How to work out the uncertainty of some measurements?
The standard deviation would then be the uncertainty. However, in practice, you only have a handful of measurements. In this case, the range can be used as an estimate of the random uncertainty. In summary, The uncertainty of measurements can be quantified by the standard deviation or the range, depending on the number of measurements taken. It is important to also consider the accuracy and precision of the instrument used to make the measurements.
a66as
i am trying to work out the uncertainty of some measurements but i don't know how to, i tried finding some info on it online but i cant, well these are my 10 measurements
9.13mm
9.12mm
9.13mm
9.12mm
9.12mm
9.13mm
9.13mm
9.12mm
9.13mm
9.12mm
i have worked out that the average is 9.125 but i don't have a clue on how to work out the uncertainty, any help would be appreciated, you don't have to give an answer just tell me what you can to calculate to work it out
The uncertainty is the standard deviation. Subtract each value from the mean, square that result, add them together, divide by n-1 (9 in this case), and take the square root of that.
It's generally represented by a plus-or-minus sign, but that doesn't mean that the average falls between the range created by that value, that's a different calculation involving confidence intervals.
When you use an instrument to make measurements, your uncertainty depends on its accuracy.
When it is inaccurate, the uncertainty is larger than the standard deviation of the repeated measures.
http://en.wikipedia.org/wiki/Measurement_uncertainty"
after doing some research online i found this formula
Random Uncertainty = Maximum reading - Minimum reading
Number of readings
so if i did 9.13 - 9.12 and divided it by 10 i would get the answer 1x10 to the power of -3
0.01 is this the correct answer?
Typically, scientists use the standard deviation of a set of measurements to quantify the uncertainty. To give a meaningful uncertainty in practice, however, a scientist should also include device precision and reading error.
Exactly. If you get by some formula that the uncertainty is smaller than the accuracy of your instrument then the uncertainty is simply the accuracy of your instrument.
Using
you can get a very small uncertainty if you have a lot of values. Say you measured a building with a meter rule and you get an uncertainty of 1 nanometer you realize it's meaningless to say the uncertainty is smaller than the accuracy of your instrument.
Number of readings
Note the term "random uncertainty". This refers, therefore, to multiple measurements where the data and/or the measurement changed because of randomness. This assumes that your measurement is infinitely accurate, as others have pointed out. Your measurements have only two significant digits after the decimal point, therefore an uncertainty of 0.001 does not really make sense. It would help to know what your measurements are of and how the measurements were done.
Assuming the measurement is perfect (a theoretical measurement :wink:) and a large number of measurements, a standard deviation as mentioned by 2ltben is a better measure of the random uncertainty than the formula you have.
What is uncertainty in measurements?
Uncertainty in measurements refers to the degree of doubt or error in a measurement. It is a measure of the range of values within which the true value of the measurement is likely to fall.
Why is it important to work out the uncertainty of measurements?
Working out the uncertainty of measurements is important because it helps to determine the accuracy and reliability of the measurement. It also allows for proper analysis and interpretation of the data.
What are the sources of uncertainty in measurements?
The sources of uncertainty in measurements can be classified into two categories: random and systematic. Random uncertainties are caused by inherent variations in the measurement process, while systematic uncertainties are caused by factors that consistently affect the measurement in the same way.
How can you calculate the uncertainty of a measurement?
The uncertainty of a measurement can be calculated by taking into account the precision of the measuring instrument, the limitations of the measurement process, and the sources of uncertainty. This can be done using statistical methods or by using a specific formula, depending on the type of uncertainty.
What are some strategies for reducing uncertainty in measurements?
Some strategies for reducing uncertainty in measurements include using more precise instruments, calibrating instruments regularly, conducting multiple measurements, and controlling external factors that may affect the measurement. It is also important to follow proper measurement techniques and record all relevant data accurately.
  • Atomic and Condensed Matter
  • Quantum Physics
  • STEM Educators and Teaching
