2 questions in electromagnetism.
In summary: I'm not sure what you mean by this...unless \chi_{ij} are functions of E (which is not at all implied by the way you've written the equation), the relationship is...linear?No, it's not linear.
MathematicalPhysicist
371
1. In a dilectric sphere with radius a and polarization vector P= P0 r (r is the spherical radial vector) where P0>0. find D,E and the polarization charge volume density and area density.
2. A chagrge q is displaced at the centre of a hollow dilectric sphere (with a,b as its internal an outer radii), the dilectric constant e(r) depends on the radial distance, find E,D,P.
Maxwell (electrostatic) Equations and boundary conditions.
For 1, I found the charge densities, [tex] \rho ' =-\nabla \b{P}= -3P0[/tex] and [tex]\sigma ' = -(\b{P}_{inside \ sphere} - \b{P}_{outside \ sphere})\cdot \b{n}= P_0 a[/tex], Now I don't know how to find D and E, from the boundary conditions I know that:
div D= [tex]4\pi \rho_{free}[/tex] and that [tex]\sigma_{free} = -(\b{D}_{inside \ sphere} - \b{D}_{outside \ sphere})[/tex], and E I can find after I find D, by the fact that D=E+4pi P.
I suppose that [tex]\sigma_{free}=-\sigma '[/tex] cause the net charge is zero, and the same with volume densities, from both equations and from the symmetry of the problem (D is spherical radial) I can find D, I am not sure if this is valid.
For 2, not sure either, if I find D then E=D/e(r), and P=(e(r)-1)/4pi)E, the question is how do I find D?
Thanks in advance.
Do you know the relations?
[tex]
\mathbf{P}=\varepsilon_0\chi_e\mathbf{E}
[/tex]
and
[tex]
\mathbf{D}=\varepsilon_0\mathbf{E}+\mathbf{P}
[/tex]
these should help with both problems
Yes, I know them (but in cgs system).
OK, I see now how I can solve question #1, but not sure how to answer question #2, can you help me with question #2?
thanks.
Wait a minute, the first equation is valid only for linear materials, in the first question it's not given that the material is linear (i.e E is proportinal to D).
It doesn't say it's not linear either. For nonlinear polarization,
[tex]
P_i=\sum_j\varepsilon_0\chi_{ij}E_j
[/tex]
I would assume you should go with what I wrote first, since you don't have the matrices needed to solve the nonlinear term.
For problem 2, wouldn't this just be Gauss's Law in dielectric form?
[tex]
\oint \mathbf{D}\,d\mathbf{S}=Q_{enc}
[/tex]
and from D, find E and P?
It also doesn't say there aren't a bunch of free charges scattered about, but I see no reason to assume there are.
[tex]
[/tex]
That still looks like a linear relationship to me (If you double E, you double P)...Just because the material doesn't polarize parallel to E, doesn't mean its nonlinear.
True, but in non-linear cases, it is not [tex]\mathbf{E}[/tex] that is the non-linear term, it's the [tex]\chi_{ij}[/tex] that is the non-linear term.
That looks a little odd to me...are you sure the problem doesn't specify [itex]\textbf{P}=P_0\hat{\textbf{r}}[/itex] (i.e. the polarization has a constant magnitude and points radially outward)?
What makes you think the net charge s zero? Unless you are given information to the contrary, I would assume there are no free charges. You can then calculate E directly from the bound charges using Coulomb's Law (or Gauss' Law) and D can be determined directly from its definition.
I'm not sure what you mean by this...unless [itex]\chi_{ij}[/itex] are functions of [itex]E[/itex] (which is not at all implied by the way you've written the equation), the relationship is linear.
Normally you would Taylor expand the relationship into more terms:
[tex]
P_i=\varepsilon_0\left(\sum_j\chi^{(1)}_{ij}E_j+\sum_{jk}\chi^{(2)}_{ijk}E_jE_k+\cdots\right)
[/tex]
where [tex]\chi^{(1)}[/tex] is your normal susceptibility and [tex]\chi^{(2)}[/tex] comes from the Pockels effect and so on, but I didn't feel like expanding it out further than I did because I doubt that the professor would have assigned such an problem (that is, I still assume it is linear).
So I guess I was technically wrong about saying that [tex]\chi_{ij}[/tex] was the non-linear term. When you asked further, I pulled out my non-linear optics text to double check.
I am sure.
Careful,
[tex]\rho'=-\mathbf{\nabla}\cdot\textbf{P}\neq-3P_0[/tex]
Why not, I use the nabla operator in spherical coordinates which according to my textbook is:
div A= 1/r^2 d/dr(r^2 A_r)
In this case, A_r=P0*r.
[/quote]
Not sure how to do this, [tex]div E=4\pi \rho '[/tex], I can assume here that E is radial, if yes then it's rather simple as well.
I am sure.
Okay.
Yes, I edited my post when I realized my error:smile:
Have you not already calculated the fields due to a uniformly charged sphere and a uniformly charged spherical surface?:wink:
[tex]
[/tex]
So for r<a, Q enclosed is q, so D *4pi *r^2=q, => D=q/(4pi*r^2)
for a<r<b, D(4pi(r^2-a^2))=q
for r>b, D(4pi * b^2)=q
Is this right?
Thanks in advance.
P.s
Don't know but electromagnetism in university is still my tough part in physics, though the theory is pretty neat I find myself baffled at questions which are rudimintary.
Why do you have the r^2-a^2 there? What are you using as your Gaussian surface? What is the flux of a spherically symmetric D-field through that surface?
I use the ring between the spheres with radius a and b, which its surface area is 4pi (r^2-a^2).
I'm not sure what you mean by "ring", but I guess you are referring to a spherical shell of thickness r-a? If so, that is a VERY poor choice of Gaussian Surfaces; it is actually two surfaces (at r'=a and r'=r) and hence the D-field will have two different values over this surface (D(r'=a) and D(r'=r))
[tex]\oint\textbf{D}\cdot d\textbf{a}=4\pi D(r)r^2-4\pi D(a)a^2[/tex]
Just use an infinitesimally thin spherical shell at r'=r instead.
I still don't get it.
So, S D.da= 4pi D(r) r^2, or something else?
Yes, so [itex]\textbf{D}=\frac{q}{4\pi r^2}\hat{\textbf{r}}[/itex] everywhere...
1. What is electromagnetism?
Electromagnetism is a branch of physics that deals with the study of the relationship between electricity and magnetism. It explains how electric charges and currents interact with magnetic fields to produce forces and how changing magnetic fields can induce electric currents.
2. What are the two main questions in electromagnetism?
The two main questions in electromagnetism are: 1) How do electric charges and currents interact with magnetic fields? 2) How do changing magnetic fields induce electric currents?
3. How do electric charges and currents interact with magnetic fields?
Electric charges and currents interact with magnetic fields through a force called the Lorentz force. This force is perpendicular to both the electric and magnetic fields and is dependent on the magnitude and direction of the charge or current and the strength and direction of the magnetic field.
4. How do changing magnetic fields induce electric currents?
According to Faraday's law, a changing magnetic field can induce an electric current in a conductor. This is due to the fact that a changing magnetic field produces an electric field, which in turn causes charges to move and creates an electric current.
5. How is electromagnetism used in everyday life?
Electromagnetism has many practical applications in our daily lives. Some examples include the use of electric motors and generators in appliances, the transmission of electricity through power lines, the functioning of electronic devices, and the use of MRI machines in medical imaging.
