Dimensional analysis of the fermion mass renormalization
In summary, dimensional analysis is a method used to determine the scaling of a physical quantity based on its units and symmetries. By applying this method to the mass shift in fermion mass renormalization, it can be seen that the resulting diagram is proportional to ##m_e \ln \Lambda##, where ##m_e## is the mass of the electron and ##\ln \Lambda## is dimensionless. This shows that the divergence of such diagrams is at most logarithmic, and not worse, due to the cancellation of odd terms in the integral.
phypar
In the textbook, usually the fermion mass renormalization is introduced as follows: the mass shift [itex]\delta m[/itex] must vanish when [itex]m_0=0[/itex]. The mass shift must therefore be proportional to [itex]m_0[/itex]. By dimensional analysis, it can only depend logarithmically on [itex]\Lambda[/itex] (the ultraviolet cutoff): [itex]\delta m \sim \ln \Lambda[/itex].
Here I don't understand how the "dimensional analysis" is performed, can somebody explain it in detail? Thanks in advance.
Take a look at e.g. the diagram (a) here, in QED: http://ej.iop.org/images/1751-8121/45/38/383001/Full/jpa374448f4_online.jpg
This diagram will correct the mass of the electron. Schematically, this diagram has a value that looks like
##\int d^4 p \frac{\gamma^\mu p_\mu + m_e}{p^2 + m^2}\frac{1}{p^2}##
The integrand has dimension 1/[mass]^3, so the diagram has a whole has dimension [mass]^1.
Now, the integral superficially seems to be linearly divergent, like ##\int d^4 p (1/p^3)##. In that case the result would be proportional to ##\Lambda## times a dimensionless constant (since it must have dimensions of [mass]^1). However, looking a little closer we see that the term involving ##\gamma^\mu p_\mu## is odd in ##p## and therefore cancels out, leaving
##m_e \int d^4 p \frac{1}{p^2 + m^2}\frac{1}{p^2}##
Now we can see that the integral is actually logarithmically divergent, so the diagram is proportional to ##m_e \ln \Lambda##. Here ##m_e## has units of [mass]^1 and ##\ln \Lambda## is dimensionless, so the diagram has units of [mass]^1, as required.
The point of the symmetry+dimensional analysis argument is to argue that this same thing will happen generally. The diagram has to have units of [mass]^1, and must be proportional to ##m_e##. So whatever the diagram evaluates to, it has to look like ##m_e## times something dimensionless. The only dimensionless thing you can make out of ##\Lambda## is ##\ln \Lambda##, so at worst diagrams like this can only diverge like ##\ln \Lambda## and not, say, ##\Lambda^2##.
Likes 1 person
Thanks a lot, you gave a very clear explanation. Now I understand it fully.
1. What is dimensional analysis in the context of fermion mass renormalization?
Dimensional analysis is a mathematical method used to determine the scaling behavior of physical quantities in a system. In the context of fermion mass renormalization, it is used to study how the mass of a fermion changes as a function of energy scale.
2. Why is dimensional analysis important in the study of fermion mass renormalization?
Dimensional analysis is important because it provides a way to identify the relevant physical parameters that affect the mass of a fermion and their scaling behavior. This allows for a deeper understanding of the underlying physics and can help guide the development of theoretical models.
3. Can dimensional analysis be applied to any type of fermion?
Yes, dimensional analysis can be applied to any type of fermion, as it is a general mathematical method. However, the specific parameters and scaling behavior may vary depending on the type of fermion being studied.
4. How does dimensional analysis relate to the concept of renormalization in quantum field theory?
Dimensional analysis is closely related to renormalization in quantum field theory. In fact, renormalization techniques often involve using dimensional analysis to determine the scaling behavior of physical quantities in a system. This can help to remove infinities and make physical predictions more accurate.
5. Are there any limitations to using dimensional analysis in the study of fermion mass renormalization?
While dimensional analysis can provide valuable insights, it is not a substitute for a rigorous mathematical analysis. It is important to use it in conjunction with other techniques and approaches to fully understand the complexities of fermion mass renormalization.
