apchar
- 11
I'm reading a book (Numerical Techniques in Electromagnetics by Sadiku) & just finished the section on finite difference methods. As what I thought would be an easy exercise, I tried to apply what I'd learned to the telegraphers equations that describe the voltage, V(x, t), and current, I(x, t), on a transmission line with some realistic (meaning ugly) boundary conditions:
Picture: A voltage source Vg, a resistor Rg, a long transmission line of length L with characteristic impedance Z0, and a load resistor RL.
The equations are 2 coupled (by the boundary conditions) wave equations:
[tex]
\frac{\partial^2 V}{\partial t^2} = u^2 \frac{\partial^2 V}{\partial x^2}
[/tex]
[tex]
\frac{\partial^2 I}{\partial t^2} = u^2 \frac{\partial^2 I}{\partial x^2}
[/tex]
Where u is the velocity of propagation and 0 < x < L, t > 0
The boundary & initial conditions are
[tex]
V(0, 0) = V_g(0) \frac{Z_0}{Z_0 + R_g}
[/tex]
[tex]
I(0, 0) = V_g(0) \frac{1}{Z_0 + R_g}
[/tex]
[tex]
V(0, t) = V_g(t) - R_g I(0, t)
[/tex]
[tex]
V(L, t) = R_L I(L, t)
[/tex]
V(x, 0) = I(x, 0) = 0 for x>0 & everything(t<0) = 0
RL, Rg, & Z0 are real positive constants. Vg(t) is a known function of time only.
It's those last 2 boundary conditions that are confounding me.
So I turn each into a difference equations using the centralized 2nd order approximation
[tex]
\frac{V(i, j+1) - 2 V(i, j) + V(i, j-1)}{\Delta t^2} = u^2 \frac{V(i+1, j) - 2 V(i, j) + V(i-1, j)}{\Delta x^2}
[/tex]
same for I. I solve for V(i, j+1) & I(i, j+1). With j (time) in my outer loop & i (x) in my inner loop I start stepping across x for each time t. Everything is fine until I reach that last boundary condition. I have a chicken & egg problem. First impulse is to step V forward and calculate I or vice versa. But neither will give me the right answer. I'm going to have the same problem at x=0 after that first step.
The problem is easy if RL = Rg = 0. I can just crank the the equation for V since V(L, t) = 0 is a nice fixed condition.
Likewise it works fine for RL=infinity & Rg = 0. I can crank the equation for I.
It's also works for RL = Rg = Z0.
The fact that it works in these 3 situations leads me to believe it can work for others.
But, for RL & Rg > 0 but not = Z0, how do I handle those two boundary conditions that relate V & I at x=0 and x=L?
I know there are other (& probably better) ways to solve this, even analytically or just intuitively. But I need the practice with FD.
Thanks,
Apchar
[tex]
[/tex]
[tex]
[/tex]
[tex]
[/tex]
[tex]
[/tex]
[tex]
[/tex]
[tex]
[/tex]
[tex]
[/tex]
Thanks,
Apchar
