Magnetic Levitation energy problem
In summary, the conversation discusses the feasibility of using magnetism to levitate a 180.0 kg mass using the Earth's gravitational field. The equation for Magnetic Pressure and Electrical force is mentioned, but it is noted that the Earth's magnetic field is too weak for this to work. Suggestions for using electrostatic forces or superconductors are brought up, but it is determined that the force required for levitation is too large to be practical. The question of using a charged piece of metal and the need for a solenoid with a large diameter are also discussed. In the end, it is concluded that the idea is not feasible without using superconductors.
HeliosRX
OK, this'll be my first post here.
I was writing on a topic about magnetism when I realized that I simply don't know enough to answer the question effectively.
The question is,
How much energy does it take to magnetically levitate a 180.0 kg mass using the Earth's gravitational field? (That is, using electricity to power an electromagnet to generate another magnetic field)
Some searching gave me the equation for Magnetic Pressure and Electrical force, but I don't understand how to solve this problem.
A prompt reply would be appreciated.
Thanks!
Hmmm. The problem is that the Earth's magnetic field is very very weak. I saw a thread or two on this in the past and while I don't remember the details I do remember that it required a huge amount of power. So much that I don't think it was possible to levitate something that carried it's own power source.
Unfortunately I don't know how to figure the force required either lol.
i guess use a solenoid to create a strong / almost uniform magnetic field, hang the mass by a wire which is partly in the magnetic field created by the solenoid and run a current through the wire?
I remember setting a similar problem which involved calculating how much current a DC electricity cable would have to carry in order to support its own weight in the Earth's field. The BIL = Force formula was all you needed. You could do the same for your solenoid.
BTW, the answer was a ridiculous value - as you'd expect and which I can't remember - and tells you that the arrangement is self-defeating as you need thick (=heavy) cable to carry the current without melting.
Thanks guys, a ridiculous number is what I'm looking for.
Could you use electrostatic forces to levitate instead and would it be more efficient?
The Earth isn't charged, so it wouldn't work.
Riiiight, silly me.
Given that I'm calculating for a charged piece of flat metal, not a solenoid, do I need to modify the equation
F=IBL
Or can I just get rid of L?
HeliosRX said:
Riiiight, silly me.
F=IBL
Why are you using a charged piece of metal?
*shrugs*
Uh, does it affect my calculations?
High current density, and problems with electric resistance? Use superconductors.
However, the magnetic field of Earth is too weak and too homogeneous to levitate an object just based on this field. It is possible to levitate objects with other magnets. With superconductors, this is quite easy and does not require any power to keep it levitating (well ok, you have to cool the superconductor).
Hi.
You can just use pair of permanent magnet for magnetic levitation.
See Science Olympiad page http://scioly.org/wiki/Magnetic_Levitation .
Regards.
HeliosRX said:
*shrugs*
I'm slightly confused. What exactly are you wanting to calculate?
Hi.
HeliosRX said:
The question is,
The magnetic FORCE should be 180*9.8 Newton. You do not have to think of ENERGY, do you ?
Regards.
OK, let's clarify some things here.
MFB, thanks for the recommendation; For the time being I'm just trying to prove how ludicrous it is to do it without the superconductors. I'm getting a result of about 5.7*10^7 Amperes required to counteract a gravitational force of 1765 Newtons, but I'm not sure my equation is correct. I'm just calculating for F=IB because I'm not using a solenoid, so I don't have a figure for L; does this give me a wrong answer?
sweet springs, I know what the force should be, but I'm trying to figure out if I can simply use F=IBL to calculate Amperage required to levitate magnetically.
I*B is not a force. You need some length scale of your current. However, there is a problem: You cannot create or destroy charges. You always need some way for the charges to return - in the opposite direction, which gives a force downwards.
Therefore, you cannot simply use the homogeneous part of the magnetic field to levitate something. You have to use its variation in space, and this is extremely small (of the order of (50µT)/(5000km)).
To get a force of 1N, you already need something like 10^9 Ampere in a loop with 100m^2 internal area (WolframAlpha query) or 10^5 A with an area of 1km^2.
Superconductors can get current densities of about 10^6A/cm^2, for 10^5 A you need ~0.1cm^2 cable cross-section or ~10g/m cable length (probably more). Ignoring stability issues, this 1km-loop will have a mass of ~50kg and a corresponding force of 500N. As the area scales quadratic with the cable length, scaling the whole system by a factor of 500 would fit - but how do you handle a loop of a really thin wire with a diameter of ~500km?
Maybe you can improve the setup a bit - use better superconductors, use regions with a larger variation of the magnetic field and so on. But the numbers are so far away from any reasonable setup that I would be extremely surprised if that would help.
For regular conductors, something like 10^3 A/cm^2 is more realistic. Don't even try ;).
Ah, thanks.
So it has to be a solenoid, and one with a huge diameter, too. Let me see if I understand your point.
10^9 Amperes * 100 meters^2 * magnetic field of Earth (50 microTeslas/5000km) = 1 Newton of force
Because I want to use a 25-meter^2 area loop, I can just multiply the Amperage by 4 to get the value for 1 Newton, right? That would give me something ridiculous on the order of 4*10^10 Amperes for a single Newton. (o_O)
Am I right?
Right now I'm just calculating for how ridiculous the preposition is. How would using a superconductor affect how practical the premise is?
4 times 10^9 A is just 4*10^9 A, not 4*10^10. Apart from that, you are right, the product of current and area determines the force, if you keep the position of the setup the same and neglect effects of higher order.
Superconductors have a better current density, so you get more current per cable mass.
With magnets in the lab as field source, things are much better. You can easily get gradients of 1T/m (and more), which is better by a factor of 10^11. Instead of superconducing rings, you can use a simple superconducting object of any shape, and use the Meissner effect for levitation.
1. What is magnetic levitation energy?
Magnetic levitation energy, also known as Maglev energy, is a form of renewable energy that uses magnetic fields to create motion and generate electricity.
2. How does magnetic levitation energy work?
Magnetic levitation energy works by using the repelling force between two magnets to create motion. This motion is then harnessed to generate electricity through a process called electromagnetic induction.
3. What are the benefits of using magnetic levitation energy?
Some of the benefits of using magnetic levitation energy include: being a renewable energy source, producing no greenhouse gases or air pollution, having low maintenance costs, and being able to operate in harsh weather conditions.
4. What are the limitations of magnetic levitation energy?
One of the main limitations of magnetic levitation energy is the high initial cost of building and installing the necessary infrastructure. Additionally, the efficiency of the energy conversion process is currently lower compared to other forms of renewable energy.
5. What are some applications of magnetic levitation energy?
Magnetic levitation energy can be used in a variety of applications, including transportation systems such as high-speed trains, energy storage systems, and power generation systems. It can also be used in industries that require precise and frictionless motion, such as in manufacturing and medical equipment.
  • Electromagnetism
  • Electromagnetism
  • Electromagnetism
  • Electromagnetism
  • Electromagnetism
