Are left-invariant fields mapped onto the manifold Killing vectors?
In summary, left invariant fields on a group G satisfy a Lie algebra, with a basis of fields satisfying the algebra [X_a, X_b] = c_{ab}^c X_c. Similarly, on a Riemannian manifold with killing vectors, the same algebra is satisfied. The map F: TG -> TM given by X_a -> X_a^{*} is identified with the Killing fields on M, but may not be injective. If the action is effective, X_a^{*} is Killing for every X in Lie(G). In the case of spherical symmetry, if the Lie algebra of SO(3) can be embedded in the Lie algebra of the killing vectors on (M,g), then (M,g)
center o bass
560
Left invariant fields on a group G satisfies a lie algebra; say we have an n-dimensional Lie algebra for which the fields ##{X_1, \ldots , X_n}## is a basis. Let these satisfy the algebra ##[X_a, X_b] = c_{ab}^c X_c##. Suppose now that we have a Riemannian manifold with killing vectors ##{\xi_1,\ldots, \xi_n}## and let they satisfy the same algebra ##[\xi_a, \xi_b] = c_{ab}^c \xi_c##. Let ##p \in M## and the action of the group G on M be denoted ##g \cdot p##. Then we have the map ##F: TG \to TM## given by
$$X_a \mapsto X_a^{*} := \left. \frac{d}{dt}\right|_{t = 0} e^{t X_a} \cdot p.$$
Is ##X_a^{*}## identical to the killing field ##\xi_a##? If so, how does one prove it?
If the action is effective, then the map X-->X* is injective. If not, then it seems to me that X-->X* may be non injective. In that case, the answer to your question is certainly negative.
Even if we assume the action is effective, then just looking at the case where n=1. Any X in Lie(G) is such that [X,X]=0 as well as any Killing field on M satisfies [K,K]=0. But as soon as there exist two or more Killing fields on M, we have a counter-example to your question.
How does that counter-example arise? If we can't do the identification of the vector fields, does it however follow that if ##X## is a basis of the lie algebra of G, which is the same as that of the killing vectors on M, then ##X^*## is a killing vector? In other words, is ##\mathcal{L}_{X^*} g = 0## where g is the metric tensor on M?
At the start of page 182 in Arthur Besse's book "Einstein manifolds", he identifies ##X^*## with the Killing fields on M, but notes that
$$[X,Y]_{\mathcal{g}} = -[X^*,Y^*]$$
where ##[ \ , \ ]_{\mathcal{g}}## denotes the Lie bracket on the Lie algebra.
I think this would be provable if the map ##X \mapsto X^*## could formulated as a pushforward. And it seems that it would have to be related to the pushforward of the group action.
If G acts by isometries on (M,g), then X* is Killing for every X in Lie(G). Is that what you're asking?!
No, but rather: If the Lie algebra of G is 'equivalent' to the Lie algebra of the killing vectors on (M,g) will G act on M by isometries?
Take the example of spherical symmetry. According to Wald ( or Schutz spherical symmetry is defined as follows: If the Lie algebra of killing vector fields on (M,g) has a subalgebra which is the Lie algebra of SO(3), then we say that (M,g) has spherical symmetry.
Now take an basis vector of the Lie algebra of SO(3), let's call it X and map X according to ##X \mapsto X^*##. Do we then have that ##\mathcal{L}_{X^*} g = 0##?
Or simply: When does G act on (M,g) by isometries? When are ##X^*## the killing vectors on (M,g)?
So if I understand correctly the situation, you've read this abstract-looking definition and now you're trying to make sense of it. Is that what's going on?
If that is so, then I don't think you're asking the right question, because there is no a priori action of G on M in the definition of Wald. He only speak of the existence of an embedding of so(3) in k.
Here is how I would make sense of the definition however: The isometry group Isom(M,g) of a riemannian manifold is a finite dimensional Lie group with Lie algebra k (the Killing fields) (see Kobayashi-Nomizu). Therefor, by the general theory of Lie groups (see John Lee), if a is a subalgebra of k, there is a unique connected subgroup A of Isom(M,g) whose Lie algebra is a. On the other hand, since SO(3) also has Lie algebra a and is simply connected, SO(3) is the universal cover of A, and so there is a homomorphism (the covering map) SO(3)-->A\subset Isom(M,g). This, by definition, is an action of SO(3)~S² on M by isometries.
You are right that I am looking to understand that definition and it's consequences.
Is there no canonical action of Isom(M) on M?
From what you just argued, is it possible to argue that a a manifold with SO(3) symmetry is isometric to a sphere? Or locally isometric? What about homeomorphic?
1. What is a left-invariant field?
A left-invariant field is a vector field on a manifold that is invariant under left translations. This means that the vector field remains unchanged when the manifold is translated by a fixed amount in a particular direction.
2. What is a Killing vector?
A Killing vector is a vector field on a manifold that preserves the metric of the manifold. This means that the vector field generates an isometry, or a transformation that preserves distances and angles on the manifold.
3. How are left-invariant fields and Killing vectors related?
Left-invariant fields are a special case of Killing vectors, where the isometry is a translation. This means that all left-invariant fields are mapped onto Killing vectors, but not all Killing vectors are left-invariant.
4. Why is it important to study the mapping of left-invariant fields onto Killing vectors?
Understanding the relationship between left-invariant fields and Killing vectors is important for studying symmetries and transformations on manifolds. It also has applications in physics, particularly in the study of spacetime and general relativity.
5. Can left-invariant fields be mapped onto any manifold?
Yes, left-invariant fields can be mapped onto any manifold with a well-defined metric. However, the resulting Killing vector may not necessarily be a left-invariant field on the new manifold.
  • Differential Geometry
