How to calculate the contraction of metric tensor g^ab g_ab
In summary, the conversation discusses the calculation of a contraction involving gabgab and the use of Tensor Algebra. The incorrect steps taken in calculating the contraction are pointed out, with the correct step being to expand and sum over the components in four spacetime dimensions.
yicong2011
75
I wish I could calculate the contraction:
gabgab
I wish someone could show me how to get n!
Unfortunately, I find it difficult, for I am not familiar with Tensor Algebra ...
My wrong way to calculate it:
gabgab= gabgba (since gab is symmetric)
= δaa
= 1Why is it wrong?
So, you just sum over a and b...so it's like g00g00+g01g01+g02g02+g03g03+g10g10+g11g11+...all 16 terms
But why the following is wrong? I cannot figure it out...
= δaa
= 1
Anyone can help?
The problem is your last step.
In four spacetime dimensions
[tex]\delta^a{}_a = 4[/tex]
because
[tex]\delta^a{}_a = \delta^0{}_0 + \delta^1{}_1 + \delta^2{}_2 + \delta^3{}_3 = 1 + 1 +1 +1 = 4[/tex]
because
Ahh...Ja... [tex]\delta^a{}_a is not the components... I need to expand it and sum over the components...
What is the formula for calculating the contraction of a metric tensor?
The contraction of a metric tensor gab gab can be calculated using the formula gab gab = g11 + g22 + g33 + ... + gnn, where n is the dimension of the metric tensor.
How does the contraction of a metric tensor relate to the metric determinant?
The contraction of a metric tensor is equal to the square of the metric determinant. In other words, gab gab = det(g).
Can the contraction of a metric tensor be negative?
Yes, the contraction of a metric tensor can be negative if the metric tensor has negative components. This can occur in non-Euclidean spaces.
What is the physical significance of the contraction of a metric tensor?
The contraction of a metric tensor is related to the volume element in a given coordinate system. It is also used to calculate distances and angles in curved spaces.
How is the contraction of a metric tensor used in general relativity?
In general relativity, the contraction of a metric tensor is used to define the energy-momentum tensor, which describes the distribution of mass and energy in a given spacetime.
  • Linear and Abstract Algebra
