mingshey
- 5
Jackson("Classical Electrodynamics", Ch.6)
uses the theorem of curl of curl to separate current density into transverse and parallel,
[tex]\vec J = \vec{J_p}+\vec{J_t}[/tex] to say,
[tex]\begin{align*}\vec{J}(\vec{x}) &= \int\vec{J}(\vec{x'})\delta(\vec{x}-\vec{x'})d^{3}x'\\
&= -{1\over{4\pi}}\int\vec{J}(\vec{x'})\nabla^2 \left({1\over|\vec{x}-\vec{x'}|}\right)d^{3}x'
\end{align*}[/tex]
Since the del is about [tex]x[/tex] and independent of the integral variable,
[tex]\begin{align*}{}&=-{1\over{4\pi}}\nabla^2\int{\vec{J}(\vec{x'})
\over|\vec{x}-\vec{x'}|}d^{3}x'
\end{align*}[/tex]
And using the theorem
[tex]\nabla\times(\nabla\times\vec{A})=\nabla(\nabla\cdot\vec{A})-\nabla^2\vec{A}[/tex]
{1\over{4\pi}}\nabla\times\nabla\times\int{\vec{J}(\vec{x'})
\over|\vec{x}-\vec{x'}|}d^{3}x'-{1\over{4\pi}}\nabla\left(\nabla\cdot\int{\vec{J}(\vec{x'})
\over|\vec{x}-\vec{x'}|}d^{3}x'\right)\end{align*}[/tex]
But here Jackson take some hidden procedure to get from the second term of ther right side
[tex]-{1\over{4\pi}}\nabla\left(\int{\nabla'\cdot\vec{J}(\vec{x'})
\over|\vec{x}-\vec{x'}|}d^{3}x'\right)={1\over{4\pi}}\nabla\left(\int{\partial\rho(\vec{x'})/\partial t
\over|\vec{x}-\vec{x'}|}d^{3}x'\right)[/tex]
to use the continuity theorem to get the term about a time derivative of charge density at [tex]x'[/tex].
And I cannot see how is the differential about [tex]x[/tex] changed into a differential about [tex]x'[/tex] and got inside the integral, and is only applied to the current density, but not the denominator.
Can somebody explain it for me? Thank you.
\end{align*}[/tex]
\end{align*}[/tex]
