[ubuntu] Can't boot into anything after installing Ubuntu on Windows 7
In summary: Windows 7 /dev/sdb1 Linux Drive: sdc _____________________________________________________________________Disk /dev/sdc: 2500.4 GB, 250039164864 bytes255 heads, 63 sectors/track, 1875 cylinders, total 1953525168 sectorsUnits = sectors of 1 * 512 = 512 bytesSector size (logical/physical): 512 bytes / 512 bytes
zeion
466
Hi,
I installed Ubuntu 11.10 as a partition on the same HD as my Windows 7; after rebooting the HD would not boot into either OS. I've tried to set partition flags to 'boot' but it does nothing. Should there be some files I need in /boot ?
I'm able to mount and access the files on either partition but I can't boot into them. (Only able to boot from USB).
Please help.
Thanks.
edit: I've added boot info script and here's the result:
Boot Info Script 0.60 from 17 May 2011============================= Boot Info Summary: ===============================
=> No boot loader is installed in the MBR of /dev/sda.
=> Syslinux MBR (4.04 and higher) is installed in the MBR of /dev/sdb.
sda1: __________________________________________________________________________
File system: swap
Boot sector type: -
Boot sector info:
sda2: __________________________________________________________________________
File system: ext4
Boot sector type: -
Boot sector info:
Operating System: Ubuntu 11.10
Boot files: /boot/grub/grub.cfg /etc/fstab
sda3: __________________________________________________________________________
File system: ntfs
Boot sector type: Windows Vista/7
Boot sector info: No errors found in the Boot Parameter Block.
Operating System: Windows 7
Boot files: /Windows/System32/winload.exe
sdb1: __________________________________________________________________________
File system: vfat
Boot sector type: SYSLINUX 4.05 2011-12-09
Boot sector info: Syslinux looks at sector 37976 of /dev/sdb1 for its
second stage. SYSLINUX is installed in the directory.
The integrity check of the ADV area failed. No errors
Operating System:
Boot files: /boot/grub/grub.cfg /syslinux/syslinux.cfg /ldlinux.sys
============================ Drive/Partition Info: =============================
Drive: sda _____________________________________________________________________
Disk /dev/sda: 1000.2 GB, 1000204886016 bytes
255 heads, 63 sectors/track, 121601 cylinders, total 1953525168 sectors
Partition Boot Start Sector End Sector # of Sectors Id System
/dev/sda1 1 1,953,525,167 1,953,525,167 ee GPTGUID Partition Table detected.
Partition Start Sector End Sector # of Sectors System
/dev/sda1 1,534,093,312 1,550,093,312 16,000,001 Swap partition (Linux)
/dev/sda2 1,550,093,313 1,953,524,953 403,431,641 Data partition (Windows/Linux)
/dev/sda3 468,992 1,534,093,311 1,533,624,320 EFI System partition
Drive: sdb _____________________________________________________________________
Disk /dev/sdb: 4127 MB, 4127194624 bytes
255 heads, 63 sectors/track, 501 cylinders, total 8060927 sectors
/dev/sdb1 * 128 8,060,799 8,060,672 b W95 FAT32"blkid" output: ________________________________________________________________
Device UUID TYPE LABEL
/dev/loop0 squashfs
/dev/sda1 1fc11ecd-0735-4c85-bbf3-a6b2e1f94ce4 swap
/dev/sda2 26d36caa-7d60-4f39-afd6-1c596a6552a3 ext4
/dev/sda3 DCAA8516AA84EE78 ntfs
/dev/sdb1 7C9A-C58E vfat PENDRIVE
================================ Mount points: =================================
Device Mount_Point Type Options
/dev/loop0 /rofs squashfs (ro,noatime)
/dev/sda3 /media/DCAA8516AA84EE78 fuseblk (rw,nosuid,nodev,allow_other,blksize=4096,default_permissions)
/dev/sdb1 /cdrom vfat (rw,relatime,fmask=0022,dmask=0022,codepage=cp437,iocharset=iso8859-1,shortname=mixed,errors=remount-ro)
