the only two possibilities for this particle as far as energy is concerned. |
| Feb6-13, 01:25 AM | #12 |
Ok but from ##C_1^2+C_2^2=1## and some other physical behavior could I say something about ##C_1^2## and ##C_2^2##?
| Feb6-13, 09:35 PM | #13 |
Mentor
Obviously you need additional information about your specific situation in order to find C1 and C2. It's impossible to say more unless you have a specific situation in mind.
| Feb7-13, 02:01 AM | #14 |
I understand that. But could you give me example of some specific situation.
| New Reply |
| Thread Tools | |
Similar Threads for: Infinite potential well
| Thread | Forum | Replies | ||
| EFunction and Energy of Infinite potential + Parabolic potential well | Advanced Physics Homework | 0 | ||
| Infinite potential well- Delta potential inside | Advanced Physics Homework | 1 | ||
| Potential step with infinite potential barrier (D.A.B Miller problem 2.8.6) | Advanced Physics Homework | 8 | ||
| 3-D Infinite Potential Well | Quantum Physics | 1 | ||
| why potential of an infinite line of charge not equals to zero at r = infinite | General Physics | 17 | ||
