How is it we know the speed of light?
In summary, the conversation discusses the concept of measuring the speed of light and how it relates to our relative movement in the universe. It raises questions about whether we can truly determine the speed of light without a fixed reference point and how our own movement affects our perception of it. The theory of special relativity is mentioned as an explanation for the constant speed of light in all reference frames. The conversation also touches on the practical methods of measuring the speed of light, such as using a mirror and equations from electromagnetic fields.
whocouldshebe
35
I don't see how we can say the speed of light is X value. Here's why:
Imagine you are driving 50mph then a cop comes up driving beside you at 50 Mph too. If he aims his gun out his window and clocks you it would read 0 Mph right? So to get your real speed he would have to look at his own speedometer first to determine his speed in relation to the Earth's surface beneath his vehicle no?
So if the Earth is spinning around the axis at X, slinging around X miles per hour in our solar system, and our solar system is slung around our galaxy at X unknown miles per hour, and our galaxy shoots around the universe at X unknown miles more, even then we still have to ask, is our universe traveling at X speed through a Mega-verse, then how is it that we can say the speed of light is always X without comparing that in relation to something that isn't moving at all in the mega-universe stopped or at least start calculating the velocity of our speedometer in relation to such a non-moving point in space, if one even exists.
We don't even know the size of the universe, nor where the center point is, so how in world can we say that light travels across the universe at X miles per hour, heck, we don't even really know how long an hour is since time is relative, from that vantage point isn't light different speeds at different locations all over the universe as is relative to the speed of the non-stationary locations of a speed detector? I mean sheesh, if I were a particle of light, I would think "I" light travel at 0 miles per hour, am the center of all things, and consider everything else around me here on Earth to be moving at the speed of 'mass' or 299,792,458 m/s, the exact opposite, you know, like when your car is stopped at the light, then the car beside you moves so you think your are moving, but nope, they are. Maybe light is stationary, that's why it doesn't need energy to move through space, and lives forever, because it is sitting in one place until we matter slam into it at the speed of light?!
It doesn't make a bit of sense at all when you think about it... Why do we always consider ourselves to be the stationary center that can judge the speed of all things when clearly it is we that are in a constant state of movement expending tons of energy that we can calculate to keep us in motion?!
It makes more sense to say light moves at 0 mph, we are in fact the ones in motion!
Science news on Phys.org
I really did not read your entire post, its more like a rant than science, as for measuring the speed of light, you could easily measure time time light takes to reflect from a mirror and get back to the source, and using the distance between the reflector and source, find the speed of light.
Also there are many other relations from where c can be measured, you could measure the ratio of the magnetic and electric field amplitude of a EM wave, and the ratio and the value of permittivity or permeability of space would give you the speed of light.
You could measure the energy released when mass defect takes place, and equate it to m*c^2
Also measuring the wavelength and frequency of an EM wave in space.
You really need to read a book on special relativity. This was an issue with Maxwell's equations in the late 19th century. People wondered, in what frame of reference are these equations correct. This led to false ideas about the ether.
Einstein came along to solve the issue. He claimed that in all inertial reference frames (frames of reference moving with a uniform velocity where Newton's law of inertia is still valid) you will measure the same speed of light no matter what.
So, if you are on the ground and throw a baseball at 50 mph, then make the same pitch while on a moving car going 50 mph, the baseball will be traveling at 100 mph. However, if you turn on a flash light standing still you will see it leave you at the speed of light. If you also watch someone turn on a light while they are moving 50 mph relative to you, it will still be going at the speed of light, not 50 mph greater.
This creates some really strange physics. First of all, you and the guy driving in the car will effectively measure the speed of light to be the same. This seems impossible, but it isn't. There is so many more consequences of this fact. That I'm not going to say any more, you just need to read up on special relativity. Also, if you don't believe me and you claim it's impossible, tell that to the thousands of experimental physicists who show everyday that special relativity is scientific fact.
