AC Voltage and current, amplitude, rms, peak value
In summary, peak values are sometimes used in addition to RMS values, but as long as you are consistent in your calculations, ohm's law will hold true. Additionally, to obtain DC current from an AC waveform, you can find the average value over one cycle, which can often be determined visually from the waveform.
Deathfish
86
General enquiries (template may not be suitable)
- When the question provides value of AC voltage amplitude, is this the same value of peak voltage?
- Also, in current waveform, when do we use peak current and rms current?
- In ohm's law equations we use rms current, so in the current waveform graph do we need to times square root of 2?
- If provided with current waveform, can we get output dc current from using the same equation for voltage? eg. 2 x Vmax / [itex]\pi[/itex], Vmax / [itex]\pi[/itex]
Relevant Equations :
V (odc) = 2 x Vmax / [itex]\pi[/itex], V(odc) = Vmax / [itex]\pi[/itex],
V (peak) = Vrms x [itex]\sqrt{2}[/itex]
yes, voltage amplitude means maximum deviation from DC value, or half the peak-to-peak
there isn't a set rule for this unfortunately, in my electrical engineering course it is much easier to use peak values for sinusoidal or complex expressions. only cases I have come across using RMS is calculation of power dissapation
Deathfish said:
- In ohm's law equations we use rms current, so in the waveform graph do we need to times square root of 2?
as long as you are consistent, ie use only rms or only peak values in your calculatoins, ohm's law will hold, just like converting all units to metric units
i'm not sure what these voltage formalae are used for but to obtain DC current you can use the ac waveform and find its average value over one cycle, more often then not they are quite obvious from inspection
Unless otherwise specified, AC voltage and current values are given as RMS. This is convention.
Sometimes it is necessary to know about peak values when specifying things like dielectric strengths or insulation. Also, if nonlinear components are involved (like diodes) and time constants or triggering levels are involved, you may need to work with the actual voltage or current waveforms in their 'peak' form.
1. What is AC voltage and current?
AC voltage and current stand for alternating current voltage and current. Alternating current is an electric current that periodically reverses direction, unlike direct current, which flows in only one direction.
2. What does amplitude refer to in AC voltage and current?
Amplitude refers to the maximum value of the voltage or current in an AC waveform. It is measured in volts or amps and represents the strength or intensity of the electric signal.
3. What is the difference between RMS and peak value in AC voltage and current?
RMS (root mean square) is a mathematical calculation that represents the equivalent DC value of an AC waveform. It is calculated by taking the square root of the average of the squares of the values in the waveform. Peak value, on the other hand, refers to the highest value reached by the AC waveform. In most cases, the peak value of an AC waveform is higher than its RMS value.
4. How is AC voltage and current measured?
AC voltage and current are measured using specialized instruments called voltmeters and ammeters, respectively. These instruments measure the voltage and current in an AC circuit and display the readings in volts and amps, respectively.
5. What is the purpose of AC voltage and current in everyday life?
AC voltage and current are essential in powering our everyday devices and appliances. Most homes and businesses use AC power from the electric grid to run lights, appliances, and other electronic devices. AC power also allows for the efficient transmission of electricity over long distances.
