Lorentz force and Maxwell Equations
In summary: But the electric force can also be viewed as a manifestation of the magnetic force according to some theory. Someone might be able to provide a more in-depth explanation or justification for this view.In summary, the Lorentz force can be derived from Maxwell's equations, but it is not the only way to do it. There is another way which is more accessible to undergrads.
sokrates
483
I am trying to bridge a gap between Maxwell equations and Lorentz force. I know that they are not independent and in theory, one could be derived from the other but I cannot see that.
More physics oriented people prefer the Lorentz force because it describes the effect of B and E as a final force on the particle, which is good.
But all that should also be captured by Maxwell's set. And in classical EM theory, they don't even mention Lorentz force.
Could anyone show a theoretical derivation or provide some remarks on this issue?
many thanks,
Oh, one nice way you can derive the Lorentz force is by taking the extremum of the action, just use good old Lagrangian physics to find the path of a charge through an electric and magnetic field. It should come out nicely, Feynman has a good derivation of it in his Quantum Mechanics and Path Integrals book if you are lucky enough to find a copy.
many thanks,
Wikipedia has a good article on this: http://en.wikipedia.org/wiki/Lorentz_force
Someone has done a paper to show that the Lorentz force can be derived from Maxwell's equations: http://arxiv.org/abs/physics/0206022
AM
I asked something quite similar in this thread:
https://www.physicsforums.com/showthread.php?t=251261
I was pointed to the stress energy tensor, which relates the two up to a point. For example, if you take the time derivative of the field energy density
[tex]
U = \frac{\epsilon_0 (\mathbf{E}^2 + c^2 \mathbf{B}^2)}{2}
[/tex]
you'll can get after application of Maxwell's equations and some messy algebra
[tex]
\frac{\partial}{\partial t}\frac{\epsilon_0 (\mathbf{E}^2 + c^2 \mathbf{B}^2)}{2}
+ c^2 \epsilon_0 \nabla \cdot ( \mathbf{E} \times \mathbf{B} ) = - \mathbf{E} \cdot \mathbf{j}
[/tex]
The [itex]- \mathbf{E} \cdot \mathbf{j}[/itex] term on the RHS is the energy term of the Lorentz force equation. If you do the same thing, taking time derivatives of the momentum density terms (the Poynting vector components [itex]\mathbf{E} \times \mathbf{B}[/itex]), then the RHS terms will be of the form
[tex]
\rho \mathbf{E} + \mathbf{j} \times \mathbf{B}
[/tex]
These are the momentum parts of the Lorentz force equation per unit volume. So, only considering derivatives of fields, one is able to see that there is a fundamental relationship between the Maxwell's equations and something that is like the Lorentz force, but without doing something else one still needs a way to relate this to the force on a mass.
Likes Caowy
The Lorentz force equation contains both electric and a magnetic force terms. It is possible to show that they are both manifestations of the same electric force, as seen from stationary and moving reference frames according to the laws of special relativity. The derivation is given in a simple way in Nobel laureate E.M. Purcell's first year undergraduate book ("Electricity and Magnetism").
Maxwell's equations may be derived in the same way, starting from Coulomb's law and using special relativity and symmetry arguments. The upper level undergraduate book M. Schwartz, Principles of Electrodynamics, by another Nobel laureate, lays it out in the first few chapters. Once he derives the Lorentz force, Schwartz needs only a few more pages to derive the vector potential, magnetic field, and then all of the Maxwell equations in vacuuo.
The unity of electricity and magnetism, and their relation through relativity, is one of the great beauties in physics. It is accessible to undergrads through the treatments mentioned above.
But the electric force can also be viewed as a manifestation of the magnetic force according to Einstein in his 1905 paper "On The Electrodynamics Of Moving Bodies". He stated that neither the electric nor magnetic force is the "seat", seat meaning root, or basis.
Electric and magnetic forces are inclusive. Either can be viewed as a manifestation of the other with regard to relativity. E is not more basic than H, nor less so.
Claude
  • Einstein.pdf
Fair enough. Having said that, however, there is considerable merit to starting with the electric force and not going the other way around. Coulomb's law is taught in high-school physics, and, being a central force, is intuitively reasonable. I venture that few beginners in physics are sufficiently comfortable with magnetism, with its curly behavior and its dependence on currents, to be able to start from the magnetic force and then move to the electric.
The Lorentz force cannot be derived from Maxwell's equations.
And your point is ----- ?
