What are the Sources of Dispersion in Fibre Optics?
In summary, dispersion in Fibre Optics is due to the different group velocities of different modes in the fibre. Modes are not present in single mode fibres, as there is only one mode. Waveguide dispersion can be shifted so that the 0 occurs at a different wavelength (1550nm).
-DJL-
I'm confused as to sources of dispersion in a fibre. Any clarification would be appreciated.
Modal (Intermodal) dispersion: pulse spreading due to different group velocities of different modes in the fibre. Each mode has a slightly different n-effective hence the different Vg for each mode. Not present in single mode fibres, as there's only one mode. Can also be though of as different ray paths - light traveling down the centre of the fibre will reach the end before light which is TIR'ing its way along.
Intramodal covers the following;
Material Dispersion: Spectral width; each spectral component will in general travel with a different group velocity -> difference wavelengths travel at different speeds. Sources of spectral width: LED greater width than a laser, and sidebands caused by modulation.
Waveguide dispersion: ?? changes in the distribution of light between core and cladding? Dependant on core diameter?
So with Dispersion Shifted Fibres :- single mode fibre, therefore no modal dispersion. Waveguide dispersion is negative and material dispersion is positive -> therefore at a particular wavelength they cancel -> 0 dispersion. Wave guide dispersion can be shifted so that the 0 occurs at a different wavelength (1550nm)
...wave-guide dispersion depends on the shape, design, and chemical composition of the fiber core. Only 80 percent of the power from a light source is confined to the core in a standard single-mode fiber, while the other 20 percent actually propagates through the inner layer of the cladding. This 20 percent travels at a faster velocity because the refractive index of the cladding is lower than that of the core (Keiser, 1983). Consequently, signals of differing frequencies and wavelengths are dispersed and the pulse becomes indistinguishable (Lerner, 1997).
"www.cmste.uncc.edu/new/papers/Attenuation%20in%20Fiber%20Optics.doc"[/URL]
That's cool stuff. What part is confusing? What learning resources do you have available, and what have you read so far on the web?
Doh! dlgoff is quick today!
dlgoff - Thanks, that link, along with going through the maths, has helped clarify waveguide dispersion.
A great book on the subject is Ghatak, Ajoy and K., Thyagarajan. (2000). Introduction to Fibre Optics. Cambridge, UK : Cambridge University Press.
What is dispersion in fibre optics?
Dispersion in fibre optics refers to the phenomenon where different wavelengths of light travel at different speeds through a fibre optic cable. This can cause distortion and loss of signal, leading to reduced performance of the optical system.
What are the different types of dispersion in fibre optics?
There are two main types of dispersion in fibre optics: chromatic dispersion and modal dispersion. Chromatic dispersion is caused by differences in the speed of light for different wavelengths, while modal dispersion is caused by variations in the path length of different modes of light within a fibre.
How does dispersion affect the performance of fibre optic systems?
Dispersion can significantly degrade the performance of fibre optic systems by causing signal distortion and loss. This can result in lower data transmission rates and decreased signal quality. It is important to minimize dispersion in fibre optic systems to ensure optimal performance.
What are some methods for reducing dispersion in fibre optics?
There are several methods for reducing dispersion in fibre optics, including using dispersion-compensating fibres, using dispersion-shifted fibres, and using dispersion compensation techniques such as pre-compensation or post-compensation. These methods help to counteract the effects of dispersion and improve the overall performance of the optical system.
How is dispersion measured in fibre optics?
Dispersion is typically measured in units of picoseconds per kilometre (ps/km) or nanoseconds per kilometre (ns/km). This measurement is used to quantify the amount of time delay or distortion that occurs in a fibre optic system. Specialized equipment, such as an optical time domain reflectometer (OTDR), is used to measure dispersion in fibre optics.
  • Quantum Physics
