- #6,826
jim hardy
Dearly Missed
- 9,832
- 4,894
here's from a real old Oak Ridge report. sounds like they'll be okay if they keep it wet.
I wouldn't even worry about temp somewhat above boiling - like a stove burner heating water from below, it has to be hotter than the pot
http://www.osti.gov/bridge/servlets/purl/6124656-R8y05j/6124656.pdf
cover page says distribution unlimited so i guess it's okay for us to read.
moderator scrub post if it violates anything, I'm still learning my way here.
[q]After structural deformation and downward relocation of molten control
blade, channel box, and candling clad material (in that order) onto the
dry core plate [2], local creep rupture failures of the core plate would
introduce relocating material into the lower plenum water and begin the
accumulation of quenched debris in the reactor vessel bottom head
[3,4]. Relocation of the metal structure of the core is expected to
leave the fuel pellet stacks standing until weakening, by overtemperature,
of the ZrO2 sheaths surrounding the fuel pellets and similar loss
of strength by the previously molten material that tends to weld the fuel
pellets together. It should be noted, given the progressive relocation
methodology outlined above, that the majority of the debris entering the
lower plenum is expected to be in the solid state when it enters the
water.
As the relocated core material accumulates in the 3WR reactor vessel bottom
head, it is expected that the composition of the quenched debris bed
would vary with height. Lowermost in the bed would be the mostly metallic
debris (control blades, canisters, candled clad and dissolved fuel)
that had either accumulated on the core plate before local core plate
failure or had subsequently relocated downward above the core plate failure
locations before fuel pellet stack collapse. Higher, within the
middle region of the bed, would be the collapsed fuel and ZrO2 from the
central region of the core. The initial local core plate structural
failures would cause temporary bursts of steaming as the relocated
metallic debris was quenched; however, with the collapse of the central
core fuel pellet stacks, a constant heat source (the decay heat
associated with the pellets) would be introduced to the lower plenum
reservoir, initiating a rapid continuous boiloff of the lower plenum
water.[/q]
stuff at bottom of pile protects vessel from the corium in middle of pile?
it's only a flesh wound...
water.
water.[/q]
