| New Reply |
Is it possible that speed of a gravitational waves are greater than c? |
Share Thread |
| May27-12, 04:13 AM | #52 |
Nothing in this universe moves 'instantly' at the other end when you push/pull it. It's called Young's modulus, in case you were curious.
| May27-12, 06:09 AM | #53 |
Ok, while i still processing this, the following questions emerged :
"It is clear that two events that are simultaneous in frame S (satisfying Δt = 0), are not necessarily simultaneous in another inertial frame S′ (satisfying Δt′ = 0). Only if these events are colocal in frame S (satisfying Δx = 0), will they be simultaneous in another frame S′." That takes the assumption, that gravity isnt absolute spacetime. http://library.thinkquest.org/C01160...theorytext.htm That takes the assumption, that not just local time, not just a ruler's size, but distance itself is dependant on light. Is there any experiment, that invalidates, that gravity is absolute spacetime? http://vixra.org/pdf/1110.0037v1.pdf That says the working of GPS shows that c is constant in the frame of gravity field. Not constant to everthing that moves. (Like Earth's surface. MM experiment doesnt showed Earth's rotation due to the length contradiction of the interferometer's arm.) What do theese calculations say about the following dilemma i read : there is a fast moving train, observer A on the train, observer B is on the ground. You light two bulbs at the begin and end of the train. Is it possible, that both A and B see both lights at the same time? |
| New Reply |
Similar discussions for: Is it possible that speed of a gravitational waves are greater than c?
| Thread | Forum | Replies | ||
| What is the speed of gravitational waves? | Special & General Relativity | 3 | ||
| Gravitational Waves and Speed of Light | Special & General Relativity | 21 | ||
| Speed of Gravitational Waves | Special & General Relativity | 31 | ||
| LIGO and speed of gravitational waves | Special & General Relativity | 8 | ||
| LIGO and speed of gravitational waves | General Physics | 18 | ||
