dhemoxeus
- 1
please elaborate their difference in your own word.. thanks!
(SURVEY)
(SURVEY)
The main difference between induced voltage and generated voltage is the source of the voltage. Induced voltage is created when a conductor moves through a magnetic field, causing a change in the magnetic flux. On the other hand, generated voltage is produced by a generator or alternator, which converts mechanical energy into electrical energy.
Induced voltage and generated voltage are both forms of electromagnetic induction. Induced voltage is a result of Faraday's law, which states that a changing magnetic field induces an electric field. Generated voltage, on the other hand, is a result of Lenz's law, which states that the direction of the induced voltage opposes the change in magnetic flux.
Yes, both induced voltage and generated voltage can be measured using a voltmeter. Induced voltage can be measured by connecting the conductor that is moving through the magnetic field to the voltmeter, while generated voltage can be measured by connecting the output terminals of the generator or alternator to the voltmeter.
An example of induced voltage is the electricity generated in a hydroelectric dam, where water flowing through a magnetic field induces a voltage in the turbines. An example of generated voltage is the electricity produced by a car's alternator, where the mechanical energy from the engine is converted into electrical energy to power the car's electrical systems.
The magnitude of induced voltage depends on factors such as the strength of the magnetic field, the speed of the conductor, and the angle between the conductor and the magnetic field. On the other hand, the magnitude of generated voltage depends on the size and speed of the generator or alternator, as well as the strength of the magnetic field used to generate the voltage.
