| New Reply |
horizontal spring with friction |
Share Thread | Thread Tools |
| Feb4-13, 01:15 PM | #1 |
1. The problem statement, all variables and given/known data
A spring with negligible mass has a constant of 105 N/m. It has been compressed horizantally with a 2 kg mass for a distance of 0.1m. If the mass has moved after release for a distance of 0.25m, what is the coefficient of kinetic friction between mass and horizontal surface. 2. Relevant equations F=-kx (spring force) f= C N, f is friction, C is the kinetic friction coefficient, and N is the force exerted on the mass by the horizontal surface 3. The attempt at a solution 1. The problem statement, all variables and given/known data 2. Relevant equations 3. The attempt at a solution |
| Feb4-13, 01:16 PM | #2 |
i would recommend using work to solve this problem.
Work=force*distance also work done by a spring is .5*k*x^2 |
| Feb4-13, 02:57 PM | #3 |
Conservation of energy would be the easiest way to solve this.
What happens to the potential energy initially stored in the spring? |
| Feb4-13, 03:24 PM | #4 |
hello
ok the work done by the spring is 0.5*k*x02 - 0.5*k*x12 we know that x0=-0.1m but what is x1, since the 0.25m given in the question is the distance not the displacement??!? |
| Feb4-13, 03:38 PM | #5 |
ok i see what you mean ap123
the energy stored initially = the work done by the friction force 0.5*k*x0^2= C * mg * distance |
| Feb4-13, 03:43 PM | #6 |
Yes, you've got it :)
| New Reply |
| Thread Tools | |
Similar Threads for: horizontal spring with friction
| Thread | Forum | Replies | ||
| Horizontal spring, mass and nonconstant friction | Introductory Physics Homework | 1 | ||
| Horizontal Spring-Mass System with Friction | Introductory Physics Homework | 3 | ||
| horizontal spring | General Physics | 3 | ||
| Horizontal spring problem with friction? | Introductory Physics Homework | 2 | ||
| Crates on a Ramp with Friction and a spring at bottom. Finding the spring constant. | Introductory Physics Homework | 2 | ||