I will throw in one more interesting thought experiment though:
Imagine you are on the ground next to a train traveling at .75 times the speed of light. Also, imagine you can see inside the train. Now, on the train someone throws a baseball in the direction of the train's movement at .75 the speed of light. You can't just add the velocities to get 1.5 times the speed of light. Effectively what happens, is you observe the people on the train to be passing through time at a slower rate than you are. You will see them moving slower, you will see them throwing a baseball slower. No matter what, you can't violate the ultimate speed limit of light.
singhvi - that doesn't make any sense because both mirrors are moving here on Earth but we don't know in what direction in relation to a non-moving position in space time since we don't have anything to compare it to.
silmaril89 - Oh, yeah, that makes sense, because time stops for the observer from their point of reference if they are light, and why light speed is a constant, no matter how you look at it, as zero or infinite, they both give the same answer when used in a calculation if time is relative to the observer and the calculations are done from an outside point of reference considered stationary, I just always see things from light's point of reference.
I've never read anything on relativity, was just thinking, but I read up on special relativity just now, Galileo & Einstein clearly state the same as me in their definition: "there is no absolute and well-defined state of rest." Nope not for anything that exists in the universe there isn't it just simplifies things to me to think everything is infinitely fast except light which doesn't move, and gravity as like a kind of vacuum of nothingness that wants to be filled with whatever concentrated mass nearest by first-most.
I always try to simply things to their simplest form so I don't have to remember crazy complicated formulas to understand the simple world around me.
Thanks.
The cool thing about the speed of light is that it is always the same, regardless of the speed of the observer. That's the primary point in Einstein's special relativity.
No problem. The fact that the speed of light is the same for all observers makes it so there is not one "rest" frame. There is no better reference frame than anyone else.
This was a good question for not having any knowledge of special relativity. It was a very puzzling questions for many physicists until Einstein came along. Before him, they had an idea called http://en.wikipedia.org/wiki/Luminiferous_aether"
Special relativity brings up another question I've had on my mind, how is it that we know we are where we currently are in our galaxy/universe if our changing views of space-time as a traveling observer tell us were are absolutely positively not located right here right now where we perceive ourselves to be located?
For example it appears we are currently close to crossing the axis of our galaxy, but it takes years for anything to reach us here where are, and we don't know our current velocity in the galaxy, so how is it we can make a map of the galaxy and label the planet Earth as X "you are here" like a mall map or something. Can our computers really compensate for all the space-time curvatures between here and the other side of this galaxy so easily?
I'm reading about the aether now. This should be fun.
Quick question. Say light is emitted from a stationary frame, and is detected later in another frame that is moving 75% the speed of light directly away from the original frame.The 2nd frame is 1 LY away when the light is first emitted. It will take much longer for light to reach the 2nd frame compared to if the frame was stationary at 1 LY, correct?
We do know our current velocity through the galaxy. While the distances are immense, the time it takes for light to cross back and forth is MUCH MUCH faster than speed of anything moving around the galaxy. Yes, the lag in position due to the speed of light is able to be compensated for, as it is not THAT much anyways compared to the scale of the galaxy.
I'm not worried about the time it takes for light to travel here from other point, that is easily compensated for I'm sure, I'm worried about the effect space-time has on light and/or the radio-waves we use to estimate where things are actually located on the other side of the galaxy. The smallest planet between here and there, a large black hole, or medium sized star can and will cause space-time to curve depending on it's concentrated mass. Since we can't guess, see, nor detect and calculate all the masses that might be between here and the other side of galaxy it should be by all means impossible to actually know where things are located even more so on the exact opposite side of the center, much less, where we are located in relation to them. Calculations cannot even be close to correct, and when I say not even close I mean, at least 1-3% error, so we could actually be hundreds of light years away from where our computers calculate us to be. Our current location can only be a close estimate at best...
Sure, our position is most likely off by at least a few light years depending on where you are measuring from. Most of that is due to limitations in the way we determine distance on a galactic and universal scale, not on the light itself. Most of space is pretty empty. Almost all of the light from any visible stars we can see is taking an almost undisturbed trip straight to us. Even if there was a black hole between us and something else, they immense distances between everything means that unless the black hole is DIRECTLY between us and that star, the light is almost entirely unaffected.
Also, overall the combined affects of gravity on light results in no net change, as on a galactic and universal scale things are mostly homogenous over very large distances. Everything "cancels" everything else in effect if that makes sense.
You have to take time dilation into account since the frame is moving at 75% the speed of light with respect to the other frame.
WannabeNewton said:
You have to take time dilation into account since the frame is moving at 75% the speed of light.
