How does a fibre bundle differ from base space X typical fibre?
In summary, the cylinder is equivalent to S1 X line segment while the Möbius strip is only locally like S1 X line segment.
pellman
684
Let's take a simple example.
Both a cylinder and Möbius strip consist of a circle with a line segment associated with each point of the circle. The cylinder is considered truly equivalent to the direct product S1 X line segment while the Möbius strip is only locally like S1 X line segment. Ok, what does that mean? Does the direct product have any properties which aren't local?
I mean, I thought S1 X line segment L is merely [tex]\{(p,x)|p \in S^1, x \in L\}[/tex], period. Both the cylinder and Möbius strip would be instances of this general thing, differing from each other only in additional properties, e.g. the transition functions.
While locally the same, there are global, ie, topological differences. Specifically, the two spaces are not homeomorphic. For example, one is orientable and one is not. Also, if you cut along a circle around the strips, the cylinder gets cut into 2 disjoint pieces while the Mobius strip does not.
Thanks, StatusX. I think I fully understand the global difference between the cylinder and the Mobius strip.
The problem is in how they relate to the direct product S1 X line segment.
For instance from Wikipedia http://en.wikipedia.org/wiki/Fiber_bundle#Trivial_bundle
Trivial bundle
Let E = B × F and let π : E → B be the projection onto the first factor. Then E is a fiber bundle (of F) over B. Here E is not just locally a product but globally one. Any such fiber bundle is called a trivial bundle
(End quote)
So what I am asking is, "what does 'globally' like a product mean?" As far as I can see, direct product is strictly a local relation.
Apparently I am missing something since both the cylinder (the "trivial bundle") and the Mobius strip seem to me to be instances of S1 X line segment L, albeit instances which differ from each other by additional (global) properties.
Yet the literature indicates that the cylinder is identical to S1 X L while the Mobius strip is only "locally" like S1 X L. I don't see the distinction--with regard to S1 X L. (I do see the distinction between the cylinder and the Mobius strip.)
Clarification: in fibre bundle terminology here, the base space is the circle S1 and the (typical) fibre is the line segment L. The total space of the fibre bundle (also called the bundle space) is S1 X L ... for both the cylinder and the Mobius strip?
The difference between cylinder and Möbius strip is in the topology of their total space (E). A fiber bundle consists of two topological spaces (the total space, and the base space), and a projection from the total space to the base space. The topology of the total space determines, if the bundle can be covered continuously with a single product of the base space and the typical fiber, or it is impossible (like in the case of the Möbius strip). The emphasis is on the continuity.
No. Only the cylinder's total space is S1 x L, the total space of the Möbius strip isn't.
I think I have it now.
I was thinking that since both the cylinder and the mobius strip consist of a circle with a line segment associated with each point of the circle and so both are equivalent to S1 X L. However, another way to view S1 X L is as a line segment with a circle associated with each point. When you picture it that way it is easy to see that S1 X L is the cylinder and not the mobius strip.
Thanks for playing, mma and StatusX.
Good understanding! It is often said that fiber bundle is a Cartesian product who has lost one of his projection. Now you have shown the projection of the Cartesian product cylinder which is lost when we consider it only a fiber bundle with bas space S1 and fiber L. However in the case of the cylinder, this projection can be retrieved as you showed, that's why it is called trivial. You have now shown that if we start from the Cartesian product cylinder, we can create another fiber bundle from it by forgetting it's another projection. That is, we can regard the cylinder not only as a fiber bundle with base space S1 and fiber L, but also as a fiber bundle with base space L and fiber S1. The Möbius strip of course not, because of its topology.
mma said:
It is often said that fiber bundle is a Cartesian product who has lost one of his projection. Now you have shown the projection of the Cartesian product cylinder which is lost when we consider it only a fiber bundle with bas space S1 and fiber L. [/.
I was just trying to wrap my head around this very concept. Thanks for tying it to my question.
1. What is a fibre bundle?
A fibre bundle is a mathematical concept used to describe the relationship between a base space and a typical fibre. It consists of a base space, which is a topological space, and a typical fibre, which is a space that is attached to each point on the base space in a consistent manner.
2. How does a fibre bundle differ from a base space?
A fibre bundle differs from a base space in that it includes an additional structure, the typical fibre, which is attached to each point on the base space. This allows for a more complex and detailed description of the space.
3. What is the typical fibre in a fibre bundle?
The typical fibre in a fibre bundle is a space that is attached to each point on the base space in a consistent manner. It can be any type of space, such as a vector space, a manifold, or a group. The choice of typical fibre depends on the specific application of the fibre bundle.
4. How does a fibre bundle differ from a vector bundle?
A vector bundle is a type of fibre bundle where the typical fibre is a vector space. This means that at each point on the base space, there is a vector space attached. In contrast, a general fibre bundle can have any type of typical fibre, not just a vector space.
5. What is the importance of fibre bundles in mathematics?
Fibre bundles are important in mathematics because they allow for a more detailed and flexible description of spaces. They are used in various branches of mathematics, including topology, geometry, and physics, to study and understand complex structures. They also have applications in engineering, such as in the study of vibrations and elasticity.
  • Differential Geometry
9K