Claude
Claude
I think his point is an answer to the original question:
"I am trying to bridge a gap between Maxwell equations and Lorentz force. I know that they are not independent and in theory, one could be derived from the other but I cannot see that."
AM
This paper seems to show just the opposite, that an additional postulate is required.
True. You could linearly rescale the Lorenz force and it would still be consistent with Maxwell's equations + conservation of energy/momentum.
I wasn't thinking of linear rescalings. I was thinking that the Lorentz force law can't be derived from Maxwell's equations in the same way that charge conservation can, without additional assumptions. If one adds the assumption of energy/momentum conservation then the Lorentz force law can be derived from Maxwell's equations, as you say.
How?
No, it is not possible to derive Newton's 2nd law (i.e., Lorentz force) from Maxwell equations. If such cosistent derivation is possible, then Maxwell or Lorentz would have done it.
regards
sam
clem said:
How?
I don't actually know how, am simply putting blind faith in MTW, who state the result without derivation on p473 http://books.google.com/books?id=w4Gigq3tY1kC&printsec=frontcover&source=gbs_navlinks_s. I thought it reasonable because in the context of GR, the geodesic equation of motion doesn't have to be supplied independently of the Einstein field equations, so perhaps if one has the Einstein and Maxwell field equations, then the Lorentz equation of motion will pop out.
I think it's fair under any circumstances to "assume" the energy and momentum conservations are correct since they are fundamental.
I don't even consider those as "extra" assumptions so is it true that Lorentz force can be derived from Maxwell equations "in consistence with known laws of physics" after all?
regards
sam
That's a very convincing way of putting it.
If it had been possible, maxwell or lorentz would have done it.
Hmm..
You almost got me.
An introduction to the Lorentz-Dirac equation
Eric Poisson
http://arxiv.org/abs/gr-qc/9912045
The relativistic transformation of a static transverse electric field yields a transverse field that includes both a transverse electric field and a transverse v x B term. The transformation does not have to be relativistic, because the transformed fields are multiplied by γ, not β, and γ(β=0) = 1. So it can be demonstrated in a Crookes tube for example. Apparently Maxwell actually knew of the "Lorentz" force before Lorentz did. If there were eight, rather than four, Maxwell's Equations (and maybe there should be), this thread would have been unnecessary.
History (from Wikipedia)
Hendrik Lorentz introduced this force in 1892.[5] However, the discovery of the Lorentz force was before Lorentz's time. In particular, it can be seen at equation (77) in Maxwell's 1861 paper On Physical Lines of Force. Later, Maxwell listed it as equation "D" of his 1864 paper, A Dynamical Theory of the Electromagnetic Field, as one of the eight original Maxwell's equations.
What is the Lorentz force?
The Lorentz force is a fundamental law of electromagnetism that describes the force experienced by a charged particle in an electric and magnetic field. It is named after Dutch physicist Hendrik Lorentz and is given by the equation F = q(E + v x B), where q is the charge of the particle, E is the electric field, v is the velocity of the particle, and B is the magnetic field.
What are the Maxwell equations?
The Maxwell equations, also known as the Maxwell's equations, are a set of four fundamental equations that describe the behavior of electric and magnetic fields. They were developed by Scottish physicist James Clerk Maxwell in the 19th century and are considered one of the most important achievements in the field of electromagnetism. The equations are used to understand and predict the behavior of electromagnetic phenomena, such as light, electricity, and magnetism.
What is the significance of the Maxwell equations?
The Maxwell equations are significant because they provide a comprehensive understanding of the relationship between electricity and magnetism. They also helped to unify the previously separate theories of electricity and magnetism, leading to the development of the theory of electromagnetism. The equations have had a profound impact on technology and have been instrumental in the development of modern devices such as radios, televisions, and computers.
How are the Maxwell equations related to the Lorentz force?
The Lorentz force is derived from the Maxwell equations. Specifically, it is a combination of the equations that describe the electric and magnetic fields. The Lorentz force equation can be seen as a way to summarize the complex interactions between electric and magnetic fields and charged particles, as described by the Maxwell equations.
What are some real-world applications of the Lorentz force and Maxwell equations?
The Lorentz force and Maxwell equations have numerous real-world applications. Some examples include the operation of electric motors, the functioning of generators in power plants, the operation of particle accelerators, and the behavior of electromagnetic waves in communication systems. These principles also play a crucial role in modern technologies such as MRI machines, satellite communications, and navigation systems.
  • Electromagnetism
