Relation between charge and voltage in spherical capacitors
In summary: the other side of course, if the first plate surrounds the second so that the distance between them is constant, then there's no "nearer" and "further", and the charge in the second plate will have no reason to redistribute itself (it can't retreat to the inside surface of the second plate because the charge there must be zero from gauss's law since there's no charge inside it)if the second plate surrounds the first, a gaussian surface in the middle of the second plate shows that the opposite charge on the inside surface must be equal to that of the inner plate: the "same" charge will retreat to the outside surface of the second plate if not grounded, and to the ground if grounded (i think that's what
abdo799
169
1-If we had a spherical capacitor and the voltage across it is 1000 V, I need to know the charge on every plate, I know 2 ways to solve this either using C=Q/V or V=Q/r * 1/4ε0∏. So, which one should I use, and why?
2-Another thing, according to hyperphysics the formula for the capacitance of the spherical capacitor = 4∏ε0/ (1/a - 1/b). Does that mean that the dielectric constant of the dielectric has no effect like parallel plates?
2. Usually we look at spheres with nothing in between, hence the ##\epsilon_0##. With a dielectric you would have to use ##\epsilon##.
1. With plate you mean spherical surface ? In your case I would use the first eqn. Since you already found the hyperphysics expression for C: just above there is V in terms of Q, though. A bit more straightforward.
All this assuming you are comfortable with Gauss' law.
ok, i know from my other post ( chemical engineering thing) that you are a physicist which is really cool because i wanted to be one, about your answer, is the second wrong if i used it in this case?
if you considered a van de graaff generator , where the sphere was one plate and then it was covered with dielectric then we put another metal sphere on it as the other plate ( we ground this plate).(forming a spherical capacitor)
If the van de graaff generator had a radius of 1 m and put a charge on the sphere of 0.001 coulomb using the second equation the voltage on the sphere will be about 9 MV.
will the other plate gain the same voltage or the same charge ?
In my first case i was almost sure that we have to use C=Q/V because the setup was a capacitor and a battery, a classical circuit. In the case i just wrote , something is different, we charge only one plate with positive charge ( the van-de graaff generator) and the other plate will gain the extra negative charge from the ground.
hi abdo799! :smile:
for a spherical capacitor with dielectric constant ε:
D = -Q/4πr2
E = -Q/ε4πr2
V = ∫ab E dx = [Q/ε4πr]ab
C = Q/V​
tiny-tim said:
hi abdo799! :smile:
D = -Q/4πr2
E = -Q/ε4πr2
C = Q/V​
i already know this derivation , but i really need an answer to my reply to the first reply , thanks
hi abdo799! :smile:
if the capacitor is part of a circuit, it's the same (and opposite) charge
when you change the voltage across any capacitor in a circuit, the total charge on the two plates will be the same as before :wink:
if the capacitor is not part of a circuit (ie it's not really acting as a capacitor), eg if you charge one sphere and bring it near an uncharged sphere (unconnected to it), then the positive and negative charges on the uncharged sphere will redistribute so that the opposite charge faces the first sphere, and the "same" charge retreats to the other side
if the second plate surrounds the first, a gaussian surface in the middle of the second plate shows that the opposite charge on the inside surface must be equal to that of the inner plate: the "same" charge will retreat to the outside surface of the second plate if not grounded, and to the ground if grounded (i think that's what you're asking about?)
Likes 1 person
tiny-tim said:
hi abdo799! :smile:
Last question please,
After we charge the whole thing , and the external sphere gained the extra charge , then we connect both sphere with a wire ( kinda like a capacitor discharge) the electrons will flow from the negative sphere to the positive one ,can i consider it now a capacitor ? can i use (1/2 c V^2) to calculate energy ?
What value of C are you suggesting should be used?
C=4ε∏/(1/a-1/b)
1. What is the relation between charge and voltage in a spherical capacitor?
In a spherical capacitor, the charge and voltage are directly proportional to each other. This means that as the charge increases, the voltage also increases, and vice versa.
2. How does the shape of a spherical capacitor affect the relation between charge and voltage?
The shape of a spherical capacitor does not affect the relation between charge and voltage. As long as the capacitor has a spherical shape, the relationship between charge and voltage will remain the same.
3. Can the relation between charge and voltage in a spherical capacitor be expressed using a mathematical equation?
Yes, the relation between charge and voltage in a spherical capacitor can be expressed using the equation Q = CV, where Q is the charge, C is the capacitance, and V is the voltage.
4. How does the dielectric material in a spherical capacitor affect the relation between charge and voltage?
The dielectric material in a spherical capacitor affects the capacitance, which in turn affects the relation between charge and voltage. A higher dielectric constant will result in a higher capacitance, leading to a higher charge and voltage for a given applied potential.
5. Is the relation between charge and voltage in a spherical capacitor affected by the distance between the two spherical plates?
Yes, the distance between the two spherical plates affects the capacitance, and therefore, the relation between charge and voltage. A larger distance will result in a lower capacitance, leading to a lower charge and voltage for a given applied potential.
  • Electromagnetism
  • Electromagnetism
  • Electromagnetism
  • Electromagnetism
  • Electromagnetism
