Finding the distance from a point to a plane using substitution
Then plug these values into the distance equation to get the minimum distance.In summary, to find the distance from a point to a plane, you can use the formula: distance = \sqrt{(x-2)^{2}+(y-1)^{2}+(x+y)^{2}}. This can be derived by substituting in the equation of the plane for z, and then using the distance formula for a point to another point. Alternatively, you can use calculus and Lagrange multipliers to find the minimum distance.
mrcleanhands
If I want to find the distance from a point to a plane.
E.g. (2,1,-1) to the plane x+y+z=1
I know that distance from one point to another is given by:
[itex]\sqrt{(x-2)^{2}+(y-1)^{2}+(z+1)^{2}}[/itex]
And in this case the solution is to substitute in z=x+y-1 which fits nicely giving us:
distance=[itex]\sqrt{(x-2)^{2}+(y-1)^{2}+(x+y)^{2}}[/itex]What I'm trying to work out in my own mind is why substituting that in will suddenly give us the distance from the plane to the point.
I think that x,y are still arbitrary points in 3D space but when we substitute in the stuff for Z (nice/formal way of saying this anyone?) now x,y are allowed to be arbitrary points in 3D space since if Z is forced to be on the plane then x,y should fall on the plane.
However, if you have a tilted plane I can visualize a case where z is on the level of the plane but x,y are running off somewhere else...and btw for those of you guys answering questions here. I can't tell you how much more enjoyable this forum has made maths for me (I was starting to dislike it a lot). I'm able to delve into all the little details I wasn't before. Thank you!
Where do those -1, -1, +1 come from? That is certainly not the formula for the distance of your point. You should use your specific point here, not something else.
It does not, you still have two variables there.
E.g. (2,0,-3) to the plane x+y+z=1
[itex]\sqrt{(x-1)^{2}+(y-1)^{2}+(z+1)^{2}}[/itex]
Your distance formula gives the distance from an arbitrary point P(x, y, z) to Q(1, 1, -1). There's nothing in your formula that pertains to the point (2, 0, -3), which needs to be in your distance formula.
It's 4AM here... I just edited the question.
I don't want to substitute in points from the plane for x,y,z because I want to be able to find the derivative of this Distance function and then minimize it. So I want to understand how I can make sure I'm minimizing the right distance...
In order to get the distance from a point to a plane, you need to do the following.
1) Define a vector perpendicular to the plane - in your case Q = (1,1,1) will do.
2) Get the intersection of a line starting at your given point, directed along the perpendicular. Let P be your original point. So the line is described by P + sQ.
3) Plug this into the equation for the plane. (2+s) + (1+s) + (-1+s) = 1.
4) Solve for s = -1/3. The distance is now |s|√3 = 1/√3.
The problem can also be worked using the approach that mrcleanhands suggests - by finding the minimum value through calculus of the distance between the specified point and an arbitrary point on the plane.
It's simpler to work with the square of the distance than with the distance itself. After all, the point that minimizes the distance also minimizes the square of the distance. You would want to minimize
f(x, y) = D2 = (x - 2)2 + (y - 1)2 + (1 - x - y + 1)2
Since this is a function of two variables, you'll need to use partial derivatives, and set both of them to zero.
The problem can also be done using a technique called Lagrange multipliers. See http://en.wikipedia.org/wiki/Lagrange_multiplier.
Just wondering. Why use a more roundabout approach, when the simple method (no calculus) will do?
In this case it's just a matter of learning about an application of partial derivatives.
So the thing I don't get here is why:
f(x, y) = D2 = (x - 2)2 + (y - 1)2 + (1 - x - y + 1)2 is going to give you the distance^2.
If you have a flat plane which is only on one value of Z then yes it will work, but if the plane is tilted then you can no longer just take any value of x,y as it won't necessarily be on the plane anymore even if it's the right Z value.
This gives the distance to a particular point on the plane. The next step is to find the (x,y) pair which minimizes: ∂f/∂x = 0, ∂f/∂y = 0. Solve for x and y.
1. How do you find the distance from a point to a plane using substitution?
To find the distance from a point to a plane using substitution, you can use the formula d = |ax + by + cz + d| / √(a^2 + b^2 + c^2), where (x,y,z) is the coordinates of the point and ax + by + cz + d = 0 is the equation of the plane.
2. Can you explain the concept of substitution in finding the distance from a point to a plane?
Substitution in this context refers to the method of replacing the variables (x,y,z) in the equation of the plane with the coordinates of the given point. This allows us to reduce the problem to finding the distance from a point to a line, which is a simpler concept to understand.
3. Is it necessary to use the absolute value in the distance formula?
Yes, it is necessary to use the absolute value because the distance between a point and a plane can be either positive or negative, depending on which side of the plane the point is located. Taking the absolute value ensures that we get a positive distance value.
4. Can this method be used to find the distance from a point to any type of plane?
Yes, this method can be used to find the distance from a point to any type of plane, as long as the plane is defined by a linear equation in three dimensions. This includes vertical and horizontal planes as well as tilted or slanted planes.
5. Are there any other methods for finding the distance from a point to a plane?
Yes, there are other methods for finding the distance from a point to a plane, such as using vectors or the Pythagorean theorem. However, the substitution method is often the most straightforward and efficient method for solving this type of problem.
  • Calculus