/dev/sr0 /media/UDF Volume udf (ro,nosuid,nodev,uid=999,gid=999,iocharset=utf8,umask=0077,dmode=0500,uhelper=udisks)=========================== sda2/boot/grub/grub.cfg: ===========================
# DO NOT EDIT THIS FILE
# It is automatically generated by grub-mkconfig using templates
# from /etc/grub.d and settings from /etc/default/grub
### BEGIN /etc/grub.d/00_header ###
if [ -s $prefix/grubenv ]; then
set have_grubenv=true
load_env
fi
set default="0"
if [ "${prev_saved_entry}" ]; then
set saved_entry="${prev_saved_entry}"
save_env saved_entry
set prev_saved_entry=
save_env prev_saved_entry
set boot_once=true
fi
function savedefault {
if [ -z "${boot_once}" ]; then
saved_entry="${chosen}"
fi
function recordfail {
set recordfail=1
if [ -n "${have_grubenv}" ]; then if [ -z "${boot_once}" ]; then save_env recordfail; fi; fi
function load_video {
insmod efi_gop
insmod efi_uga
insmod video_bochs
insmod video_cirrus
insmod part_gpt
insmod ext2
set root='(hd0,gpt2)'
search --no-floppy --fs-uuid --set=root 26d36caa-7d60-4f39-afd6-1c596a6552a3
if loadfont /usr/share/grub/unicode.pf2 ; then
set gfxmode=auto
load_video
insmod gfxterm
insmod part_gpt
insmod ext2
set locale_dir=($root)/boot/grub/locale
set lang=en_CA
insmod gettext
fi
terminal_output gfxterm
if [ "${recordfail}" = 1 ]; then
set timeout=-1
else
set timeout=10
fi
### END /etc/grub.d/00_header ###
### BEGIN /etc/grub.d/05_debian_theme ###
set menu_color_normal=white/black
set menu_color_highlight=black/light-gray
if background_color 44,0,30; then
clear
fi
### END /etc/grub.d/05_debian_theme ###
### BEGIN /etc/grub.d/10_linux ###
if [ ${recordfail} != 1 ]; then
if [ -e ${prefix}/gfxblacklist.txt ]; then
if hwmatch ${prefix}/gfxblacklist.txt 3; then
if [ ${match} = 0 ]; then
set linux_gfx_mode=keep
else
set linux_gfx_mode=text
fi
else
fi
else
fi
else
fi
export linux_gfx_mode
if [ "$linux_gfx_mode" != "text" ]; then load_video; fi
menuentry 'Ubuntu, with Linux 3.0.0-12-generic' --class ubuntu --class gnu-linux --class gnu --class os {
recordfail
set gfxpayload=$linux_gfx_mode
insmod gzio
insmod part_gpt
insmod ext2
linux /boot/vmlinuz-3.0.0-12-generic root=UUID=26d36caa-7d60-4f39-afd6-1c596a6552a3 ro quiet splash vt.handoff=7
initrd /boot/initrd.img-3.0.0-12-generic
menuentry 'Ubuntu, with Linux 3.0.0-12-generic (recovery mode)' --class ubuntu --class gnu-linux --class gnu --class os {
recordfail
insmod gzio
insmod part_gpt
insmod ext2
echo 'Loading Linux 3.0.0-12-generic ...'
linux /boot/vmlinuz-3.0.0-12-generic root=UUID=26d36caa-7d60-4f39-afd6-1c596a6552a3 ro recovery nomodeset
echo 'Loading initial ramdisk ...'
### END /etc/grub.d/10_linux ###
### BEGIN /etc/grub.d/20_linux_xen ###
### END /etc/grub.d/20_linux_xen ###
### BEGIN /etc/grub.d/20_memtest86+ ###
menuentry "Memory test (memtest86+)" {
insmod part_gpt
insmod ext2
linux16 /boot/memtest86+.bin
menuentry "Memory test (memtest86+, serial console 115200)" {
insmod part_gpt
insmod ext2
linux16 /boot/memtest86+.bin console=ttyS0,115200n8
### END /etc/grub.d/20_memtest86+ ###
### BEGIN /etc/grub.d/30_os-prober ###
if [ "x${timeout}" != "x-1" ]; then
if keystatus; then
if keystatus --shift; then
set timeout=-1
else
set timeout=0
fi
else
if sleep --interruptible 3 ; then
set timeout=0
fi
fi
fi
### END /etc/grub.d/30_os-prober ###
### BEGIN /etc/grub.d/40_custom ###
# This file provides an easy way to add custom menu entries. Simply type the
# menu entries you want to add after this comment. Be careful not to change
# the 'exec tail' line above.
### END /etc/grub.d/40_custom ###
### BEGIN /etc/grub.d/41_custom ###
if [ -f $prefix/custom.cfg ]; then
source $prefix/custom.cfg;
