- #1
cpp6f
- 4
- 0
If I have a matrix valued function A(x) of some scalar x, how do I compute the derivative of the square root of A with respect to x? It seems like it should be simple, but I can't find it anywhere on the internet. Thanks!
cpp6f said:I forgot to mention that A is positive definitive. So the principle square root of A (the square root that is also positive definitive)
The derivative of a matrix square root is a matrix of the same size as the original matrix, with each element being the derivative of the corresponding element in the square root matrix.
The derivative of a matrix square root is calculated using the chain rule, where the derivative of the square root function is multiplied by the derivative of the matrix inside the square root.
The derivative of a matrix square root is important in mathematics because it allows us to find the rate of change of a matrix with respect to its square root. This can be useful in various fields, such as optimization, control theory, and statistics.
Yes, the derivative of a matrix square root can be negative. This means that as the value of the matrix increases, the value of its square root decreases.
No, the derivative of a matrix square root is not always defined. It is only defined for matrices that have real and positive eigenvalues. If a matrix has complex or negative eigenvalues, the derivative of its square root is not well-defined.
