Radiation & nuclear physics, linear attenuation Co-60, Cs-137-
In summary, the conversation discusses three problems related to calculating dose rates and protecting workers from radiation exposure. The first and second problems are solved, but the third problem involves calculating the thickness of a concrete wall needed to protect a worker from receiving an annual dose of 0.50mSv. The conversation also includes equations and attempts at solving the problem. Ultimately, the solution involves using the equation I=I_0*e^(-yx) where y is the attenuation factor and x is the thickness of the wall. The resulting thicknesses for Co-60 and Cs-137 are 13.7cm and 10.2cm, respectively.
tigrus
Hello there.
I've been struggling with this one for quite a long time now and decided to ask if any of you people could point out what I'm missing here.
There are actually three problems which are related to each other. I managed to solve the first and the second one, but the third is where I run out of ideas.
1) The measured dose rate at a distance of one meter from source is 7.5uSv/h. Calculate the dose rate at a distance of a) 1.50m b) 0.10m from the source.
Answers: a) 3.3uSv/h b) 750 ySv/h
2) What is the total dose per year received by a person who works in average distance of 2.0m from the radiation source referred in previous exercise, if there are 220 working days per year and the length of the working day is 8 hours.
Answer: 3.3mSv
Following is the one I have troubles with
3) How thick concrete wall is needed to protect the worker so that the annual dose is 0.50mSv for a worker described in the previous exercise, if the source is a) Co-60 b) Cs-137
Answers: a) 14cm b) 10cm
Attenuation of y-radiation: I = I_0 * e^(-yx)
Relationship between activity and dose rate - r (gamma) constant: A=D'd^2/r
According to wikipedia r seems to be around 0.57721 uSvm^2/MBq
As far as I understand 0.50mSv/a year is a dose rate itself, but I converted that to uSv/h
220 * 8h = 1760h = year of work
Dose rate D' = 0.50mSv/1760h = 0.284uSv/h
Q_Co-60 = 2.823067Mev (Taken from a table)
With that energy the factor of linear attenuation in Pb seems to be around 48.756. This was an approximation. For 2Mev the table says 52,2 and for 3Mev 48,0 so I took a value in between.
From equation I=I_0*e^(-yx) I could calculate the needed thickness by making it x=ln(I/I_0)/-y but I have not found a way to solve the undampened intensity/dose rate. As far as I understand intensity and dose rates can be considered meaning the same thing here. Am I completely mistaken?
I could also calculate the activity A with the formula A=D'd^2/r meaning A= (0.284uSv/h * 2^2)/0.57721 uSvm^2/MBq giving acticity of 1.96809 MBq but I have not understood how to utilize this information. How would you proceed?
Any help is appreciated.
Edited: Alright, one mistake clearly is that I was using attenuation factor for Pb instead of concrete. For concrete 2MeV the factor is 10.5 and 3MeV it is 8.51. Therefore I assume the factor to use is 8.8682. Still how to solve this remain unclear to me.
Thank you for your replies. I think I understand the concept better now. I was missing the fact that dose rate and intensity can be considered the same here, meaning that attenuation factor is related to dose rate. To solve this I used the equation I=I_0*e^(-yx) where y is the attenuation factor and x is the thickness of the wall. This gave me the thickness of 13.7cm for Co-60 and 10.2cm for Cs-137. The values I got were slightly off from the ones given in the question, but I assume this is due to the approximations I had to do in the attenuation factors. Once again, thank you all for helping me out.
1) What is radiation?
Radiation is the emission or transmission of energy in the form of waves or particles. It can occur naturally, such as from the sun or from radioactive materials, or it can be man-made, such as in medical imaging or nuclear power plants.
2) What is nuclear physics?
Nuclear physics is the branch of physics that deals with the structure, properties, and interactions of atomic nuclei. It involves the study of the forces that hold the nucleus together, as well as the processes of nuclear decay and nuclear reactions.
3) What is linear attenuation?
Linear attenuation is the decrease in the intensity of radiation as it passes through a material. It occurs as a result of absorption and scattering of the radiation by the atoms in the material.
4) What is Co-60?
Co-60, or cobalt-60, is a radioactive isotope of cobalt with a half-life of 5.27 years. It is commonly used in medical and industrial applications, such as cancer treatment and sterilization of medical equipment.
5) What is Cs-137?
Cs-137, or cesium-137, is a radioactive isotope of cesium with a half-life of 30 years. It is commonly used in industrial applications, such as radiography and thickness gauging, as well as in medical treatments for cancer and other diseases.
  • Nuclear Engineering
  • General Discussion
9K
