Upper limit on the characteristics of Singularity
In summary, the concept of a "singularity" in the context of black holes refers to a point where the solution to the equations of general relativity breaks down due to a division by zero. This means that GR is not able to accurately describe what happens at the singularity and a different theory is needed. While it is not possible to determine the dimensions of the singularity, there may be an upper limit on the size of the region where GR stops working, which is estimated to be around the Planck length. This suggests that GR may fail in a spherical region of approximately 1 Planck length at the center of a black hole.
surajt88
63
"Upper limit" on the characteristics of "Singularity"
I know GR fails in "singularities". Is there an upper limit on characteristics of the singularity like a maximum value for the density of matter after which GR fails? I came across a number of threads which discuss what happens after something falls inside a supermassive black hole and it seems that GR holds well inside these objects within the event horizon. I would like to know the limits of GR, or in other words, at what point exactly does GR begin to fail in explaining the characteristics of matter that falls into the said supermassive black hole? Hope I made myself clear.
The only relevant scale is the Planck scale: http://en.wikipedia.org/wiki/Planck_length
Near a black hole, you can describe spacetime using GR as long as your distance from the singularity is roughly greater than the Planck length.
There is also a Planck mass, and therefore you can define a Planck density.
Sorry for the layman questions, but does the plank length explanation imply that the size of the "singularity" is of dimensions comparable to the Planck length or is the dimensions of the singularity indeterminable by GR, but the characteristics of the infalling matter is determinable upto within Planck length of the singularity? Also, is the Planck length incorporated in GR to explain the limits of the theory?
I don't think we know, since we don't have a theory of quantum gravity.
That's certainly true.
Not sure what you mean by this.
No, GR doesn't have Planck's constant in it, so it doesn't say anything about the Planck scale. If we didn't know about quantum mechanics, only GR, then we might suspect that something was going wrong when singularities were predicted, but we'd have no way of saying that there was a specific scale where GR broke down.
Not sure what you mean by this .
I don't have a formal background in physics and so I'm having a hard time getting across with what I mean.
The above post was what I wanted clarifications with. Let's assume an infalling observer measures the distance from the event horizon to within 1 Planck distance of the singularity using GR. From this distance and from his previous knowledge of the diameter of the (let's assume) non rotating black hole, wouldn't it be possible to calculate the "dimensions of the singularity"?
I know this would seem a stupid question but I am unable to find an answer to this.
The "singularity" is a point where the solution to the equations of general relativity makes no sense because it contains a division by zero. That doesn't tell us anything except that GR doesn't work at that point and that we need a different theory to describe what's happening in the neighborhood of that point.
Because it's a point, it also doesn't make much sense to talk about its dimensions.
However, I expect that what you're really asking is "Is there an upper limit on the size of the region where GR stops working?". Given that we don't exactly have a lot of observational data from inside an event horizon to confirm that GR works there, a fair case could be made that that's the upper bound. (not a very satisfying upper bound though, because we have every reason to expect that GR does work until we get much closer to the singularity).
The Planck length is a pretty convincing lower bound.
"Is there an upper limit on the size of the region where GR stops working?" was exactly what I meant. I read up a bit and realized that askin for the "dimensions of the singularity" in this case is akin to askin when infinity begins in an extended number line.
Does what you said above imply that GR fails in a spherical region of radius of about 1 Planck length at the centre of the black hole?
1. What is the "Upper limit on the characteristics of Singularity"?
The "Upper limit on the characteristics of Singularity" refers to the theoretical maximum capabilities and traits that a Singularity (a hypothetical point of technological advancement where artificial intelligence surpasses human intelligence) can possess.
2. Why is there an upper limit on the characteristics of Singularity?
The upper limit on the characteristics of Singularity is based on the laws of physics and computing power. There is a finite amount of energy and resources available in the universe, and a Singularity cannot exceed these limits.
3. Can the upper limit on the characteristics of Singularity be surpassed?
It is highly unlikely that the upper limit on the characteristics of Singularity can be surpassed, as it is based on fundamental laws of the universe. However, advancements in technology and understanding may allow for some characteristics to be pushed closer to the limit.
4. How is the upper limit on the characteristics of Singularity determined?
The upper limit on the characteristics of Singularity is determined through calculations and predictions based on current and projected technological capabilities, as well as the known limits of physics and computing power.
5. What are some potential characteristics that could be limited by the upper limit on Singularity?
Some potential characteristics that could be limited by the upper limit on Singularity include intelligence, problem-solving abilities, memory capacity, and processing speed. However, there may be other unknown limitations that could also play a role.
