Please help assign due 2marrow effective radiative temperature
  • Thread starter Sunshin3
  • Tags
    Temperature
In summary, the conversation discusses the sun's radiative output during the Archean eon, which is believed to have been 30% less than it is today. The temperature of the sun at that time is estimated to be 5488.14K, and the peak emission would have been at a wavelength of 0.527. To determine the Earth's temperature at this time, one must use the Stefan-Boltzmann law to calculate the amount of radiation it receives and then reduce it by 30%. Assuming the Earth's albedo was the same as it is today, it can be determined that the Earth's temperature at this time would have been 75% of its current temperature.
Sunshin3
. Homework Statement
It is believed that in the Archeaneon (2.5-4 billion years ago) the sun’s radiative output was 30% less than it is today.
(i) What would the temperature of the sun have been at that time?
(ii) At what wavelength would the peak emission from the sun have been?
(iii) Ignoring the effects of the atmosphere, what would the temperature of the Earth have been at this time (i.e. the effective radiative temperature)? Assume that the Earth’s albedo was 0.3, the same as today.
2. Homework Equations
Boltzman equation
wiens law
3. The Attempt at a Solution
a)T= 4th root[5143824/(5.67*10^-8)]
t=5488.14K
b)detlamax=2897/5488.147
=0.527
I DONT GET PART 3 PLEASE HELP MEE! MY ASSIGNMENT IS DUE TOMARROW! PLEASE
You will have to do a better job of explaining your work in parts 1 and 2.
To do part 3, you have to determine what amount of radiation the Earth currently receives / unit time and then reduce it by 30%. You know that the Earth must radiate that same amount of energy /unit time (on average). From that, apply the Stefan-Boltzmann law to determine its temperature.
AM
HELP
For part (iii), we can use the Stefan-Boltzmann law to calculate the effective radiative temperature of the Earth. The Stefan-Boltzmann law states that the energy radiated from a blackbody is proportional to the fourth power of its temperature. In this case, we can assume that the Earth is a blackbody and use the following equation:
T = (L/4πσR^2)^1/4
Where:
T = temperature in Kelvin
L = luminosity of the sun
σ = Stefan-Boltzmann constant (5.67 x 10^-8 W/m^2K^4)
R = distance between the Earth and the sun (assume 1 AU)
Using the luminosity of the sun at that time (30% less than today), we can calculate the effective radiative temperature of the Earth. Remember to convert the luminosity to SI units (Watts) before plugging it into the equation.
Once you have calculated the effective radiative temperature of the Earth, you can then use the albedo value (0.3) to calculate the equilibrium temperature of the Earth using the following equation:
Te = (1-A)^1/4 * T
Where:
Te = equilibrium temperature of the Earth
A = albedo value (0.3)
T = effective radiative temperature of the Earth calculated in the previous step
This will give you the temperature of the Earth at that time, assuming there were no atmospheric effects. Keep in mind that this is a simplified calculation and does not take into account other factors such as the greenhouse effect.
What is an effective radiative temperature?
An effective radiative temperature is the theoretical temperature of a blackbody that would emit the same amount of radiation as the given object at a given wavelength. It is used to describe the overall temperature of an object based on its radiative properties.
Why is it important to assign an effective radiative temperature?
Assigning an effective radiative temperature is important for understanding the energy balance of a system and predicting its radiative properties. It is also useful for comparing the temperatures of different objects based on their emission spectra.
How do you calculate the effective radiative temperature?
The effective radiative temperature can be calculated using the Stefan-Boltzmann law, which relates the temperature of an object to its radiative flux. It can also be estimated using radiative transfer models.
What factors can affect the effective radiative temperature of an object?
The effective radiative temperature of an object can be affected by its composition, surface properties, and internal heat sources. It can also be influenced by external factors such as atmospheric conditions and nearby objects.
How is the effective radiative temperature used in scientific research?
The effective radiative temperature is used in a variety of fields, including meteorology, astrophysics, and remote sensing. It is used to study the energy balance of the Earth and other planets, as well as the radiative properties of stars and other celestial objects. It is also used in climate modeling to understand the effects of greenhouse gases on the Earth's temperature.
9K
  • Aerospace Engineering
