Moving faster than light cannot stop biological aging Or can?
In summary: Exactly - that is the biological clock. It is an internal mechanism that is subject to the same laws of physics as everything else....and changes happening around us...The changes happening around us are also subject to the laws of physics, including time dilation. So if a person is moving at a high velocity, the changes happening around them will appear to occur at a slower rate compared to someone who is stationary.So the traveling brother aging would not be affected by his speed, he would just experience changing events in different scales. This is correct. The traveling brother's aging would be affected by his speed because time is relative, but he would experience changes happening around him at a slower rate compared to someone who is stationary.
pingulii
Hi everyone, before I post I apologize for my bad English!
I am not a physicist but I am interested in this stuff (I've read relativity theory and...)
But I have a question regarding time traveling
Imagine that it is true that we can travel at speed of light...So here is the famous example of identical twins:
one of whom makes a journey into space in a high-speed rocket and returns home to find that the twin who remained on Earth has aged more.
it could be that, aboard the space-ship, two years of flight-time have passed - on-board clocks and calendars show that two years have elapsed, and both spaceship and traveling twin have aged by exactly that amoung of time. On Earth, however, a whopping 30 years have passed between the spaceship's departure and its return. Just like all other humans on the planet, the twin on Earth has aged by 30 years during that time.
So here is my question:
Does the brother who was on the space looks younger? I mean his face? is it true that one of them looks like a child while the other one looks like an adult? Does biological ageing like growing cells and chemical reactions in our body go slower like time?
Or it is just a matter of relativity meaning that they just had different experience of time and both of them are look the same regarding their face and body?
Yes! The traveling brother really is younger.
Do you know why? why do you say that? any proof or logical explanation?
You seem to accept that ordinary clocks carried by the traveling brother would show less time. Why do you think that biological "clocks" would work differently? (All temporal processes show the same effects.)
Likes 1 person
If clocks slow down then so must biological aging, according to the first postulate of relativity.
DaleSpam said:
to understand how we make the jump from light clocks to time in general you need to consider the first postulate:
Imagine that we have a light clock, an atomic clock, a piezoelectric quartz clock, a windup spring clock, and a rat with a really steady heartbeat. All are clocks working on different physical principles. Because the laws of physics are the same in all inertial reference frames (first postulate) if they all beat at the same rate in one frame they must all beat at the same rate in any other frame. So, in an inertial frame where the clocks are moving at relativistic velocity, because the light clock slows down the other clocks must also slow down or the laws of physics would be different. Therefore, because any physics expression with a "t" in it must slow down, we say time slows down.
Likes 1 person
So you think our body clock (our heartbeat or biological clock) works as a CLOCK? you consider it as a kind of TIME? what if our body is different with what we think? I mean what if aging process does not follow physics principle?
I think the consent of time that we have about ourself is something like interior feeling of changes of our organs and changes happening around us... So the traveling brother ageing would not affected by his speed, he would just experience changing events in different scale
Imagine two person are given 100 years of living in our planet. Mr.A start traveling at speed of light. Mr.B start a normal life.
I think Mr.A would die just in one week which is equal to 100 years on living of Mr.B...They would die together !
we've tried this experiment - not with people, but with various subatomic particles of known lifetime. It doesn't work the way you're expecting - the moving particles die after the stationary ones, in exactly the way that relativity predicts.
Likes 1 person
Yes. Definitely.
That simply is not the case. The human body obeys the laws of physics. If you step off a building the human body is subject to gravity and will fall. If you grab an electrical wire the human body is subject to electromagnetism and will conduct current. If you swallow a radioactive substance the human body is subject to the strong and weak nuclear forces and will radiate. The body is subject to all of the laws of physics and all of the laws of physics demonstrate time dilation.
As Nugatory mentioned this experiment has been done with particles and your thought is contrary to the actual measured behavior of the universe.
Likes 1 person
If a light-clock slows down then aging must too. Otherwise you get different outcomes, for different observes.
