(a) If A and B are disjoint closed sets in some
In summary: A and y ∈ B, we have d(x,y) > δ, and so A and B are separated. In summary, we proved that for (a) and (b), if A and B are disjoint closed or open sets in a metric space X, then they are separated. For (c), we showed that for any point p in X and a given distance ∂ > 0, the sets A and B defined by d(p,q) < ∂ and d(p,q) > ∂ are separated.
Jamin2112
986
(a) If A and B are disjoint closed sets in some ...
(a) If A and B are disjoint closed sets in some metric space X, prove that they are separated.
(b) Prove the same for disjoint open sets.
(c) Fix p in X, ∂ >0, define A to be the set of all q in Z for which d(p,q) < ∂, define B similarly, with > in place of <. Prove that A and B are separated.
Triangle inequality, definitions of open and closed sets
Give me some hints to finishing part (c).
(a) To prove that A and B are separated, we need to show that there exists a distance δ > 0 such that for any two points x ∈ A and y ∈ B, we have d(x,y) > δ.
Since A and B are disjoint closed sets, we know that X \ A and X \ B are open sets. Since X \ A is open, for any point x ∈ A, there exists a δx > 0 such that the open ball B(x,δx) is contained in X \ A. Similarly, for any point y ∈ B, there exists a δy > 0 such that the open ball B(y,δy) is contained in X \ B.
Now, let δ = min{δx, δy}. Since A and B are disjoint, this means that for any x ∈ A and y ∈ B, the open balls B(x,δ) and B(y,δ) are disjoint. Therefore, d(x,y) > δ for all x ∈ A and y ∈ B, which means that A and B are separated.
(b) The proof for (b) is very similar to the proof for (a), except instead of using X \ A and X \ B, we use A^c and B^c, the complements of A and B. Since A and B are disjoint open sets, their complements A^c and B^c are closed. Following the same steps as in (a), we can show that A and B are separated.
(c) To prove that A and B are separated, we need to show that there exists a distance δ > 0 such that for any two points x ∈ A and y ∈ B, we have d(x,y) > δ.
Let x ∈ A and y ∈ B. This means that d(p,x) < ∂ and d(p,y) > ∂. We want to find a δ > 0 that satisfies d(x,y) > δ.
By the triangle inequality, we have d(x,y) ≤ d(x,p) + d(p,y). Since d(p,x) < ∂ and d(p,y) > ∂, we can choose δ = d(p,y) - d(p,x). This gives us d(x,y) ≤ d(x,p) + (d(p,y) - d(p,x)) = d(y,p) < ∂.
Therefore, for any x ∈
1. What does it mean for two sets to be disjoint?
Two sets are said to be disjoint if they have no elements in common. In other words, there is no overlap between the two sets.
2. What does it mean for sets to be closed?
A set is considered closed if it contains all of its limit points. This means that every point on the boundary of the set is also included in the set.
3. Are disjoint closed sets always mutually exclusive?
Yes, if two sets are disjoint, then they are also mutually exclusive. This is because there are no elements that are shared between the two sets.
4. Can disjoint closed sets overlap in any way?
No, by definition, disjoint sets have no elements in common and therefore cannot overlap in any way.
5. How do disjoint closed sets relate to each other?
If two sets are disjoint, they have no elements in common and therefore have no intersection. However, they can still complement each other, meaning that the union of the two sets will result in the entire space in which they exist.
