How is coating with an oxide oxidation
In summary: Oxidation is the process in which oxidation number of an element goes up. For example, metallic Al gets oxidized to Al(III) by the air oxygen and - in the process - gets covered with the oxide.Coating with the oxide can be an effect of the oxidation, but it is not an oxidation itself.
caters
229
I looked up the word oxidize and one of the definitions is to make it an oxide which is what happens when iron gets rusty(even though there is also iron hydroxide in rust).
Another was to coat with an oxide. Now how is coating with an oxide oxidation?
Does it catalyze the oxidation by making it easier for oxygen to get to whatever is being oxidized without the oxide being reduced and if so is the speed of the reaction the same or faster?
Does the oxygen from the oxide go to what is being oxidized so that more oxygen can come in and oxidize it faster with the oxide getting reduced?
Does the oxide and whatever is being oxidized form an oxidized complex?
examples:
Iron oxide coating on copper
Aluminum oxide coating on Iron
Chemistry news on Phys.org
when iron oxidizes, the oxidation layer keeps growing, completely consuming the object during the oxidation process. Iron rust is very porous, so oxygen can pass through the rust to reach the un-oxidized iron. Aluminium oxide for example is much more dense and very stable at room temperatures. It forms an impenetrable oxide layer and the aluminium will not oxidize further because oxygen cannot pass through the protective oxide layer. In principle you can protect iron by coating it with a thin layer of aluminium oxide.
yes but I looked up what oxidize means and one of the definitions is to coat with an oxide.
Where have you seen this definition? I think you may be misreading your source. Coating with the oxide can be an effect of the oxidation, but it is not an oxidation itself. Oxidation is a process in which oxidation number of an element goes up. For example, metallic Al gets oxidized to Al(III) by the air oxygen and - in the process - gets covered with the oxide.
Dictionaries like Dictionary.com say that there are 2 definition for oxidize besides loosing electrons. The first definition they have is the formation of an oxide and the second definition of it in the dictionaries is to coat with an oxide.
It is not intended to mean "cover with an oxide added as a separate substance to the surface" but "cover with an oxide produced during oxidation of the metal below".
1. How does coating with an oxide prevent oxidation?
Coating with an oxide creates a barrier between the metal surface and the surrounding environment, preventing oxygen and moisture from coming into contact with the metal and causing oxidation.
2. What type of oxide is commonly used for coating?
Aluminum oxide is the most commonly used oxide for coating because it is highly resistant to corrosion and has a high melting point.
3. Can coating with an oxide increase the lifespan of a metal object?
Yes, coating with an oxide can significantly increase the lifespan of a metal object by protecting it from oxidation and other forms of corrosion.
4. Is coating with an oxide a permanent solution for preventing oxidation?
No, coating with an oxide is not a permanent solution as the coating can wear off over time. However, regular maintenance and reapplication of the coating can prolong the protection against oxidation.
5. Are there any disadvantages to coating with an oxide?
One potential disadvantage of coating with an oxide is that it can add an extra layer to the surface of the metal, which may affect its appearance or functionality. Additionally, some types of oxide coatings may require specialized equipment or processes for application.
  • Chemistry