I know. Maybe I forgot to say that I want to know how long it takes from the frame of reference of the stationary frame. Or am I misunderstanding something? Can you determine "when" the light is detected at the moving frame and compare it to a non moving frame?
Depends, from your point of view, for the light, it would arrive at the moving frame the same time it left, from the moving frames point of view would arrive 1 LY later no matter how far it travels since times slows for it as it get faster, but from our point of view, as the stationary frame it would take longer than 1 LY to reach the moving frame.
The way I see it though, we are wrong, it takes 1 LY no matter what to get there, since light is constant, we just perceive that it took longer to get there because we are moving away from both the frames at a relative velocity, if that makes any sense.
A lightyear is a unit of distance, not time. But I think I undestand what you are saying.
You say the second frame is 1LY away when the light is first emitted. But you haven't said which frame this distance is measured in. The distance is different when measured by the 1st and 2nd frames.
To answer the question, yes it takes longer for light to go between two points that are moving away from each other than for two points that are stationary with respect to each other
(Think about it) the speed of light is finite, and the separation between the points is increasing with time, so light takes longer to travel between the two
I like Tesla's aether better...
And as far as our location using light as a point of reference, we know something really huge, most probably a black hole or bigger is at the center of every galaxy, so the sling-shot effect of the light we do receive here on Earth is most likely huge. The stars we see bundled up in the middle could be practically anywhere until we know exactly what IS at the center and can enter some real formula to compensate for it.
It would take 1 & 1/3 LY for the moving object to reach the other stationary frame but only 1 year would pass for the moving object, to put it simple, I assume that's how they measure light years, but I would think the moving object would only see 1/3 of a year pass, which is right?
That's what I was thinking. I had just never seen anyone ask it before and wanted to make sure.
It would take 1 & 1/3 LY for the moving object to reach the other stationary frame but only 1 year would pass for the moving object, to put it simple.
We aren't using light as a point of reference, we are using ourselves and measuring everything else in relation to that. And no, the slingshot effect from the black hole at the center of the galaxy is EXTREMELY small. If it was strong enough to greatly affect light all the way out where we are at, the entire galaxy would be pulled into the black hole, which is not happening.
Edit: Also, we do have a very good measurement for the black hole in the middle of the galaxy. We have measured the velocity of the nearby stars orbiting it and have been able to determine a good estimate of its mass. See here: http://en.wikipedia.org/wiki/Sagittarius_A*
Thanks.
it doesn't matter as long as the mirrors and the source/observer are stationary relative to each other. peace
Uh, yes it is happening, we are being pulled into the back hole just like water spins around the drain before it goes in, we do see it happening, that's like saying we can't see the effect of the suns gravity on earth, yet obviously it is super strong to be able to hold us in orbit at this distance, well the mass at the center of the galaxy is so super strong that our whole solar system spins around it at this distance, even black holes spin around the center of our galaxy under it's grip, and we already know light curves around a black hole, so much so that we cannot see what is on the other side, there's no telling how much it curves around the center of the galaxy since we can't even fathom the massive force of gravity that would have be there to cause all the stars and planets in the sky to spin around it at this vast distance.
The force of gravity is still ridiculously strong over this vast distance! Everything we can see is slingshot around it, to say that is EXTREMELY small seems very odd. So what is more powerful than gravity that we know of in the universe?
The way I look at it, take a bowling ball, tie it to a string, then spin it in a circle over your head, now add a million balls and spin them around on a million strings at millions of miles an hour, you'd have to have one really strong arm to do that, not an extremely weak one.
Now tie the string to the feet of millions of people that are each spinning millions of bowling balls around themselves, and spin those millions of people around your head and sling them out millions of miles away. That's how I envision the center of our galaxy.
I can't even fathom what the pull must be at the center of the universe.
By the time light reaches us across the center the point departure has to be totally messed up; however, little things like stars and tiny black holes are no doubt small in comparison so we could guess fairly close to where things might actually be on the other side.
But at the center of the galaxy, it has to be guesswork at best...
No the gravity of the galaxy is caused by all the stars and dark matter within it.
The gravity due to the supermassive black hole in the middle is almost negligible in comparison.
