Register to reply
In electronics, why do we need a two port network?
by meisnkp
Tags: electronics, network, port
Share this thread:
meisnkp
#1
Aug17-14, 07:06 AM
P: 3
Why do we need a two port network? Is there something which a one port network lacks? Why we needed a two port network connection?
Phys.Org News Partner Engineering news on Phys.org
A spray-on light show on four wheels: Darkside Scientific
Research project on accident-avoiding vehicle concluded
Smaller artificial magnetic conductors allow for more compact antenna hardware
Simon Bridge
#2
Aug17-14, 09:28 AM
Homework
Sci Advisor
HW Helper
Thanks
Simon Bridge's Avatar
P: 13,051
Welcome to PF;
What a 1-port network lacks is a second port.
The second port on the input and the output allows for more complicated arrangements of components.
Almost all electronics devices would not function with only one port.
For instance - how do make an amplifier with only one port? How do you add a power supply with only one port?
(Note: the ground can be the second port.)
meisnkp
#3
Aug17-14, 09:59 AM
P: 3
Hmm...thanks
meisnkp
#4
Aug17-14, 10:04 AM
P: 3
But what about the two port circuits with only simple linear resistances (and not any non-linear elements like transistor s)? What's special in that?
sophiecentaur
#5
Aug17-14, 05:34 PM
Sci Advisor
Thanks
PF Gold
sophiecentaur's Avatar
P: 12,256
Quote Quote by Simon Bridge View Post
Welcome to PF;
I am not sure about that. Ifaikr, a 'port' consists of two terminals - e.g between an input terminal and ground or two input connections. A two port device would have four terminals or possibly three terminals with one 'common', which may or may not be 'ground'. I don't think the power supply connections are classed as ports in an active device.
A single port network would just have two terminals - such as a resistor (the simplest), an RC or RLC network or a more complicated circuit that might even be active.
We "need" two port networks if we want to have all those functions that amplifiers, transformers and matching networks provide.
davenn
#6
Aug17-14, 06:02 PM
Sci Advisor
PF Gold
davenn's Avatar
P: 2,722
Quote Quote by sophiecentaur
yes agreed ... a port is an I/O type port input only, output only, or bi directional
and may be considered analog or digital
Dave
jsgruszynski
#7
Sep7-14, 06:10 PM
P: 287
A one port models a single 2-terminal circuit element.
A two port models a transfer function or similar system component as wells ladder and tee circuit elements. Dependent sources, for example, are 2-ports. A transfer function of the form y = A x is a 2-port.
Since transfer functions are extremely common it's nice to have a very generic linear circuit model concept for them.
Register to reply
Related Discussions
Two-port network models Engineering, Comp Sci, & Technology Homework 2
Two-port network models Engineering, Comp Sci, & Technology Homework 6
2 port network Y parameters Engineering, Comp Sci, & Technology Homework 7
Regarding with two port electrical network Electrical Engineering 3
2 Port Network Engineering, Comp Sci, & Technology Homework 2