Imagine you are locked in a cage. The lock is controlled by a light clock, that opens after 1 day in your frame so you walk out. An observer who moves fast relative to the cage will observe the light clock slown down and open after 1000 years. If he wouldn't observe your aging slown down, he would see you die in the cage. But that contradicts the fact that you walked out of the cage.
Interesting.
I wish I were Physicist
So just to know more, would the effects of traveling at speed of light on ageing and time, happen in slower speed?
For example if you travel with a car at high speed you are getting older slower than a person who walks?? or no you should be out of planet Earth to see this happening?
Yes, although the effect is too small to notice at those speeds. Time dilation is just barely detectable with the most sensitive equipment (yes, this experiment has been done too) with clocks carried in jet aircraft.
pingulii said:
Moving faster than light cannot stop biological ageing! Or can?
I find it a bit odd that no one has commented on the subject line of your post. It is impossible for anything with mass to travel AT the speed of light, much less faster than light. All of the discussion above is about situations traveling SLOWER than light.
Yes you are right, I wanted to change the topic but I couldn't. Sorry about that but all the discussions are what I was searching for
Talking about most sensitive equipment, like atomic clock, I was wondering how this clock works?
I know it uses the resonance frequencies of atoms and the resonator is regulated by the frequency of the microwave electromagnetic radiation emitted or absorbed by the quantum transition of an atom...but how they measure this frequency? I mean how they change it into time scale? like seconds!?
That part is simple. The period of the radiation is 1/frequency, and the period of the radiation has units of seconds.
So you can either measure the frequency and convert it to a period, or measure the period, and you get units of seconds.
Likes 1 person
I guess I have to understand the nature of time! I think it is the changing states of matter and energy. and it is nonsense without moving, something like space-time, but does it really true? is this the true concept of time? or is there any scientific definition of time and its nature and concept?
According to Einstein, time is what clocks measure. Distance is what rulers measure. Slightly suprisingly, the two concepts aren't completely separate.
That's about all there is to know about the nature of time.
yes time is what clocks measure but it is not its nature, it is just device for human to make it understandable, kind of agreement. I'm looking for its nature, from where it is stemming?
That's not a question physics can answer.
The point is that you do not need to understand "what time is" to understand relativity. No one understands that. All you need to know is that there is something that clocks measure in a consistent fashion.
Explanations may (or my not) be forthcoming when we manage to unify relativity and quantum mechanics. If there is an explanation, though, expect it to be underpinned by something else that "just is" without any more explanation. That's the way science works, as Vanadium50 pointed out.
Likes 1 person
What is the theory behind moving faster than light and its effect on biological aging?
The theory behind moving faster than light is based on Einstein's theory of relativity, specifically the concept of time dilation. Time dilation states that time moves slower for objects that are moving at high speeds, such as near the speed of light. This means that if an object were able to travel faster than light, time would essentially stop for that object, preventing biological aging from occurring.
Is it possible for humans to achieve speeds faster than light?
At this point, it is not possible for humans to achieve speeds faster than light. According to Einstein's theory of relativity, an infinite amount of energy would be required to accelerate an object to the speed of light, making it impossible for humans to reach this speed.
What are the potential consequences of traveling faster than light on the human body?
While it is purely theoretical at this point, if humans were able to travel faster than light, the potential consequences on the human body could be severe. The extreme forces and radiation exposure that would be experienced at these speeds could have damaging effects on biological tissues and DNA.
Could moving faster than light be a way to achieve immortality?
This is a highly debated topic among scientists and philosophers. Some argue that if time dilation were possible and one could travel faster than light, then biological aging would stop and immortality would be achieved. However, others argue that even if biological aging were halted, there are other factors such as accidents, diseases, and natural disasters that could still lead to death.
What are some current scientific advancements in the study of time dilation and faster-than-light travel?
Currently, there are ongoing experiments and research being conducted to better understand the concept of time dilation and its potential effects on the human body. Some scientists are also exploring the possibility of using wormholes or other forms of advanced propulsion to potentially travel faster than light. However, these advancements are still in the early stages and much more research is needed before any concrete conclusions can be made.
