- #1
SticksandStones
- 88
- 0
I've heard this a lot - that you lose depth perception when looking out of only one eye. So I have to ask - is this true? When I try it everything looks exactly the same to me.
Astronuc said:If one uses one eye, the brain does try to compensate.
I can't do this with both eyes open either :uhh:Try covering one eye and, perhaps with the help of a friend, gauge the distance to an object.
I'll try this later (except for the throwing one, which I can't do with both eyes open either :rofl: )If you really want to test this, go to an unfamiliar location and try to judge distance. Or, sit in an empty room or open field (where you won't have other clues about distance), and have a friend place objects at different distances when you aren't looking, and then with one eye closed, see how well you can identify which is the closer or farther object. Or, close your eyes, have someone choose a distance to stand from you, then open only one eye and try to throw a ball to them (choose something soft so you don't hurt them when your aim is off).
dontdisturbmycircles said:I am not 100% sure about this but this simple thought experiment may account for it a little bit. I don't know how the brain works... but this is one reason why it may work for two eyes but not for 1 (it definitely won't work for one)
If you hold a pencil infront of your eyes and close one eye, and then take turns and close the other eye, you will notice that the two images that your eyes are receiving differ. In fact, the closer an object is, the more the two images differ (in respect to that object)... could this be how our brain judges depth? Maybe someone with a degree in biology can explain how it works. I would research into it but I can't right now.
The reason that you can't judge depth with only one eye is blatant, there is nothing for the brain to compare with. Think about holding two unsharpened pencils, one quite a bit further from the other, but it is bigger (the viewer does not know this) and it is held in such a position that the sizes look the same. If they were being hovered in the air so that you couldn't use other factors to judge, wouldn't they look to be the same distance? But with two eyes your brain could use the two separate images to compare them.
dontdisturbmycircles said:If you hold a pencil infront of your eyes and close one eye, and then take turns and close the other eye, you will notice that the two images that your eyes are receiving differ. In fact, the closer an object is, the more the two images differ (in respect to that object)... could this be how our brain judges depth? Maybe someone with a degree in biology can explain how it works. I would research into it but I can't right now.
brewnog said:You don't need a degree in biology to explain this.
brewnog said:Your two eyes are actually located in different places, a few inches apart.
Of course the images look different; it's like taking two photographs of the same object from completely different places.
MadScientist 1000 said:Strange fact: You loose depth perception when both of your eyes are closed.
I don't think that's necessarily true (but haven't looked into it either). The reason I don't think so is that the optic nerves cross before entering the brain, not after, so I don't think there's a need to have both sides of the brain connected for visual information to be correctly relayed.Monique said:So what happens in people who have had Corpus callosotomy: the surgical disconnection of the two brain hemispheres by cutting the neurological bridge that connects both hemispheres. Depth perception must have been lost.
SticksandStones said:I can't do this with both eyes open either :uhh:
Thanks for the suggestions, although I still think everything looks the same. Are you supposed to be able to *see* a difference?
BobG said:Are your eyes different strengths? If one eye is much weaker than the other, you won't have very good depth perception. You don't notice because you fall in the habit of relying on your better eye, but that's the sort of thing a thorough eye exam picks up.
Moonbear said:I don't think that's necessarily true (but haven't looked into it either). The reason I don't think so is that the optic nerves cross before entering the brain, not after, so I don't think there's a need to have both sides of the brain connected for visual information to be correctly relayed.
Yes, your eyes do exactly that. It's called parallax. In fact, astronomers can do the same thing when looking at the night sky. If you look at some star in January, and then wait until June and look at it again, the Earth will have moved a considerable distance away from where you first measured it.If you hold a pencil infront of your eyes and close one eye, and then take turns and close the other eye, you will notice that the two images that your eyes are receiving differ. In fact, the closer an object is, the more the two images differ (in respect to that object)... could this be how our brain judges depth? Maybe someone with a degree in biology can explain how it works. I would research into it but I can't right now.
Integral said:The quickest, easiest test I know about is simply touching your fingers. Close 1 eye, bring your hands up from your sides and touch your forefingers together.
I had no trouble at all with one eye closed. There are simply too many visual and non-visual cues. I tried the following variation with much more success. Place a pencil across the diameter of a drinking cup (these are items I had at hand when I tried this) with the pencil point pointing to your right and the cup placed to your left. Now hold a pen in your right hand and move it from right to left parallel to the pencil. Touch the point of the pencil with the tip of the pen. I was unable to do this unless I had both eyes open.cyrusabdollahi said:Classic example. Open both eyes.
Now 'point' with your left and right hands. Hold your hands out infront of you and touch the tips of your 'pointing fingers'
Now close one eye and see if you can do it, you cant.
Danger said:My knowledge of biology is severely limited, but isn't it true that half of the visual field of each eye goes to each hemisphere? In that case, depth perception should be maintained.
Yes, it is true that losing depth perception can occur when looking out of one eye. This is because depth perception is the ability to perceive the distance of objects and their relative positions in three-dimensional space. When looking out of only one eye, the brain is unable to use the disparity between the images from each eye to calculate depth, resulting in a loss of depth perception.
Losing depth perception can make it difficult to accurately judge distances and spatial relationships, which can affect daily activities such as driving, sports, and even simple tasks like pouring a glass of water. It can also cause eye strain and fatigue as the brain works harder to compensate for the lack of depth perception.
In most cases, depth perception cannot be regained if one eye is permanently closed. However, if the eye is temporarily closed, the brain can adapt and learn to use the remaining eye to perceive depth. This process is known as sensory substitution and can take some time to develop.
There are some exercises and treatments that can potentially improve depth perception in one eye, such as vision therapy and wearing a patch over the stronger eye to strengthen the weaker eye. However, the effectiveness of these methods may vary and it is best to consult with a doctor or vision specialist for personalized recommendations.
In some cases, losing depth perception in one eye can be a sign of a serious eye condition, such as a lazy eye or a cataract. It is important to consult with an eye doctor if you experience sudden loss of depth perception, as it can be a symptom of a larger problem that requires medical attention.
