How to study feedback? Which branch of Mathematics does it?
In summary, studying systems with feedback between variables is a complex task as there are no independent variables and every input affects the overall system. Differential equations, signal processing, and control systems are useful tools for understanding these systems. Control theory deals with inputs to dynamical systems and the resulting feedback, making it a valuable interdisciplinary approach. Experiments can also be conducted using computer simulations and system identification to estimate parameters that control the behavior of the system.
jonjacson
447
38
Hello,
I want to study a system, and I have realized that all variables in it are dependent. There is no independent variable. So everytime you modify the input, you get an output but at the same time that output modifies the input itself, there is an important feedback. So the system apparently is evolving searching a kind of equilibrium but it does it in several steps and I find it difficult to "isolate" one variable, or analyze what is the relationship between variables since they are affected by the rest of the system.
I will try to put an example, hopefully it will show the main characteristics I am talking about.
In the atmosphere if there is a raise in the amount of energy that arrives from the sun, the temperature raises. But that changes the amount of water the air can contain, and that modifies the amount of radiation that the atmosphere absorbs which is the factor we started analyzing.
My question is, What is the best mathematical tool to understand systems where feedback between variables is key?
Another example:
Would you use differential equations? Variational calculus?
Mathematics news on Phys.org
Is this not Chaos theory, essentially?
It has nothing to do with Chaos theory unless the system happens to be chaotic, and many systems as complex as the OP's picture are not.
Differential equations, signal processing (analog and digital), and control systems (stability analysis, etc) would be good topics to start learning. You may need some probability theory as well.
With 'feed back', this would be "non-linear differential equations" or, more generally, "non-linear analysis".
It's not 'chaos theory' you are looking for, but 'control theory' which deals with inputs to dynamical systems and the resulting feedback:
http://en.wikipedia.org/wiki/Control_theory
It's not a branch of pure mathematics which deals with feedback, but a blend of math and engineering, an inter-disciplinary effort.
Well, I don't know if the system is chaotic or not. It is complex for sure. I guess a small change could have a big impact on other variables but this is only guessing.
Thanks, I will try to learn that.
Thank you very much. That looks very interesting.
I have a question about this, Can people using control theory do experiments?
I mean, in mechanics you could go to a laboratory and analyze a pendulum. But the problem is that I can't do any experiment, it is like the atmosphere, you can't stop it and analyze any specific variable.
Everything is mixed together and evolving constantly in time. The same problem you have in astrophysics, you can't stop the universe nor isolate a galaxy, I can just watch everything mixed and changing in time.
Does that matter for control theory?
Sure. For example one of the "standard" experiments is to design a system that will balance an inverted pendulum on a moving cart. Making a computer simulation would probably be a good thing to do first. Then build the real world system and get it working!
https://www.youtube.com/watch?v=AuAZ5zOP0yQ
You can't easily experiment with a system like the Earth's atmosphere, but you can collect data and use it to estimate the parameters that control how the system behaves. That procedure is called "system identification".
That looks exactly what I was looking for. Thanks.
What is feedback?
Feedback is information or reactions about a product, service, or performance that is provided to the creator or performer from an outside source.
Why is studying feedback important?
Studying feedback allows for improvement and growth in a product, service, or performance by identifying areas of strength and weakness. It also helps to understand the needs and preferences of the target audience.
What methods can be used to study feedback?
There are various methods to study feedback such as surveys, focus groups, interviews, online reviews, and data analysis.
Is there a specific branch of Mathematics that is used in studying feedback?
While feedback can involve mathematical concepts such as statistics and data analysis, it is not specific to one branch of Mathematics. It is a interdisciplinary approach that combines elements from various fields.
How can the results of studying feedback be applied?
The results of studying feedback can be applied in various ways such as making improvements to a product or service, targeting specific marketing strategies, and enhancing overall performance and customer satisfaction.
  • General Math
  • Electrical Engineering
  • Quantum Physics
  • General Math
  • Set Theory, Logic, Probability, Statistics
