Sound travelling without any disturbances?
  • Thread starter adjacent
  • Tags
    Sound
In summary, sound is a longitudinal wave and can be disturbed by other sounds. Our voices can be drowned out by louder noises. The linearity of the equations describing the behavior of sound waves in air, over the range of amplitudes and frequencies that humans can hear without being damaged by them, is "something special". However, using linearized approximate models in physics is so common that it's easy to forget how "special" they are. Additionally, there is probably an anthropogenic principle here - if "sound waves" behaved in a nonlinear way so they were no use for communication, humans and other animals would be using something different to communicate!
adjacent
63
As we all know, we are always surrounded by a "sea" of sound(Of cars,air,farts etc :wink:. Lol)
How can our voice be transmitted by the air without getting disturbed by other sounds?
Sound is a longitudinal wave. So imagine another wave traveling perpendicular to our wave. Then at the point of intersection, there will be movement of air in both forward-backward and right-left. So the sound wave should be disturbed here. Am I wrong?
It's not clear by what you mean when you ask, "How can our voice be transmitted by the air without getting disturbed by other sounds?"
Our voices can be drowned out by louder noises. (Ever try to carry on a conversation behind a roaring jet engine?)
If you are asking how we can 'distinguish' a voice from other noises in the background, that's something the brain does for us.
I don't think you understood what I meant. See this image of two sound waves traveling in perpendicular directions to each other
What will happen in the circled area?
There's nothing special there. It is still a superposition of both waves, even when they are perpendicular to each other.
Have you never seen waves in ripple tanks before?
http://www.555electronics.com.au/scanripple2.jpg
Look carefully. As some point, the wave fronts from each of the two sources are moving perpendicular to each other.
Zz.
Likes 1 person
Sound waves, just like waves in ripple tanks and waves in strings, do in fact interfere with one another. However, at commonly encountered amplitudes the effect is very very tiny and can be ignored.
Likes 1 person
I see. Thanks everyone!
The fact that the equations describing the behavior of sound waves in air, over the range of amplitudes and frequencies that humans can hear without being damaged by them, are linear (in most situations) is "something special". But using linearized approximate models in physics is so common that it's easy to forget how "special" they are.
Also there is probably an anthropogenic principle here - if "sound waves" behaved in a nonlinear way so they were no use for communication, humans and other animals would be using something different to communicate!
How is this relevant to the topic of this thread?
The "specialness", or lack of it, that I referred to was not in the range of frequencies, but rather in the DIRECTION of propagation!
Zz.
I think the relevance is that the (non)linearity ("specialness") of the waves is a function of both amplitude and wavelength (i.e., frequency).
Read the OP. Please point to me why this is relevant.
Zz.
The OP asked why voices aren't disturbed by other ambient sounds. One good answer is that sound waves are fairly linear at the amplitudes and frequencies that we typically encounter. The corollary is that waves which cross perpendicularly won't affect each other even though it seems like they should.
If the nonlinearity is significant, plane acoustic waves crossing perpendicularly does seem to be an interesting special case.
BTW, why did you assume that I didn't read the OP?
Because it appears as if you didn't read the explanation that was given in Msg. #3 that clarified what the OP was looking for! He clearly wanted to know what happened when two perpendicular wavefronts meet!
My reply was that there's NOTHING SPECIAL about this when compared to other angles, since the principle of superposition works the same way. I even showed a picture where superposition/interference occurred at many different angles.
Somehow, my use of the term "special" got picked up and now we're talking about linear regime of the frequency and sound range of human ears, which are NOT what I was referring to! I know there is a common tendency of PF threads going off on a tangent, but this is a bit silly!
Zz.
Indeed. See the animations at the bottom of this page http://lie.math.brocku.ca/~sanco/solitons/gkdv_interactions.php for the sort of things that can happen when two strongly nonlinear waves interact with each other.
The green plots are the two waves without interaction (note, for the nonlinear waves the velocity is amplitude dependent, not constant) and the red plot shows the result of the interaction. This can even generate a "tail" moving in the opposite direction to the incoming waves.
By definition, the principle of superposition works for linear waves. For nonlinear waves the principle no longer works.
Because of what I said above, it's crucial to understand that the waves are, indeed, in the linear regime.
If the waves are not in the linear regime, then much more interesting things can happen (as AlephZero explains in the post above).
I give up. Somehow the OP's elementary question and his level of understanding never entered into your consideration when answering such questions.
Zz.
1. How does sound travel without any disturbances?
Sound travels in the form of waves, which can propagate through a medium such as air, water, or solids. If the medium is uniform and undisturbed, the sound waves can travel without any disturbances.
2. What factors can cause disturbances in sound travelling?
Disturbances in sound travelling can be caused by changes in the medium, such as temperature, pressure, or density. Other factors like obstacles, wind, or turbulence can also disrupt sound waves.
3. Can sound travel without any disturbances in outer space?
No, sound cannot travel in the vacuum of outer space because there is no medium for the sound waves to propagate through. In space, sound can only be transmitted through electronic devices or vibrations in objects.
4. How does the speed of sound affect its ability to travel without disturbances?
The speed of sound is dependent on the properties of the medium it is travelling through. In denser mediums, sound can travel faster and with fewer disturbances, while in less dense mediums, sound can be slower and more easily disrupted.
5. Can sound travel without any disturbances over long distances?
Yes, sound can travel over long distances without significant disturbances as long as the medium remains uniform and undisturbed. However, factors like wind and temperature changes can affect the speed and quality of sound over long distances.
  • Mechanics
  • Mechanics
  • Astronomy and Astrophysics
