| New Reply |
Confused about definitions in optics |
Share Thread | Thread Tools |
| Feb3-13, 02:17 AM | #1 |
The width of a pulse is typically given in the time domain, correct? The effective width is the term to describe this.
What is the spectral width in the frequency domain? How do you calculate spectral widths and effective widths? Thanks for your time. |
| PhysOrg.com |
physics news on PhysOrg.com >> Promising doped zirconia >> New X-ray method shows how frog embryos could help thwart disease >> Bringing life into focus |
| Feb3-13, 10:31 AM | #2 |
From wiki:
Imagine you have a chart where the X axis runs from 500 nm to 550 nm and the Y axis is the intensity. If you plot the spectral width of a 525 nm laser you will see a very sharp peak in the center of your graph. But it's not perfectly sharp, you still have a range of wavelengths other than 525 nm. If you replaced the laser with an LED you would see much shorter, broader peak, as the LED has a wider band it emits in. Frequency domain just means that you are plotting your graph with frequency instead of time. Does that help? |
| Feb3-13, 12:36 PM | #3 |
That helps a lot, thank you. For some reason I couldn't find that wiki article.
So are frequency bandwidth and spectral width practically the same thing? |
| Feb3-13, 12:48 PM | #4 |
| New Reply |
| Thread Tools | |
Similar Threads for: Confused about definitions in optics
| Thread | Forum | Replies | ||
| Confused about this Optics problems Solution | Introductory Physics Homework | 3 | ||
| Confused by separate definitions of sets which are bounded above | Calculus | 3 | ||
| thermodynamics, confused with definitions | Advanced Physics Homework | 6 | ||
| Confused about dispersion (optics) | Classical Physics | 9 | ||
| Analytical definitions vs intuitive (or perhaps "first year") definitions | Calculus | 1 | ||