fi
### END /etc/grub.d/41_custom ###
=============================== sda2/etc/fstab: ================================
# /etc/fstab: static file system information.
# Use 'blkid' to print the universally unique identifier for a
# device; this may be used with UUID= as a more robust way to name devices
# that works even if disks are added and removed. See fstab(5).
# <file system> <mount point> <type> <options> <dump> <pass>
proc /proc proc nodev,noexec,nosuid 0 0
# / was on /dev/sda2 during installation
UUID=26d36caa-7d60-4f39-afd6-1c596a6552a3 / ext4 errors=remount-ro 0 1
# swap was on /dev/sda1 during installation
UUID=1fc11ecd-0735-4c85-bbf3-a6b2e1f94ce4 none swap sw 0 0
=================== sda2: Location of files loaded by Grub: ====================
GiB - GB File Fragment(s)
= boot/grub/grub.cfg 1
= boot/initrd.img-3.0.0-12-generic 2
= boot/vmlinuz-3.0.0-12-generic 1
= initrd.img 2
= vmlinuz 1
=========================== sdb1/boot/grub/grub.cfg: ===========================
if loadfont /boot/grub/font.pf2 ; then
set gfxmode=auto
insmod efi_gop
insmod efi_uga
insmod gfxterm
fi
menuentry "Try Ubuntu without installing" {
set gfxpayload=keep
linux /casper/vmlinuz file=/cdrom/preseed/ubuntu.seed boot=casper quiet splash --
initrd /casper/initrd.lz
menuentry "Install Ubuntu" {
set gfxpayload=keep
linux /casper/vmlinuz file=/cdrom/preseed/ubuntu.seed boot=casper only-ubiquity quiet splash --
menuentry "Check disc for defects" {
set gfxpayload=keep
linux /casper/vmlinuz boot=casper integrity-check quiet splash --
========================= sdb1/syslinux/syslinux.cfg: ==========================
# D-I config version 2.0
include menu.cfg
default vesamenu.c32
prompt 0
timeout 50
# If you would like to use the new menu and be presented with the option to install or run from USB at startup, remove # from the following line. This line was commented out (by request of many) to allow the old menu to be presented and to enable booting straight into the Live Environment!
# ui gfxboot bootlogo
=================== sdb1: Location of files loaded by Grub: ====================
?? = ?? boot/grub/grub.cfg 1
================= sdb1: Location of files loaded by Syslinux: ==================
?? = ?? ldlinux.sys 1
?? = ?? syslinux/chain.c32 1
?? = ?? syslinux/gfxboot.c32 1
?? = ?? syslinux/syslinux.cfg 1
?? = ?? syslinux/vesamenu.c32 1
============== sdb1: Version of COM32(R) files used by Syslinux: ===============
syslinux/chain.c32 : COM32R module (v4.xx)
syslinux/gfxboot.c32 : COM32R module (v4.xx)
syslinux/vesamenu.c32 : COM32R module (v4.xx)
=============================== StdErr Messages: ===============================
awk: cmd. line:36: Math support is not compiled in
/home/ubuntu/Desktop/boot_info_script.sh: line 1579: [: 2.73495e+09: integer expression expected
Computer science news on Phys.org
Is the bios asking which partition to attempt to boot from?
Nope.
It just hangs at the flashing _ and does nothing.
1. Why can't I boot into anything after installing Ubuntu on Windows 7?
There could be several reasons for this issue. One possibility is that the installation process did not complete successfully, causing the boot loader to not properly recognize the operating systems. Another possibility is that the boot order in the BIOS is not set correctly, causing the computer to bypass the Ubuntu installation. Additionally, it could be a problem with the partitioning or formatting of the hard drive.
2. How can I fix the issue of not being able to boot into anything after installing Ubuntu on Windows 7?
If the installation process did not complete successfully, you can try reinstalling Ubuntu or repairing the installation. If the boot order in the BIOS is the issue, you can access the BIOS settings and change the boot order to prioritize the Ubuntu installation. If the problem is with partitioning or formatting, you may need to use a partitioning tool to fix any errors.
3. Will I lose any data or files if I fix the issue of not being able to boot into anything after installing Ubuntu on Windows 7?
It depends on the specific issue and how it is resolved. If you need to reinstall or repair the Ubuntu installation, you may lose any files or data that were not backed up. If the issue is with the boot order or partitioning, you should not lose any data.
4. Can I dual boot Ubuntu and Windows 7 on the same computer?
Yes, it is possible to dual boot Ubuntu and Windows 7 on the same computer. However, it is important to properly partition and format the hard drive to avoid any conflicts between the operating systems. It is also recommended to install Windows first and then Ubuntu, as the Windows boot loader can sometimes override the Ubuntu boot loader.
5. Are there any alternative methods for installing Ubuntu on Windows 7?
Yes, there are alternative methods for installing Ubuntu on Windows 7. One option is to use a virtual machine software, such as VirtualBox, to run Ubuntu within Windows. Another option is to create a bootable USB drive or DVD and install Ubuntu from there. It is important to follow the proper steps and have a backup of important files before attempting any alternative installation methods.
