Simple Harmonic Motion-Solving for Spring Constant
In summary: Thanks again.In summary, the total energy of a particle undergoing simple harmonic motion with the given parameters can be calculated using the equation E=1/2 kA^2, where k is the spring constant and A is the amplitude. The spring constant can be calculated using the equation k=mω^2, where m is the mass and ω is the angular frequency. The total energy is conserved and is equal to the sum of the kinetic and potential energies.
Wellesley
274
16. Suppose that a particle of mass 0.24 kg acted upon by a spring undergoes simple harmonic motion with the parameters given in Problem 1.
(a) What is the total energy of this motion?
(b) At what time is the kinetic energy zero? At what time is the potential energy zero?
(c) At what time is the kinetic energy equal to the potential energy?
________________________________________________________
1. A particle moves back and forth along the x-axis between the points x = 0.20 m and x = –0.20 m. The period of the motion is 1.2 s, and it is simple harmonic. At the time t = 0, the particle is at x = 0 and its velocity is positive.
(a) What is the frequency of the motion? The angular frequency?
(b) What is the amplitude of the motion?
(c) What is the phase constant?
(d) At what time will the particle reach the point x = 0.20 m? At what time will it reach the point x = –0.10 m?
(e) What is the speed of the particle when it is at x = 0? What is the speed of the particle when it reaches the point x = – 0.10 m?
f=frequency=0.83 Hz
[tex]\omega[/tex]= angular frequency= 2*pi*0.3= (5*pi)/3 or 5.23599 rad/s
T=period=1.2 s
m=mass=0.24 kg
A= amplitude=0.2 m
My problem lies in part a of number 16: What is the total energy of this motion? The rest of the question I can solve easily.
I know the error has to do with the spring constant and the angular frequency.
[tex]\omega=[/tex][tex]\sqrt{k/m}[/tex]
k=[tex]\omega^{2}[/tex] * m
k=5.2359992*0.24=6.57974 N/m ----> [STRIKE]Pretty darn small for a spring constant.[/STRIKE]
I then tried this to make sure k was right:
T=2*pi*[tex]\sqrt{k/m}[/tex]
And got: k=6.57974 N/m
Then when I solve for total energy...
E=1/2kA2 -->1/2*6.57974 N/m *(0.2m)2--->E=.131595 J
The answer in the back is 6.6 Joules.
When I tried to work backwards, from the answer I get:
(6.6 J*2)/.22-->330 N/m as the spring constant.
I'm pretty sure my numbers are right...what could be throwing the answer off by a factor of fifty times? From past experience, I'm pretty certain the book isn't wrong, but in this case, I'm not sure...
Any help would be appreciated. Thanks!
The units produced from your equation for k produce kg/s^2. That is not a spring constant unit. The spring constant is a force/distance.
Also, you only calculated the potential energy, the total energy of the system involves the kinetic energy as well.
E = T + V
where E is the total energy
T is the kinetic energy
V is the potential energy
First calculate the spring constant with the correct units.
Thanks
Matt
I know that the units for my spring constant are correct. Newton/meter--> (kg*m/s^2)/meter ---->leaves kg/s^2 as the units. If you were to multiply kg/s2 by a meter, you would get kg*m/s2, which is a Newton (and the correct unit from the equation F=-kx).
This link also confirms this...http://www.rwc.uc.edu/koehler/biophys.2ed/sho.html
The spring constant clearly has units of force over distance, or kg / s2.
E = T + V
I'm confused. I did calculate the total energy. I used this equation: E=1/2kA2...the same one from Wikipedia (and my physics book)...
The total mechanical energy of the system therefore has the constant value
E = K + U = 1/2 k A^2.
http://en.wikipedia.org/wiki/Simple_harmonic_motion ---> (under Energy of simple harmonic motion).After going through the equations again, I still feel my answer is right. Any thoughts anybody?
Your answer is right. There can be errors in any book.
ehild
ehild
Thanks. That makes me feel a little better. While I was doing this problem yesterday, I thought I was losing it, when I kept coming up with an answer fifty times smaller than what the back of the book had. Even though any book is prone to errors, I needed to make sure.
Can you show how you go from kg/s^2 to N/m?
I follow the definition for a Newton but I don't see how to flip kg/s^2 to N/m without involving the gravitation constant.
I don't follow the wikipedia arcticle either. In my vibration text, "An Introduction to Mechanical Vibrations" by Robert Steidel 3rd Edition, the following is stated.
"For the total energy, E,
E = T + V
In this equation, T denotes kinetic energy due to the velocity of the mass of the system, and V is potential energy, either due to the configuration of this mass as measured from some arbitrary datum or due to the stress of the elastic member."
Let me know what the final outcome is. I apologize if I have helped you poorly.
Thanks
Matt
Matt,
Newton= kg*m/s^2. N/m =(kg*m/s^2 )/m = kg/s^2.
Or backwards: kg/s^2= (kg*m/s^2) /m =N/m.
For a mass m, connected to a spring and performing simple harmonic motion, the total energy is 1/2 mv^2+kx^2, where x is the displacement from equilibrium, v is the velocity and k is the spring constant, and this total energy is conserved. At maximum displacement, v =0 and the magnitude of x is equal to the amplitude A. So the total energy is E=1/2 kA^2.
Thanks
Matt
No need to apologize...I'm sorry if I came across as ungrateful. I should have waited until the morning to reply, instead of writing my response at 11:30 PM.
Please, if you have any more thoughts on this problem, I would be grateful if you shared them.
No problem. I make mistakes everyday. :blushing: Thats how I no that I am doing something. :rofl:
Thanks
Matt
What is simple harmonic motion?
Simple harmonic motion is the repeated back and forth movement of an object around an equilibrium point, where the restoring force is proportional to the displacement from the equilibrium point and always directed towards it.
How do you solve for the spring constant in simple harmonic motion?
To solve for the spring constant, you need to know the mass of the object, the amplitude of the motion, and the period of oscillation. The spring constant is equal to the mass multiplied by the square of the angular frequency, divided by the square of the amplitude.
What are the units for spring constant?
The units for spring constant are usually given in newtons per meter (N/m) or in kilograms per second squared (kg/s^2).
Can the spring constant change for a given system?
Yes, the spring constant can change for a given system if the physical characteristics of the spring, such as its length or material, are altered. The spring constant can also vary depending on the temperature and the environment.
How does the spring constant affect simple harmonic motion?
The spring constant determines the strength of the restoring force and, therefore, the frequency and period of the oscillation. A higher spring constant results in a faster oscillation, while a lower spring constant leads to a slower oscillation.
