Is there a solution for compression of cylinder?
In summary, this problem can be solved by finding the stress or strain in the axial direction. However, it may require a supercomputer to solve.
Mugged
104
Hello,
for some reason I can't seem to be able to find this.
Suppose you have a elastic cylinder, a full cylindrical bar (not hollow), and you want to compress the two end faces (axial compression) together and find the stress in the axial direction...or strain.
I can't seem to be able to find this problem posed anywhere in a google search and it seems easy enough for there to be a textbook analytical expression.
anyone know of any references?
Thank you
Mugged said:
Hello,
Thank you
This is the same problem of a bar in tension, except that the imposed tension stress is negative. The compressive strain is just the compressive stress divided by Young's modulus.
If its elastic than you probably won't find an analytical expression that doesn't require a supercomputer to solve.
Mugged, what is special about your cylinder or axial loading that makes this problem difficult?
The answer by Mech_Engineer is one of the first things in any mechanics of materials book.
However this assumes several things.
Firstly that the cylinder axis is long compared to its diameter
Secondly that the applied force is (sensibly) normal to the end faces
Thirdly that the applied force is applied via a large stiff plate, larger than the diameter of the cylinder
Fourthly that the cylinder is not restrained from expansion along its curved surfaces
Fifthly that the material is isotropic
Please note one more thing about Mech_eng link.
The link refers to failure, where stresses are different.
I presume you are asking about a non destructive load?
The problem is still tractable however, Aero51 is over the top with his suggestion.
1. What is compression of a cylinder?
Compression of a cylinder refers to the reduction in volume of a gas or liquid when it is placed under pressure. This can also refer to the mechanical process of decreasing the size of a cylinder by applying external force.
2. Why is compression of a cylinder important?
Compression of a cylinder is important because it allows for the storage and transportation of gases and liquids in a more compact and efficient way. It also plays a crucial role in many industrial processes such as refrigeration, air compression, and hydraulic systems.
3. Is there a universal solution for compression of a cylinder?
No, there is no one universal solution for compression of a cylinder. The specific solution will depend on the type of gas or liquid being compressed, the desired pressure, and the intended use of the compressed material.
4. What are some common methods for compressing a cylinder?
Some common methods for compressing a cylinder include using a piston and cylinder system, a rotary compressor, or a scroll compressor. Other methods include using a centrifugal or reciprocating compressor, or using a gas ejector or booster.
5. What are the potential hazards of compressing a cylinder?
The potential hazards of compressing a cylinder include explosions or leaks due to the high pressures involved, as well as the risk of exposure to toxic or flammable gases. It is important to follow proper safety protocols and to use appropriate equipment when compressing cylinders.
  • Mechanical Engineering
