| New Reply |
Cantilever beam deflection |
Share Thread | Thread Tools |
| Feb9-13, 10:20 AM | #1 |
Hi,
I am new to this type of material and am hoping that someone may be able to assist me. In short I am putting a cantilever beam under test to determine its bending moment and stiffness (K value) in order to get a strain reading that can be related to an exact model in solid works. The cantilever beam is 0.26m long and a weight is applied at 0.25m. It is obviously hinged at one end and has a point load of 4.9N (at 0.25m). I have calculated a bending moment of 1.225x10-3 by summing -(0.0049)(0.25). I believe this is right? From this I am trying to determine strain behaviour via M/I=Sigma/y I have calculated I from bh3/12 as it is a rectangle giving me 43.94x10 6. Again I believe this is correct? For the stress I assume I simply put the 4.9N that I applied? And I am unsure on how to calculate y? Also how do i determine the K value from this? It may also be worth mentioning that I have used a DTI to calculate a deflection of .11mm under loading I appreciate any help, I am new to all of this and appreciate your patience cheers, Jason |
| Feb9-13, 02:05 PM | #2 |
If this is a homework question you have posted in wrong forum. Deflection of a cantilever under a point load P applied a distance L from the fixed support can be found in tables or determined from the calculus, where the stiffness is the inverse of the deflection under a unit point load. Watch your units is the load in N or kN? What are the beam dimensions ? Max stress occurs at extreme outer fibers at fixed end and where y for max stress location is the distance to the neutral axis .
| New Reply |
| Tags |
| cantilever beam, deflection, k stiffness, stress and strain |
| Thread Tools | |
Similar Threads for: Cantilever beam deflection
| Thread | Forum | Replies | ||
| Deflection of L Shaped Cantilever Beam | Engineering, Comp Sci, & Technology Homework | 0 | ||
| Cantilever Beam Deflection | Engineering, Comp Sci, & Technology Homework | 5 | ||
| Deflection of tapered beam cantilever | Mechanical Engineering | 3 | ||
| Deflection of Cantilever Beam Arrangement | Mechanical Engineering | 8 | ||
| Deflection of Cantilever Beam Arrangement | Classical Physics | 0 | ||