Yeah but there isn't any dark matter in our solar system, and it sticks together just fine, and no one would dare say that the gravity due to the sun in the middle of our solar system is almost negligible. Why people have to invent dark matter is beyond me when we already know matter curves matter in significant large detectable proportions, just as a magnet does. Bring me piece of dark matter and we'll measure how just strong it's pull is. LOL
I'm thinking I'll get into this in the other space forums later with new questions.
I got the original question answered. We assume all things are in motion since we don't know what is stopped and what isn't, but at the speed of light time stops so we use that as our constant to determine distance. That's what I needed to get out of this.
This is incorrect. The black hole in the middle of the galaxy is probably the most massive object in the galaxy, but it does not cause everything to orbit around itself. The mass of the entire galaxy is much much more. It is this mutal attraction that holds everything together. (That plus dark matter perhaps) The difference between the galaxy and our solar system is that the sun makes up over 99% of all the mass in the solar system. Also, we are not being pulled into it like water down a drain any more than the sun is pulling the Earth into it. In both cases we are in a stable orbit.
Your view on how gravity and black holes works is severely lacking. I suggest you hit up wikipedia or somewhere and read those a few times.
This is entirely incorrect. The only reason everything in the galaxy stays together is because the force of gravity holds it against the kinetic energy. If we were to double the speed of everything in the galaxy it would fly apart. And if you look at the relative strength of the 4 fundamental forces of nature, gravity is by far the weakest.
Every bowling ball is tied to every other bowling ball, not just to one spot in space.
Again, given the vast distances in space, the effect is very minor unless a massive object is directly between the source and yourself. Almost all light that makes it through to us from the other side of the galaxy does not have to travel through the center of the galaxy.
There is no frame of reference for something traveling at c. We cannot say that time stops. It is simply not possible to know because our math breaks down at that point. Also, you seem to have no idea what dark matter is or why we say it exists. Again, I would suggest looking this up and finding out why.
Drakkith is right, if you use special relativity to see what happens in the frame of reference of the beam of light, the equations explode. All time intervals and all distances become infinite.
Hah, this made me laugh and picture exploding equations flying everywhere! Get down! Here comes pi!
I hope its apple ^_^
Even if there is a black hole that changes the path of the light making it need more time to get to us, it does that by bending space itself, and that means that the distance is also bigger. So I would think that the time light takes to get to us still shows the distance between us and the star.
whocouldshebe, you have mentioned both the "axis" and the "center" of the universe. There are no such things. I don't know if that is contributing to your confusion, but you should get straight about those two facts. There is no axis and there is no center. There IS a center to our OBSERVABLE universe and we are by definition, that center.
1. How was the speed of light first measured?
The first successful measurement of the speed of light was conducted by Danish astronomer Ole Rømer in 1676. He observed the moons of Jupiter and noticed that the time between eclipses of the moons varied depending on the distance between Earth and Jupiter. By measuring these variations, Rømer was able to calculate the approximate speed of light to be 220,000 kilometers per second.
2. How is the speed of light currently measured?
Today, the speed of light is measured using a variety of methods, including using lasers and mirrors, interferometers, and particle accelerators. One of the most accurate methods is the use of a laser interferometer, which measures the time it takes for a laser beam to travel a known distance and reflect back. This method has allowed scientists to measure the speed of light with an accuracy of 0.00000000001%.
3. How does the speed of light relate to the theory of relativity?
The speed of light plays a crucial role in Einstein's theory of relativity. According to the theory, the speed of light is constant and the same for all observers, regardless of their relative motion. This means that the speed of light is a fundamental constant of the universe and is not affected by the motion of the source or the observer. This concept has revolutionized our understanding of space and time.
4. Can the speed of light be exceeded?
According to the theory of relativity, the speed of light is the maximum speed at which energy, matter, and information can travel. No object with mass can reach or exceed the speed of light. However, some theories, such as the Alcubierre drive, propose ways to circumvent this limit by manipulating space-time. However, these theories are still hypothetical and have not been proven.
5. How has our understanding of the speed of light evolved over time?
Our understanding of the speed of light has evolved significantly over time. In the early 17th century, it was believed that light traveled instantaneously. It wasn't until the late 19th century that scientists began to measure the speed of light accurately. In the 20th century, Einstein's theory of relativity revolutionized our understanding of the speed of light and its role in the universe. Today, the speed of light is a fundamental constant in physics and continues to be a topic of research and exploration.
10K
  • Optics
  • Optics
